No sound, error 4C00:0619 - Computers & Internet
No sound / Cmos checksum error
dave,move everything back to the positions before the checksum error.and just concentrat on the sound.se what happens.let me now how it goes.
Jul 06, 2013 | Shuttle Computers & Internet
Tip
SONY GRAND WEGA ERROR CODES AND WHAT THAY ARE
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
on Apr 13, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
When i call someone i can hear them but they cant hear me... i want i best solution,,, and my computer says "no sounds card found."
this indicated your sound device was error or sound driver error
try to reinstall sound driver first, if stll error like that place new sound card
Mar 31, 2011 | Computers & Internet
My windows vista dont have internet and sound
Check ur sound card information by doing this
Click on start menu
Click on Run
Type dxdiag, enter
Click on the sound tab
There is button of test direct sound click on this check if there is sound
Check ur registry. Check if the sound registry key is enabled or disabled. There could be an error in registry, run registry cleaner reg in out to scan for errors. Open Internet Explorer
  • Open the Tools menu
  • Select the Internet Options menu item
  • Open the Advanced tab
  • Check the box next to "Disable script debugging"
  • Remove the check next to "Display a notification about every script error"
  • Click the OK button
  • reset all setting, clean registry key for internet explorer use registry cleaner reg in out to scan ur error
Sep 07, 2010 | Microsoft Windows Vista Ultimate Edition
I found code error 88780078
check sound drivers in device manager
run-->devmgmt.msc
Jan 10, 2009 | HP Pavilion dv6000z Notebook
Please install proper drivers...error cod 88780078
The sound card features might be turned off and causing Error Code: 88780078.
To activate these "features":
1)control panel
2)sounds and audio devices
3)Hardware tab
4)sound card should be listed... highlight... Properties
5)Properties tab
6)Audio Devices
7)highlight sound card and click Properties
8)If audio features are disabled... select "Use audio features on this device"
9)restart computer
Dec 25, 2008 | Compaq Creative Sound Blaster PCI 64 Sound...
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Fan error 4 times
Temp error 4 times
Audio error 7 times
- Blowout of a fuse
- IC failure
D-OVP error 8 times
(A board, B board)
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
M2N-MX sound
Try reinstalling the drivers, which can be found here.
Apr 06, 2008 | Creative Labs Sound Blaster Live! 5.1...
No sound driver found
Usually if its onboard sound or a sound card that came stock with your system Windows Update should be able to find it; go into device manager and uninstall your sound device…then reboot and allow Windows to find your sound device then allow Windows to search Windows Update for the driver (this might take a minute).
Nov 10, 2007 | Computers & Internet
Computers & Internet Logo
393 people viewed this question
David Payne
David Payne
