Question about Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
No Hot Water - Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
  •  Christopher a Martin
    Hello Did you check the curcit breaker at the house electric panel?It will be a double breaker.
    Scholar:
  • 122 Answers
Check power
check reset button - this is located on the upper thermostat - red button
if these are ok, then it most likely is your element. I would replace both at the same time instead of just the bad one. make sure they are both the same, usually 4500 watts, take them with you to the store to make sure you get the right parts
Posted on Sep 08, 2010
Have gas storage Rheem hot water system, pressure in hot water taps is low
hot water pressure is equal to cold water inlet pressure
check for tap restriction, hot water section free of air , ( release the pressure valve ;lever to fill and bleed out air)
if you have a hot/cold mixer at the hot water system, they can fail and block of the hot water flow
(That unit has to be fitted by law on heater installation)
have it tested first as they cost in excess of $15.00 aud to replace
Apr 20, 2018 | Rheem Water Heaters
No hot water , no heater
No Hot Water - Electric Water Heater Troubleshooting
www.whirlpoolwaterheaters.com/owner-center/.../no-hot-water/
Whirlpool's video explaining potential reasons your water heater is not working ... Troubleshooting and Repair · No Hot Water (Video) · Replacing a Heating ...
Electric Water Heater Repair and Troubleshooting ' Whirlpool
www.whirlpoolwaterheaters.com/owner.../troubleshooting-repair/
Troubleshooting and Repair of a Standard Electric Water Heater. No Hot Water ... Not getting power is a common reason new water heaters don't work.
Troubleshooting Electric Water Heaters in MINUTES ~ Step ...
? 7:01
https://www.youtube.com/watch?v=SlyStHM9Nr0
Oct 4, 2013 - Uploaded by electronicsNmore
My tenant has a electric 30 gallon water tank. cimarron by Reheem. model ... So if u notice your water is overly hot and then notice no hot water ...
Dec 26, 2015 | Water Water Heaters
Hot water heater has hot in tank but dose not come out of hot water line on tank
most electric hot water systems use a heat transfer process where the element is in one tank and the house water is in another
the house water is what is being drawn off when you turn on a tap
there is a regulator valve at the top of the tank with a small lever that you open up to let water in and air out of the system
another point is that there may be a hot/cold mixer on the hot water outlet which limits the temperature of hot water to prevent scalding injuries in the bath and shower or sink
If you have one fitted they are known to malfunction and cut the hot water temperature down as, they mix too much cold water into the hot water pipe.
have a plumber check it out
Jun 13, 2015 | Water Water Heaters
I have a new Bradford white 40 gallon gas hot water heater. There are no single handle faucets. The hot water fluctuates between hot and cold. When I close both inlet and outlet shut off for the hot water...
Sounds like water leak.
For example, broken pipe... or water running out of TP valve.
That would explain variable hot-and-cold water at tap.
Turn off all taps, and observe if water meter is registering water usage.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 15, 2014 | Water Heaters
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm: Unit isn't turning on when I turn on the hot water...
Has it ever run? Is cold water going to cold water inlet? Hot out to hot water piping? Power ON? Control pad on? gas pressure correct?
May 16, 2010 | Rheem Tankless Hot Water Heater...
Hot water comes out cold side for few seconds and gets cold, no hot from hot side, only cold
Make sure that the water pipes for the cold water coming in and the hot water going out are connected to the correct positions on the water heater. If the connections get reversed, the water that is supposed to be hot will be drawn from the bottom of the tank and will not be as hot as it should be. The cold water input goes to the bottom of the tank. The hot water out comes from the top of the tank.
Oct 09, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802 Logo
62 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
