Question about LG Flatron L1715S 17" LCD Monitor
When i boot up the screen lights up for aa few seconds then go's off
  • 732 Answers
Dbartholo630, Your CCFL back-lit lcd monitor no different than any other brand in it's basic use of technology, design, and operation!! Your 5 to 7 year old unit needs work (repair/refurbishment) of it's power supply. Yes, it could have swollen, leaky electrolytic filter capacitors on the switch mode power supply that will need replacing with new one's to get it up and running again???? Read fixya "profiles" and "testimonials" of the following fixya tech's: "budmrtn" "buddymc" "12fixlouie".
Only you will determine if you will DIY fix or just trade in for new wide screen unit. Hope this was of some use to you. 12fixlouie
Posted on Sep 07, 2010
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
My AOC screen goes black after about a few seconds after booting.
The picture board on your monitor is bad, since it goes off after few seconds and the power led or button is on, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer or service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Jul 26, 2010 | AOC LM729 17" LCD Monitor
PC boots for seconds then NOTHING APPEARS SCREEN
Check to see if you have inadvertently hit the CRT button which turns off your screen to turn on an externally connected screen even if there is no external screen plugged in. OR you could have a bad (Back-light) or (Inverter)
Jan 27, 2010 | LG Flatron L1750S 17" LCD Monitor
Green Vertical Lines across screen- Sansung HLR5067WAX/AA
Hi, your are experiencing the first stages of a light engine burn out. it will fail soon. i recommend replacing the light engine asap.
Samsung Part Number: BP96-00822F---$895.00
May 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Dell 1501 powering up but not boot screen and after a few second
Are u able to get into the bios setup.....if so try to boot it in safemode...
if u arn't able to enter bios setup...then motherboard has to be replaced..
Mar 18, 2009 | Dell Inspiron 1525 Notebook
My hp laptop will not boot up
Check the power supply for power. Replace if necessary. Also check the motherboard for proper operation. If no fans come on or only come on for a few seconds then you have a bad motherboard
Feb 14, 2009 | Computers & Internet
Brake lights problem
check the wiring in the boot ...open youer boot look at pass side you will see the wiring loom covered in a plastic case break into this to get to the wires and give the wires a pull my bet you have a few broken wires causing you all sorts of problems re join wires check fuses and cover wires in tape after repair should sort problem out
Feb 01, 2009 | 1996 BMW 318
Booting
Has the fan been replaced? If not then the laptop will power itself off to protect from overheating. The fan is like a switch in the loop. Like old Xmas lights. One not working then none will work.
Aug 30, 2008 | Gateway M305CRV Notebook
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
Aug 28, 2008 | Canon PowerShot A400 Digital Camera
Monitor is on when computer boots up , then turns off
You can email rhartze@key-services.com and provide your telephone number... he will call you to assist.
Dec 13, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
LG Flatron L1715S 17" LCD Monitor Logo
47 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
