Canon clc 5100 E075 error code
I'm trying to reset the error code. I can get to the diagnostics screen to reset the code with the normal entry, but the function button won't do anything, or any of the others. Do I need to do something different?
    Problem Solver:
  • 6 Answers
E075 error is a HARD error. Im means, it will not reset by turning the machine OFF and ON. The reason for the error is the Black transfer belt is moved too much in one dirrection, causing a fault. the belt will have to be moved to center by hand, then the E075 cde can be cleared in service mode. (function > f-misc-p> screen 2> E075-rls. then shut off.
its best to get a canon tech involved, because there is most likely other problems.
Posted on May 27, 2008
  • 1,326 Answers
Think about this, did it happen after a paper jam was removed? I've seen it when a piece of paper jamed in the connector of the transport unit blocking a sensor (ps19) or a funcation of the unit.Good luck...
Posted on May 15, 2008
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
CLC 5100 error code: E194-0101
Go to Service mode (Function _ Install _ 2nd Screen i.e. 2/4 make img reg 0 Restart machine Again Go to intall press init c aftrer complition press sinitc aftre getting it ready again make img reg to "1"
Jul 19, 2010 | Canon CLC 5100 Copier
Canon CLC 1000 error code E075 - 0004 please help me get rid of it
[Phenomenon]
Error code E075
[Cause]
Because of the factors listed below, some problems may occur in the controls to prevent the transfer belt
shifting to one side due to malfunctions of the swing motor assembly and in such a case error code E075 gets
displayed.
1) Sliding fault of the part A in the Fig.1
2) Deformation of the sheet metal of the swing motor assembly
[Factory measures]
1) The resinous material has been added, as shown in the Fig. 2, to improve sliding.
2) The reinforcing sheet metal has been added, as shown in the Fig. 2, to prevent deformation of the sheet
metal of the swing motor assembly.
When the error code E075 gets displayed, run checks as described in the Service Bulletin CLC1000-005
(CAUSE OF PROBLEMS BROUGHT ABOUT BY ERRORS OF THE TRANSFER BELT
MECHANISM). If the error code E075 still gets displayed even after running the checks, replace the old
swing motor assembly with the new type by, following the instructions on removing the transfer belt swing
motor assembly described on page 4-50 of the Service Manual.
Affected machines
NFH01171 and later
PFH00044 and later
QFH00129 and later
RFH00079 and later
SFH00221 and later
TFH00127 and later
UFH00657 and later
Jun 11, 2010 | Canon CLC 1000 Color Copier
E-840-002
Hello sir; The error code you display it's means " external heat roller sensor damage , replace it.
Aug 15, 2009 | Canon Office Equipment & Supplies
Error Code E075-004 on a clc 1000 I have Re-position the transfer belt but I keep getting this error code and told to turn off and then on but the error keep commin back. I was also told that i had to go...
go to service mode by *2&8 * then you can release the error E075,Asterisk(*) button is in left side of control panel just lift the small cover .hope this will help
Jul 05, 2009 | Canon Office Equipment & Supplies
Canon clc 5100 problem
try a clear server on the Fiery. shut down/re-start
**Warning if u need your job log saved do so before clearing Fiery server.
Mar 09, 2009 | Canon CLC 5100 Copier
310 people viewed this question
k24674
jasbo
jasbo
