Question about HP Deskjet F340 All-In-One Printer
Printer says door open
We replaced the ink cartridges and the computer says "door open", nothing will print.
  • 2 more comments
  • elona May 15, 2008
    I've got the same problem and tried your suggestion but to no avail. Any other ideas
  • gingerhero May 25, 2008
    i have the HP Deskjet F340 All-In-One Printer, Copier,Scanner and every time i go to print it just says :"printer door open" and i dont know how to fix it. to be honest i have no clue where the "printer door" is supposed to be. i checked the front and theres nothing i can do to fix the door
  • Anonymous Mar 23, 2014
    CARTRIDGE DOES NOT STOP IN OPENING WHEN DOOR IS OPENED
  • Anonymous Mar 24, 2014
    how to open printer
    Problem Solver:
  • 15 Answers
Aah simple solution to that modiboni. you need to check if the printer door is still open but youv already tried that im sureoption 2 im not to sure on your printer but when you open the door chek to see o protruding plastic that will activate a switch to say the door is closed if you see that the plastic is broken use a small item to push down the sensor and it hopefully should read that the printer door is closed.
Posted on May 13, 2008
2 Suggested Answers
  • 18 Answers
SOURCE: Replaced ink cartridges but printer does not print
u did not mention which operating system, if u r using xp then click on start go to controlpanel , and controlpanel click on printer and faxes and if u r using
vista or windos 7 click on start go to controlpanel , and controlpanel click on printer,
1.under printer icon u can there would b a tab "add a printer"
2.u will get a new window select "add a local printer" click on next
3.select the port usb virtual 001 for usb connection and select lpt 1 for wireless, click on next
4.on the next page on the left hand side select HP and on the right hand side select deskjet 990c printer
5.and know that u r not using this printer
6.click next use this printer as a default one
7.it will give u an option to print a test page
8.click on "no" and hit next
9.now try to print and check
Posted on Nov 12, 2009
How do I load ink and toner in hp laserjet 1100
By load the toner, if you mean inserting the toner cartridge.Then i will give you instructions.In laser toner printer, there is toner cartridge, and not ink jet cartridge.In laser toner cartridges, there is a black color toner power and it does have any liquid ink, which ink jet cartridges have.To remove the laser toner cartridge from hp laser jet 1100 printer, its simple.The front door open and old toner cartridge comes out.Just pull the front door towards you.While inserting cartridge.If you have problem, then take note that, sticker side of the cartridge is towards you.On the cartridge there is a rectangle flap, which you hold in your hand.This is meant for holding the cartridge, while removing and inserting cartridge.The stick side will be in your side.There is a green color drum, the drum side will be on opposite site.-------------- Still any problem.Keep updated.But i think that will help.Thanks.Helpmech.
Mar 25, 2011 | HP LaserJet 1100 Printer
How to change the ink cartridge
Checking the ink levels
  1. Open the HP Director .
  2. Click Settings , point to Print Settings , and then click Printer Toolbox .
  3. After the Printer Toolbox opens, click the Estimated Ink Level tab.
  4. For information on obtaining replacement cartridges, click Print Cartridge Ordering Information .
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 21, 2011 | HP OfficeJet 6210 All-In-One InkJet...
Put new ink in printer. got the message "carriage jam" checked ink to see if correctly installed...it was. tried to use it again and same message appeared. Did as was instructed on Kodak...
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed paper out.
Dec 15, 2010 | Office Equipment & Supplies
How to change ink in HP Deskjet F480 printer???
  • Check the ink levels by opening the HP Solution Center. Click on "Settings." Click on "Toolbox." Click on "Services." Click on "Service this device." Click on "Estimated Ink Levels." A graphic will appear showing the estimated ink level in each cartridge.
  • 2 Verify that the unit is on. Open the print cartridge door allowing the print carriage to move to the far right side of the unit. Once the print carriage has stopped, lightly press down on a print cartridge to release it. Pull the print cartridge toward you out of its slot. To replace the tri-color print cartridge, remove the print cartridge from the slot on the left. To replace the black or photo print cartridge, remove the print cartridge from the slot on the right. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  • 3 Remove the new print cartridge from its packaging. Remove the plastic tape by using the pull tab, being careful to not touch the copper-colored contacts or the ink nozzles under tape.
  • 4 Slide the new print cartridge forward into the empty slot. Gently push the upper part of the print cartridge until it clicks into place. The tri-color print cartridge fits into the left slot. The black or photo print cartridge fits into the right slot.
  • 5 Close the print cartridge door. If the print cartridge alignment sheet prints, load it on the left front corner of the scanner glass with the top of the page to the left. Verify that there is plain paper loaded in the input tray, and then press the "Scan" button to align the printer.
  • Read more: How to Replace an Ink Cartridge in an HP Deskjet F340 ' eHow.com http://www.ehow.com/how_2303716_replace-ink-cartridge-hp-deskjet.html#ixzz16MAooFTf
    Nov 26, 2010 | HP DeskJet F380 All-In-One Printer
    Having trouble fitting new ink cartridge
    Hi, when an ink cartridge runs low in your HP Officejet 5610 All-in-One printer, you will see a message on the printer's display screen. Faded-looking text or pictures also indicate low ink. Ensure print quality by replacing ink cartridges when they run low.
    Instructions
    Things You'll Need:
    * HP #27 or #56 black, #22 color or #58 color photo print cartridge, or compatible equivalent
    Turn printer on if it is off. Never attempt to change the ink cartridge if the printer is off. If it is off, it will not properly position or release ink cartridges, and attempting to change the ink cartridges may damage the printer.
    Open the print-carriage door, located on the right side of the printer. The print carriage will automatically move into the access area.
    Push down on the top edge of the cartridge you are replacing to pop it out of its slot. Remove the print cartridge and discard or recycle.
    Pull off the protective tape on the new print cartridge using the pink tab. Do not touch any part of the cartridge except the black plastic. Touching the contacts or ink nozzles under the protective tape can damage the cartridge and result in poor print quality.
    Hold the cartridge upright and push gently forward into the empty ink cartridge slot until it clicks.
    Close the print-carriage door.
    You can also use this video clip to learn more:
    youtube.com/watch?v=wVXUndG-o_Q.
    Please don't forget to rate me thanks.
    Thanks for using fixya...
    Oct 26, 2010 | HP Officejet 5610 All-In-One InkJet...
    I have an hp officejet 7110 all-in-one and I've been getting a message saying that supply expired on the black cartridge. i replace it and it still won't let me print. what else could be wrong
    Hello there:
    This problem is usually due to a print head that needs to be replaced
    I have provided the information that you will need ok
    best regards mike
    This document provides information on how to replace a printhead or ink cartridge.A printhead may need replacing when print quality issues cannot be resolved by cleaning the printheads or a front-panel display message indicates a printhead needs to be replaced.An ink cartridge needs replacing when a front-panel display message indicates either:
    • Low ink levels
    • Ink cartridge approaching expiration date
    CAUTION: Never remove an ink cartridge and a printhead at the same time. Use the table below to identify the correct ink cartridge part number: Ink cartridge Part number HP 14 black print cartridge C5011A HP 14 tri-color print cartridge C5010A Use the table below to identify the correct printhead part number: Printhead Part number HP 14 black printhead C4920A HP 14 cyan printhead C4921A HP 14 magenta printhead C4922A HP 14 yellow printhead C4923A Replacing the ink cartridges Follow the instructions below to replace the ink cartridges:
    1. Turn on the unit, and open the print-carriage access door by lifting the handle until the door locks into place. Figure 1: Opening the access doorc00064456.jpg
    2. The print carriage will move to the center of the unit.After the print carriage stops, remove the ink cartridge by pressing the gray release button, then lifting the cartridge up and out of its slot. Figure 2: Removing the ink cartridgec00064457.jpg
    3. Remove the new ink cartridge from its packaging and, being careful to touch only the black plastic, remove the tape. Figure 3: Removing the tapec00064458.jpg
    4. With the ink cartridge label face-up, push the new ink cartridge firmly down into the appropriate slot until it clicks into place.The color ink cartridge inserts into the right-hand slot as indicated by the rainbow colored oval. Figure 4: Inserting the new cartridgec00064459.jpg
    5. Close the print carriage access door. CAUTION: If the ink cartridge is removed before a replacement is available, close the print carriage access door and replace the ink cartridge within 24 hours.
    Identifying parts of the printheads Use the table below to identify the parts:
    1. Printhead handle
    2. Printhead tower
    3. Copper contacts
    4. Plastic tape
    5. Ink nozzles
    c00064460.jpg Do not touch:
    • Copper contacts
    • Ink nozzles
    • Printhead tower
    Jan 24, 2010 | HP OfficeJet 7110 All-In-One Thermal...
    It prints improperly, dark on top then fades to nothing.
    Here are the steps.
    1.Please verify that the ink cartridges are intact and securely inserted into the printhead.
    a.Lift the printer access door, then remove the ink cartridges from the printhead
    b.Verify that the label on the ink cartridges is intact, and the cartridges are not damaged.
    c.Insert the ink cartridges into the printhead, then press down firmly until you hear them click into position.
    2.Clean the printhead.
    a.On your computer, open your Kodak AiO Home Center software.
    b.Click on the Help (?) button.
    c.Click on the Maintenance option.
    d.Click on the Clean Printhead option.
    3.Print Demo Page.
    Press Scan and Copy buttons at the same time for 2-3 seconds or until the printer starts printing then release the buttons.
    If issue persists,the printhead on your printer requires replacement. Call 1.800.421.6699
    Thanks.
    Regards,
    Neerak21
    Sep 24, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Won't print after replacing cartridges
    The following text copied from HP website to tackle this problem. minimtop.gif Follow the instructions below to install the print cartridges. NOTE: If you are installing ink cartridges in the unit for the first time, be sure to use only the print cartridges that came with the unit. The ink in these cartridges is specially formulated to mix with the ink in the print head assembly at first-time setup. s.gif Installing the print cartridges minimtop.gif
    1. Verify that the unit is on.
    2. Open the ink cartridge door. Figure 1: Opening the ink cartridge door c00718797.gif
    3. Squeeze the gray tab below an ink cartridge slot to release the gray latch and then lift the latch. Figure 2: Lifting the latch c00721793.gif 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges NOTE: The ink cartridge areas are color-coded for easy reference. From left to right, the ink cartridges are black, yellow, light cyan, cyan, light magenta, and magenta.
    4. Remove the new ink cartridge from its packaging.
    5. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot. NOTE: Make sure that the ink cartridge is inserted into the slot that has the same shaped icon and color as the ink cartridge. The copper-colored contacts should be facing the printer as the ink cartridge is inserted. Figure 3: Inserting an ink cartridge c00721795.gif
    6. Press down on the gray latch until it clicks into place. Figure 4: Closing the gray latch c00721796.gif
    7. Repeat steps 3 through 6 for each ink cartridge that needs to be replaced. NOTE: All six cartridges must be installed. The printer will not work if an ink cartridge is missing.
    8. Close the ink cartridge door. Figure 5: Closing the ink cartridge door c00718798.gif
    s.gif s.gifHave a Good Day
    Jul 17, 2009 | HP Photosmart C4580 All-in-One InkJet...
    Install black cartridge, but will not print
    Lets do it this way. Follow these steps again carefully and try to install the Ink.
    Introduction
    Follow the instructions below to replace the ink cartridges.
    4. Pull the ink cartridge toward you out of its slot to remove it.
    5. Remove the new ink cartridge from its packaging.
    6. Hold the ink cartridge by the handle and then slide the ink cartridge into the empty slot.
    7. Press down on the gray latch until it clicks into place.
    8. Repeat steps 3 through 7 for each ink cartridge that needs to be replaced.
    9. Close the ink cartridge door. Print a test page.
    If after doing this it does'nt work, then i will ask you to unplug the printer cable from the computer and uninstall the printer driver/Software completely.
    Shut down your computer and restart it.
    Re-install the printer driver/software from the start as you did when you bought it.
    Good luck
    Apr 18, 2009 | HP Photosmart C6180 All-In-One InkJet...
    Wont read ink cartidrige
    first try taking out the cartrage and try uninstalling the printer off your computer then reinstalling it. before putting in your cartrage make sure your computer detects it and your computer should tell you that it detcets no ink then try replacing it. if the problem consists make sure youave the right cartgae for that printer. Then check that nothing (paper, pen, anything) is stuck or jamming the computer blocking the cartage sensors,
    Jan 17, 2009 | Epson PictureMate Photo Printer
    2,290 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
