Question about Viking Dishwashers
I don't know how to start the dish washer. I turn it on and set a program and hit start and the light blinks but nothing happens.
  • Viking Master
  • 19,396 Answers
Hi.
The cycle is started simply by pressing start button when the light is on and steady, then closing the door. If Start is not on, then there is a problem. In that case check baset positions, water inlet and ensure that the door latch is clicking.
Here procedure :
1. Load the dishes per recommended loading.
2. Make sure there is rinse agent in the dispenser . Add rinse
agent if needed.
3. Add proper amount of detergent and pre-wash.
4. Push both top and bottom racks in.
5. Select the desired cycle and option(s).
6. Press “START”. The “START” symbol will illuminate to
ndicate the unit is ready.
7. Close the door tightly until you hear a click. Otherwise, the dishwasher will not start.
If you need the manual for your specific model, click here , scroll down and download the manual
Posted on Sep 07, 2010
Fisher and Paykel smart drive 708 will not start
unplug the washer and wait 10 or 15 mins sometimes it takes time to reset the program
Aug 23, 2009 | Washing Machines
Malber Dryer won't start (sine-wave light flashing)
The dryer is easy: turn it on and turn the control to 0. It will beep. Then turn it to the desired program (20, 40, 60 minutes or a pre-programmed cycle), it will beep again and start. If there's a red light you have to empty the water tank at the front on the left. The washer is a normal washer. Just pick your program and press start (be patient as it takes a while to get cranking). Sometimes you have to really push the door closed very hard. Try and turn the control to 12 o'clock before setting it again.
May 30, 2009 | Malber TD800 Electric Dryer
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Lights on the Asko D1996 keep blinking
This depends on the blinking pattern. Of the eight lights on the panel, if the four on the left blink on and then the right four lights blink on as the left ones go off, and keep blinking back and forth, that just means the mode has been set and the Start button pressed. After closing the door it should just continue on wherever it is in the cycle. (This is normal operation).
If you hold down the Start button, this resets the dishwasher. If you then close the door, nothing will happen because it thinks it's done.
If the lights are blinking in a different pattern, such as they all blink on and off in unison, that indicates an error condition and needs to be diagnosed. If the pump is not running constantly, then at least it's not because water is leaking out somewhere.
Sep 23, 2008 | Asko D1996SS Built-in Dishwasher
Blinking red lights and no washer operation
Dave, glad I could help, I'll mark this one as solved.
Jun 12, 2008 | Kenmore 4292x Front Load Washer
Blinking standby light and nothing else...
When Sony TVs detect a problem, they shutdown and present a blink code. The blinking should be a repeated count. Please report that count here as that indicates the circuit in which the problem was detected.
Thanks,
Dan
May 20, 2008 | Sony KP-46V35 TV
Equator EZ 2512 CEE Front Load dryer not starting
The blinks are the fault code on the unit you will have to watch them an count match them to the chart in the service manual
Here is a link to the service manual
http://www.appliancedesk.com/appliancedesk/service/CWD/EZ3612CEE_EZ2512CEE_EZ1612V/Service_Manual.pdf
Feb 20, 2008 | Equator EZ 2512 CEE Front Load Washer /...
Blue screen and shut off by self
You will need to reset the Netcommand and tuner settings in the set. The little indented button in the front of the set needs to be pushed in (when the set is off). The front light will blink for about a minute or minute and a half. Then, reprogram the Netcommand settings. This should solve your problem. If you need more information, then, reply to this post and I will respond.
Sep 23, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Dishwashers Logo
228 people viewed this question
Top Viking Dishwashers Experts
bandman1967
bandman1967
Level 1 Expert
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
