Question about Tally T2245 Matrix Printer
I have a Hardware Alarm 008000000 +0018 display on a Tally T2245 printer. What's causing this and what's the solution. Thanks, Peter Taylor
  • 114 Answers
SOURCE: Tally t2155 - Showing "Hardware alarm wrong board"
change the logic board. your problem will solve.
Posted on Jan 31, 2009
  • 114 Answers
SOURCE: Tally sprint pro
Please tell me the hardware alarm number . The number will display onthe control pannel LCD of your printer. Then only I can help you.
  • 114 Answers
SOURCE: Tally T2250 showing an error..
If you are using re-fill ribbon then the problem may arise , if you are using original then clean the encoder strip with isopropile if not solved change the encoder strip .
Posted on Feb 01, 2009
SOURCE: tally printer hardware alarm home postion
There is a broken gear(s) in its mechanism that's why you are having this hardware alarm message.
Posted on May 25, 2009
  • 169 Answers
SOURCE: THS Error on warrantee printer tally serial printer
The print head operating temperature may need to be calibrated for the operating environment of the printer.
The print head cable may be damaged or incorrectly plugged into the print head or logic board.
The print head may have a fault.
There may be a fault on the logic board or interconnect board
The first thing that I would recommend doing would be to calibrate the print head operating temperature, this can be done in the following way;
·Start with the printer powered OFF and at normal room temperature
·Hold down the ONLINE and SETUP button and power the printer back on
·Keep the ONLINE and SETUP button held down until the display reads ‘PRINT TEMP. CAL’ along the top line
·Press the button under ‘TEMP CAL’ (button 3)
·Using buttons 2 or 3 change the Temp Setting to match the temperature of the room the printer is used in (change this value by at least 1 degree even if it is correct to force the printer into recalibrating.
·Then press SET to save the settings.
Once the Temperature has been recalibrated power the printer OFF and back on again, this should resolve the problem.
If once the print head temperature has been calibrated the printer displays ‘Head Hot’ or alternatively displays a ‘THS’ error this indicates the printer has a hardware fault. The next step would be to identify which part may be causing the problem.
I would recommend first checking the carriage cable to ensure this is not damaged and makes good contact at each end. Then you would need to look at a logic board or print head failure.
Posted on Oct 01, 2009
I need Tally T9312 driver for Windows 7
Unfortunately I think the most current driver for the T2245 is here:
http://www.tally.com/search.aspx?searchtext=T2245
Your could also try (most current version is stated to be 5.1.2600.2180) :
http://www.howtodrivers.com/model11272.html
Tally T9312 driver can be found here:
http://www.howtodrivers.com/model12135.html
I hope this is helpful. :)
Dec 08, 2010 | Tally T2245 Matrix Printer
I forgot my tally username & password how
Please Send your Data folder To my Email:tallysupport@ovi.com, ramukumar006@yahoo.com
I Will get the Password With in 5Min By Mail back
Thanks & Regards
Sreram Computer Solutions
Nov 13, 2009 | Tally T2245 Matrix Printer
I have a Tally T2245 with load error. ASF-R
Sounds like the paper path has been changed I guess you are using the front Tractor (tractor 1) to load continuose paper.
You need to go into the menu and change the paper path back to Tractor 1.
Disconnect the pritner from the computer system, and power the printer off and back on again to clear the buffer.
  • Take the printer off-line by pressing the Online key
  • Press the Setup key
  • Press the key under "Paperway" in the display
  • Select Tractor 1 (or Tractor 2 if fitted/required)
  • Press the key under "Set"
  • This should change the paper way back to Tractor 1
    Jun 23, 2009 | Tally T2245 Matrix Printer
    when power on the printer the printer coming leftside and showing hardware alarm
    check ribbon
    +0306ne -007 000
    000000128 +0304
    error in display. how to rectifie the problem
    Jan 29, 2009 | Tally T2250 Matrix Printer
    Tally sprint pro
    Aug 26, 2008 | Tally Matrix T2280 Printer
    Printer problem
    the problem comming from FAW sensor. your FAW sensor may damaged or it is not in proper place.
    Aug 04, 2008 | Tally T2245 Matrix Printer
    Tally 2250 Matrix printer
    tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
    Jul 21, 2008 | Tally T2250 Matrix Printer
    Offline park eject error
    The problem comming from FAW sensor , adjust the FAW sensor. Check gears ,if it broken change it.
    Feb 14, 2007 | Tally T2245 Matrix Printer
    Tally T2245 Matrix Printer Logo
    67 people viewed this question
    Top Tally Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Tony
    Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
