Question about HP DeskJet 9800 InkJet Printer
Where can i the hp 9800 ink socket flex cable to purchase ?
Pin damage flex cable while try to install black ink ......
  • 3 Answers
Are you asking this because when you tried to place your ink cartridged you broke the cable with a metal part in the printer?
I just had the same problem... I need to replace that cable. I dont' even know how t otake this thing apart yet!
please reply to NGR7000@hotmail.com
let mek now if you have the same problem. I think we can call HP and tell them about this problem. maybe get some resolution.
Rafael
Posted on Sep 27, 2008
Large ink spill. Printer no longer recognized new black cartridge.
You can perform the Tap 41 Cartridge Health Diagnostics Test: [applies to HP Deskjet 6800/6900/9800]
http://inkjet411.com/?page_id=1741 (refer to 2nd video to understand how to read the printed pattern)
1. With printer power on, press and hold the POWER button.
2. Press the Cancel (X) button four (4) times.
3. Press the RESUME button (Down Arrow) once.
4. Release the POWER button.
5. The Diagnostic Test Report should print.
--- A good HP 93/95/97/99 color cartridge should display 600 good nozzles, while a good HP 92/94/96/98 black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout: http://inkjet411.com/?page_id=1741
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink (special "ink back-up mode").
For information on North American ink refill services at a major retailer near you (should you wish to save ~50% on ink costs), general printing problem resolutions or advanced HP printer diagnosis procedures (advanced cartridge diagnostic tests/cartridge error bypass & printer reset methods, etc.), please visit Inkjet411: http://www.inkjet411.com
Aug 27, 2013 | HP Deskjet 6988 Inkjet Printer - Color -...
Black is printing gray
Has your printer defaulted to 'draft' printing? That's where grey printing seems to come from.
Feb 20, 2010 | HP DeskJet 9800 InkJet Printer
Ink cartridge problem( s) appear to be missing or damaged
hi there,
Ink cartridge Problem
Cause : The indicated ink cartridge(s) are missing or are damaged.
Solution : Replace the indicated ink cartridge(s) immediately so that you can resume printing. If there are no ink cartridges missing from the HP All-in-one, the ink cartridge contacts might need to be cleaned.
IF there is no ink cartridge missing from the HP All-in-One, and you still receive this message after cleaning the ink cartridge contacts, you might have a damaged ink cartridge. Replace the ink cartridge.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Nov 26, 2009 | HP Photosmart C6280 Printer
My hp 9800 printer isn't recognizing the 99 ink cartridge thus will not print
Are you using a factory new ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
Oct 27, 2009 | HP DeskJet 9800 InkJet Printer
HP Deskjet 9800 Printer does not recognizes the cartridge and red light blinks even when the HP 97 (right cartridge) is installed. I have cleaned the contact area with Swab/alcohol but still it does not...
Take out the cartridge and examine the wire ribbon in the cartridge assembly. Many HP DeskJet 9800 users reported the ribbons getting damaged/punctured while installing or removing ink cartridges.
If that's the case your solution is to order part #C8165-67061 (google it) and install the entire assembly yourself. Be prepared that these items are delicate and some common sense is required.
You can also take the printer in for service to your local "big-box-electronic" store. This might not be cost effective so make sure you do your homework.
Jul 21, 2009 | HP DeskJet 9800 InkJet Printer
Can I turn off the ink counter on 9800?
Why would you want to turn off the counter? Doing so would allow you to run the machine completely dry resulting in major print head damage?
You cannot turn off the counter, but you can purchase a chip resetter.
Hope this is helpfull
Mar 05, 2009 | Epson Stylus Pro 9800 InkJet Printer
Hp deskjet 9800
i had the same problem -- this is what finally worked for me. turn the printer off, wait several seconds, then turn it back on. when i first turn it on, the ink lights and the resume lights blink a few times. as soon as that stops, before the ink cradle or any other parts move, lift the lid. the black piece in front of the ink cartridges will drop down so that the cartridges can be changed.
Apr 01, 2008 | HP DeskJet 9800 InkJet Printer
Black ink stall damage
The ink cartridges sit inside this area made up of three (3) light grey plastic "walls". The middle "wall" has a spring on it that is held onto the wall by a little molded *** that is part of the plastic mold. This *** breaks and the color ink cartridge will not sit in there correctly.
agrebe@sbcglobal.net
You could use epoxy.
Drill small hole and cable tying the wire in place.
If the spring has ripped a hole in the printhead contacts, then you will not be able to fix it.
Mar 13, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Ink replacement has not helped print
Sounds like a damaged or dirty flex cable to the print heads. If those tiny contacts go bad, nothing will print properly. Check the cartridge and socket area for any dirt or dis-coloration. The connections can be cleaned with contact cleaner (from radio shack), and then dried with isopropl alcohol (use the purest you can find).
Jan 03, 2008 | Lexmark X1240 All-In-One InkJet Printer
HP DeskJet 9800 InkJet Printer Logo
94 people viewed this question
Ben Johnson
