My Toshiba e-studio 200 DP-2010 showing Please Wait, then Warming Up and after aprox 30 sec turn off and on. Before that I reseted a C44 error code. Thanks
5 Suggested Answers
  • 43 Answers
SOURCE: toshiba 160 error code
c44 = fuser error
turn copier off
hold down 0 & 8 while turning it on
then wait one min, then press 4 0 0 start
then 0 and set
turn off wait one min then turn on if this does not work it might need parts
Posted on May 08, 2008
  • 643 Answers
For error code C44, it indicates Heater abnormality.
If 1st time occur, u can just go to 08-400, reset the value to "0" then restart the machine.
If happen again, then u need to check the thermistor. Replace it if necessary. If themistor replaced but still happen again, then u need to proceed to check themostat--> heater-->Mainboard-->Switching regulator.
Posted on Mar 09, 2009
M2Tech1
  • 313 Answers
SOURCE: My Toshiba e studio 167 is showing a c44 error
the c44 error is an error in the fuser if you know how to take the fuser out check for toner buld up on the thermistors.. the sensors with the thin strip that presses against the hot roller gets toner build up and cant read temp properly.. you could also try turning machine off and then on whilst pressing 1 3 and * buttons together this might reset it temporarily for you.. Good Luck A
Posted on Jun 30, 2009
goodgold
  • 389 Answers
SOURCE: I have a Toshiba studio 45 with error code c44,
You should apply to service Toshiba.
The Possible faults in lamp of the heating, thermistor, contact of the elements of fuzer or in signal of the controller of the direct current.
C41 Fuser thermistor, or no heat C43 Fuser thermistor problem or other fuser problem, after machine goes into ready C44 Heater problem
Posted on Oct 08, 2009
Toshiba e studio 18 error c43 how to reset
Dear sir i have to problem in Toshiba estudio 18 error c44
and fuser unit check ok but please tell as error reset
Jan 05, 2014 | Office Equipment & Supplies
Error c44 studio
codes c43, c44, c45
problem with the fuser
thermistor review
thermal fuse
check connectors
Dec 05, 2013 | Toshiba e-Studio 35 Copier
Error codes and their meaning for Toshiba e-studio 181 copier
toshiba e-studio 181 is not working. It shows that cover is open symbol and tells the same and the printer is woken up. what to do to rectify it.pls
Apr 27, 2012 | Toshiba e-Studio 232 Black and White...
Call for service error in Toshiba studio 160
Code Description C01 Main motor drive error C04 PFP main motor drive error C06 LCF feed motor error (DP2000/2500 series) C13 Cassette 1 error C14 Cassette 2 error C15 Cassette 3 error C16 Cassette 4 error (DP2000/2500 series) C18 LCF tray error (DP2000/2500 series) C19 LCF feed motor abnormal (DP2000/2500 series) C21 Carriage initialization error C25 Scanner unit watch dog error C26 Exposure lamp disconnection or peak detection error C38 Replaced process unit error C41 Abnormal thermistor or heater disconnection at power ON C43 Warming up mode after disconnection judgment, or abnormal thermistor after ready C44 Warming up mode after disconnection judgment, or heater abnormal after ready C45 Thermistor disconnection at the end part of heater C56 Communication error between PFC and main unit C57 Communication error between main unit and IPC (DP2000/2500 series)
May 22, 2011 | Toshiba E-Studio 160 All-In-One Laser...
I am looking to reset my toshiba studio 163 spanner signal.the machien stoped functioning. i need he reset code.
Hello
Fisrt off please hold down the 8+C buttons together, there will show a error code in the copy quantity display.
Now not knowing what the error code is, i am going to hope that it is C44 that is the most common
error code on the E163 machine. If it is C44 please do the following.
Switch off the machine.
While holding down 0+8 buttons, switch on the machine.
When ad shows on the display, input 400 then press the start button.
If the value is not 0, input 0 button and press the interupt and energy saver buttons to save the change.
Switch off the machine wait awhile and then switch the machine on again.
The problem should be sorted out.
If the error code is not C44 you will have to let us know what the error code is, by holding the8+0 buttons down together.
Here is hoping the machine is working
Regards
Apr 15, 2011 | Toshiba e-Studio163 Copier
Can we refill toshiba e-studio 207 Tonar Cartige ( Cartige No.T-1640D
sir i have Toshiba 207 copier sir now write on screen call for service C44 sir please solve my this problem thanks
Sep 03, 2009 | Toshiba e-Studio 205 Copier
My Toshiba e studio 167 is showing a c44 error code. What should I do?
Jun 30, 2009 | Toshiba E-Studio167 Copier
Toshiba 160 error code
Mar 09, 2009 | Toshiba E-Studio167 Copier
c44 = fuser error
turn copier off
then 0 and set
Mar 31, 2008 | Toshiba e-Studio163 Copier
When the message call for service is displayed
press the C key and the 8 key at the same time
an alpha numeric code will appear eg: C47 etc
Post the error code and I'll tell you what it means
Jan 19, 2008 | Toshiba E-Studio 160 All-In-One Laser...
203 people viewed this question
jasbo
jasbo
