Question about 2wire (1000-000057-000) Modem
2wire gateway I think I have a power source problem. I now have two 2wire modems that have the same problem. All of the ethernet lights, the power light, and the wireless light stay on but the dsl and internet do not. I have unplugged, reset, and banged my head on the desk. Any suggestions?
Definitely the power cords!! I had the same problem with all of my three 2Wire modems, and as soon as I replaced the power adapters with the generic ones I purchased from Radio Shack, the problem solved.
Posted on Nov 29, 2009
The modem is a Gateway 2Wire model 2701HG-D. Its function is to handle the high frequency data carrier that rides on top of your ordinary telephone wires to provide internet access. It has four ethernet ports and one USB port in addition to the telephone connector. QWest has said there have been problems with it and they recommend that you purchase a newer model for $100.
Ours failed yesterday with a bunch of green lamps glowing steadily without the normal blinking. The lady was about to go downtown to purchase a replacement when I figured out how to open the box with its four springy plastic bending tabs that you can see looking through the cooling apertures.
What I found was an internal operating voltage of about 4 volts which was well below the 5.1V printed on the power brick. When I ran the modem from a laboratory grade 5 volt source it seemed to work drawing about 1 ampere without any connection to the phone line.
Measuring the 5 volt supply that came with the modem I saw 5.2 volts but when loading it to 100 milliamps or so it dropped to 4 volts. It was definitely out of spec. Replacing the brick with another brand rated at 5 volts, 2.2 amperes solved the whole problem.
A failing power supply usually turns itself off but in this case measuring its output with a voltmeter would result in a conclusion that it was OK. Not so. You have to measure it under load which is a bit harder to do.
So. . . Don't rush to buy that new modem the way QWest says. Consider a replacement power brick. Positive 5 volts on the center of the connector with 2 amp capability. The original power converter used a three pin grounding plug for the AC source and the ground was connected to the negative side of the DC output. That's not normally done and does not seem to be necessary. It would make more sense to connect to the telephone company ground but that wire may not be available in the 6 pin telco socket.
Part numbers on the failed power brick
P/N 1000-500031-000
Part No GPUSW0512000GD1S
Input 100-120Vc.a 50/60Hz 0,15A
Output 5.1V DC 2A
Class 2 Power Unit
Made in China
And. . . after cracking the shell of the power brick the input aluminum electrolytic capacitor showed typical deformation of the round aluminum end. That kind of failure is very much a part of my life these days. Sigh.
Posted on Jul 18, 2009
I had the same problem and it turned out to be the power adapter. I thought this was too simple but I went to Radio Shack and bought a new one and everything has worked perfect since.
Posted on Jun 22, 2008
AT&T doesn't sell just the 2wire power cord. They charged me $60 for a new 2 wire modem. When I received it I took out the power cord and connected it to my old 2wire and it works fine. If your power led on your modem is red it could just need a power cord.
Posted on Oct 02, 2009
  • 4 Answers
I don't see how this can be a power supply failure. It's more likely something in the modem. I had the same problem with my AT&T provided 2Wire Gateway (actually not provided... I paid $100.00 for it :( ). I bought a replacement unit at Best Buy and haven't had any problems since.
http://www.bestbuy.com/site/olspage.jsp?skuId=8661655&st=actiontec&lp=10&type=product&cp=1&id=1198888971179
One other possiblity is that with the devices you purchase from AT&T, they can remotely control / access the unit. Not sure what they're tracking, but I know that I like my privacy :) . With this unit they can't access it at all... and the speeds / performance are excellent.
Posted on Oct 13, 2008
    Master:
  • 2wire Master
  • 543 Answers
Fairly EASY solution! See eBay: 391663683701
This is a 5 Volt 3 Amp supply for $7 including shipping!
3 Amps assures more than enough current from the supply... so it won't be overloaded.
WORST case is the NEW connector may not fit? If it's a no-fit cut BOTH connectors off and "carefully" strip the wires. Use a METER (or ?) and BE SURE your connections gives you +5 VOLTS to the CENTER pin!
SOLDER your connections and tape well. Now TEST your routers for proper operation... just to be safe, RESET your routers too.
NEW SUPPLY SPECS:
Output: DC 5V 3A (3000mA)Input Voltage: 100~240VAC 50/60HzDC Connector:5.5x2.5mmCable length: 110 cmInside positive " + " , Outside negative " - "Brand New Ac Power Adapter Charger
ORIGINAL supply specs (I THINK)
OEM 2wire AC Power Supply Adapter Modem
ACWS011C-05U
2701HG-B 2700HG-B 1701HG
Model number ACWS011C-05U
Part number 1000-500031-000
5.1V 2.2A
4.1mm outer diameter connector
1.7mm Inner diameter connector
Posted on May 15, 2017
2701HG-B Power Supply REPAIR! P/N GPUSW0512000GD1S THIS FIX WORKS (at least it did for me)!
As more of these great modems age, I suspect more people will experience this same POWER SUPPLY failure.
And who knows what other random modem problems will manifest as the voltage sags as the power supply capacitors age? In my case the Modem would not power-up at all.
A rubber mallet quickly opened the power supply with ease and I could see that one of my caps vented ~ or bulged out of the top...
I replaced BOTH caps and I am back ONLINE!
* Here is what I did... taking note of the polarity first, I carefully CRUSHED the two caps and that left me with two 'posts', still soldered to the supply board. The posts made installation of the new caps SO easy.
This method works great for other cap/component repairs too and many times saves pulling the entire board from a chassis!
* I measured the output and there was a solid 5.2 VDC, but without a load.
* Under load the voltage dropped to 2.4 VDC!
* As long as I was in the supply I replaced BOTH caps.
* The caps are 1000uF 16VDC caps and again, the 'crush' method worked out quite well.
A hot glue gun worked great for replacing the cover on the supply. I suppose DAP would work well too.
I hope this helps you and I remain...
SOGLAD
Posted on Dec 24, 2010
  • 4 Answers
If the power light stays on and the ethernet light stays on, to me it means that there is power supply to your modem and your ethernet light has connections from the modem to the PC. If both 2 wire modems is plugged simultaneously to one Broadband socket, maybe only 1 modem may receive the DSL signal because for 1 broadband line, only 1 digital signal to a modem is allowed, th modem who gets the DSL dynamic signal from singtel may get the internet access and the other 2 wire modem will not get any DSL light and Internet light at all.
Posted on Jul 23, 2008
  • Thoo Wai Kiat
    Thoo Wai Kiat Jul 23, 2008
    If both 2 wire modems are connected simultaneously to a hub and the hub is plugged into the wall socket, it i obvious that bothe modems will not get a DSL signal and will never get the internet light,due to 2 modems asking the router for a digital signal, and the router may be confuse on which modem to assign,due to multiplexing of digital signal that cannot be divided into 2 parts.
  • Thoo Wai Kiat
    If one modem is connected to the wall socket and the DSL light has no signal or blinking, contact the ISP technical helpdesk, may be 7 reasons
    1) Check if the wire from the wall socket to the modem is
    properly connected and at the right Internet line socket, not
    the telephone socket or the ethernet 1,2,3,4 socket
    2) Modem reset needed
    3) Broadband late payment, service temporary suspended
    4) Broadband digital line issues due to rennovations and
    earthworks or other reasons
    5) Account deactivated or Broadband contract ended
    6) Power adapter not compatible with the modem
    7) Modem faulty, if other modems have the DSL signal and only
    this modem fails to get the DSL signal
    8) Multiple connections devices connected on multiple sockets
    sharing and no enough voltage to run the internet/dsl after
    the voltage division maths
Power supply replacement
Posted on May 15, 2008
Need detailed help setting up my 2wire 1701hg gateway. I have high speed att dsl internet. I tryed already but att redirects me to there website, I tried calling them but they keep trying to charge mt 49$...
I can help you to configure the modem... Before that i need answers for certain questions....
How many lights are litup in your modem...? Do u have the light called "Internet and DSL" lit up in your modem ? Do you know the connection type ??? PPPoE If so do u know what is the Username and password ??
May 23, 2011 | 2wire (1000-100052-000) 802.11g/b Wireless...
Cannot connect to web.
Follow this steps
1. Connect the provided power adapter from the gateway's POWER port to an electrical outlet. The POWER light on the front of the gateway should be green. 2. Connect the provided gray phone cable from the gateway's PHONE LINE port to the DSL filter jack labeled DSL/HPNA. 3. Connect the yellow Ethernet cable provided with the gateway from the LOCAL ETHERNET port on the gateway to your computer's Ethernet port
With your computer completely started, verify the POWER and ETHERNET indicator lights on the front of the 2Wire gateway are green. If they are not, see "Understanding the Indicator Lights" on page 15. The INTERNET indicator light will not turn green until the gateway software has been installed and an Internet connection has been established.
Mar 22, 2011 | 2wire Computers & Internet
I have moved to new home. I am using 2wire wifi
you can check if the ethercable is loose or if you have a spare ethernet cable (rj45) you can replace the one that youre using
Jul 14, 2010 | 2wire Wireless-G 802.11g ADSL Gateway
My 2wire has the power light red and the ethernet green and th wireless solid green and the dsl off and the internet off....what can i do
I had the same problem on the Gateway 2701HG-B supplied from ATT for use with their DSL service. From searching the web, I learned these variety of modems apparently have an expiration date on the power cord at about 18 mos to 2 years. Mine is almost exactly at 2 yrs.
I replaced the power cord and now it works fine. You can order the OEM replacement from att e-store or try Radio Shack for a universal cord.
May 20, 2010 | 2wire (1000-000057-000) Modem
RED POWER LIGHT ON 2WIRE 2701HG-B
Red power light on the 2wire wireless gateway indicates a device failure. Replace the gateway..
Jul 10, 2009 | 2wire (1000-000057-000) Modem
1 modem connected to 2 computers
Wireless is not the best thing to do heavy online gamming with. He he wants to keep a solid connection wile playing, ethernet is the way to go.
Feb 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
Installation problem
YES!!!!! IT DOES NOT HAVE TO BE A SPECIFIC ETHERNET CORD TRY A REGULAR ONE OUT FIRST IF IT DOES NOT WORK IT WON'T SCREW ANYTHING UP IT WILL STILL BE WORKING JUST FINE SO JUST TRY A REGULAR ETHERNET CORD
Dec 14, 2008 | 2wire Wireless-G 802.11g ADSL Gateway
1800hg 2wire modem problem!
try to use another power adapter with the similar power output aside from what came with your 2wire modem if you have one, if it works fine that means the original power adapter is busted and i think it is also covered by the warranty, get a replacement from the store where you purchased it.
oh by the way, it's normal for all of the lights on your modem or router to blink when you initially power on the hardware, usually your hardware will perform a system check for several seconds to verify if there is any problem after that, several lights if not one should remain steady like the power light, the other lights on the other hand like the ethernet(LAN) or the wireless(WLAN) will most likely flicker from now and then because it indicates activity between the modem and the device/s attach to it.
Hope that answer your concern about your 2wire modem.
May 09, 2008 | 2wire HomePortal® 1800HW Router...
My 2Wire Gateway modem died
don't even try. the components are far too small. go to pacific geeks dot com and buy a new modem. I got one there for $4.50.
Jan 22, 2008 | 2wire HomePortal 100 Network Adapter
Lost Ethernet and Wireless Connections in Modem
I've not used one of these 2wire boxes before, but I believe the default router's address is 192.168.0.1. Try this instead of gateway.2wire.net to see if you can gain access to the router. This is just the starting point, but see if it works.
Here's a link to, what I believe is, the router's manual.
Before you rate this please let me try to help some more. This could be a multi step process...
Dec 29, 2007 | 2wire HomePortal 1000HW DSL Modem and...
2wire (1000-000057-000) Modem Logo
3,476 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
