Question about Dishwashers
Hi i have a Beko DE3542FW dishwasher and it is making the washing noise but nothing is happening
SOURCE: Kenmore Ultra Wash Dishwasher - 665 - 13783
dcvxzcxzcxzczxc
Posted on Feb 26, 2008
  • 185 Answers
SOURCE: Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Posted on Mar 28, 2008
SOURCE: BEKO D 2731 FW Dishwasher Problem
yes man,it worked 1st time,cheers for that info.
Posted on Sep 28, 2008
aborcass
  • 2651 Answers
SOURCE: Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Posted on Jan 25, 2009
SOURCE: Brand new beko DE 2542 PW dishwasher won't start wash cycle
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Good Luck.
Posted on May 09, 2010
Good Luck.
May 09, 2010 | Dishwashers
The washing machine belt keeps coming off any ideas why, should it have any stoppers or something to keep it from sliding off thanx . beko wma1512s
Belt would have become expanded after use. Try adjusting the motor base by moving in the direction it tensions the belt. Or replace with the identical belt No. Clean belt resting area free from any old belt rubber deposits /markings.
Apr 16, 2010 | Beko 24 in. D3731F Free-standing...
Beko DWD5410 - noise
The strange noises are of of your hose water. I think your water system is not alright or unit called ciop is damaged.
Mar 27, 2010 | Beko 24 in. D3421F Free-standing...
Brand new dishwasher, doesn't drain water and will not work now!
hi,
try this site
http://www.cookshomeappliance.com/dishwasher_troubeshooting.htm#Constant Noise During Washing or Drying
please rate my suggestion..
Apr 11, 2009 | Beko Dishwashers
My BEKO D3421F dishwasher wont start?
hi there......sounds like the door switch on your apliance has given u...open the door close it firmly lidstening for an audible click as the door switch makes...
regards SirGalahad
Mar 15, 2009 | Beko 24 in. D3421F Free-standing...
Beko DE 2431 FW dishwasher
hi there.....when the machine brings water in...have you cancelled the program reselect a program and checked that it is puming out..if all is ok then you need to check that the main wash pump rotates freely....if all is ok here..then i suspect you have a failed capicator on the wash motor....little white cylinderical component on top of the motor
regards Sir Galahad
Jan 20, 2009 | Beko 24 in. D3421F Free-standing...
Dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens.
Hi mcdoddle,
I'm Harvey the master Plumber.
Your problem is: dishwasher powers up when switched on via control panel. When start is selected, the lights indicate wash but nothing happens. This may sound stupid but first make sure no one turned the water off to the d/w. If OK then you likely have a clogged or failed solanoid valve. The d/w must be removed for replacement. I don't recomend this for the average homeowner. You might consider utilizing our Repair Directory to find a repairman.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 14, 2008 | Beko Dishwashers
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Dishwasher not working
dishwasher dwd 3410 w,it runs normal to the end but doesnt drain the water
Mar 25, 2008 | Beko 24 in. D3421F Free-standing...
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
Owen Barnes
