Question about Whirlpool Washing Machines
I have purchased a whirlpool washing machine on 07/09/2009. i am getting f2 error on my display
  • 15,935 Answers
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 07, 2010
Why is it blinking f2?
Whirlpool
F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
Press, PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
(1) Check the drain hose and make sure it is not plugged or kinked.
(2) Check the electrical connections at the pump and make sure the pump is running.
(3) Check the drain pump filter for foreign objects.
If the above does not correct the problem replace the pump.
Jan 23, 2016 | Washing Machines
Sud light comes on and f 2 and it don't spin
Hello there and thank you fixya
Whirlpool F2 = Long Drain error code.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the "F2 error code" will be displayed.
Potential Causes:
Please post me back if you need any further assistance in inspecting the pump or replacing the pump
Also if you would please give this solution a rating it helps our customers get the best possiable service ok?
Best regards Michael
Jan 26, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F2 error code
Hello there
First please verify this is a f2 and not a fo2 error
they mean almost the same thing i have it listed below
F/02 Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump
Nov 19, 2010 | Whirlpool Washing Machines
The washer is giving a code of "F2" & not draining properly.. any idea?
This code indicates a pump issue. First, remove and clean the filter. Then you need to check out the pump.
Potential Causes:
Mar 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It keeps F2 me or saying suds I can't remember
F/02 Long Drain
  • If the above does not correct the problem, replace the pump.
Jan 03, 2010 | Whirlpool Washing Machines
Washer giving F2 error during wash cycle, cycle doesnt finish
HI. this code represents a Long Drain issue.
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• If the above does not correct the problem replace the pump
Oct 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Started getting an F2 error code
I looked up the F02 code online and this is what it says:
Potential Causes
Hope that helps.
May 18, 2009 | Whirlpool GHW9400 Duet Washer
F2 is flashing, still in wash cycle
F02 Long Drain If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Potential Causes
Apr 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We get an F2 error and the machine shuts off.
to long to drain,,,press pause/cancel twice..that should it ...happy new year
Jan 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
23 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
