Question about JBL PSW-D110 Speaker
Can we use the subwoofer as an amplifier for speakers? it has jacks for speaker in/out, but i can't figure out how to make it work because the speakers have no sound.
  • 8,215 Answers
I don't believe this hookup is amplified; but, if you have used the regular unfiltered speaker connections from your receiver/amplifier to hookup the subwoofer, the system will pass the signal thru the outputs subject to the crossover adjustment on the back panel. You cannot get the full signal if your system is sending only the bass signal to the subwoofer. I have copied the instructions below from the manual. You would set the high freq crossover to the low end of your satellite's frequency range. The full manual is here: http://www.jbl.com/EN-US/Products/Pages/ProductSupportDetails.aspx?PID=PSW-D110
High-Pass Control
• If you hooked up your subwoofer
as shown in Hookup
3 on page 4, you also have
the capability of adjusting
the high-pass frequency.
The High-Pass control
determines the frequency at
which the main speakers
will start reproducing
sounds. If your main speakers
can comfortably reproduce
some low-frequency
sounds, also set this control
to a lower frequency
setting, between 50Hz –
100Hz. This will concentrate
the subwoofer’s
efforts to the ultradeep
bass sounds, while your
main speakers continue to
reproduce the mid-bass
information. If you are
using smaller bookshelf
speakers that do not extend
to the lower bass frequencies,
set the high-pass crossover
control to a higher setting,
between 125Hz – 180Hz.
With this setting, your main
speakers will not have the
burden of reproducing any
low-frequency sounds.
as shown in Hookup
1 on page 3, the high-pass
frequency is fixed at 180Hz.
as shown in Hookup
2 on page 4, there is no
high-pass control. Unless
incorporates a high-pass
crossover, your main speakers
will continue to get a
full-range signal.
Final adjustment and blending
of the low-pass and high-pass
controls may evolve over several
listening sessions. A good
starting point would be to set
both the low- and high-pass
controls to the same frequency
and adjust from that point.
Posted on Sep 07, 2010
How should i connect my subwoofer- is it directly to the speakers or amplifier?t
I'm assuming that you are using a standard amplifier with L and R speaker outputs if a stereo Amp.... or L and R and SUB standard RCA output jacks. If it is a more complicated setup, having surround sound speaker jacks, then look for a SUB OUT jack or plug.
Some Subwoofers are self-powered, having their own, built in amplifier especially designed for that model. Sometimes they require a SUB connection and a power supply to the 110V AC house power too. These sometimes need a connection to a standard 3.5 mm HEADPHONE jack output plug. If it's this type, then the front of your amplifier could have one. Either way, the musical signal from amplifier to the subwoofer must be available on your Amp AND be received by the type of subwoofer you are using.
Mar 04, 2015 | Audio Players & Recorders
HI, I am trying to connect my cerwin vega xd3's to my pc (which works fine) and my Samsung LCD TV. I am not getting any sound out of them with the TV on. I have replaced the rca jacks and still...
The "audio jacks" on the rear of your Samsung TV are intended to connect TV audio to an amplifier. Your CV XD3s should be connected to the amplifier output.
Aug 10, 2013 | Cerwin Vega LW10 Subwoofer
Conncet a sony sub to a denon reciver
Depending on the model, there are two ways to connect a subwoofer to an amplifier, receiver or processor. The best way is to connect the subwoofer to the SUB OUT or LFE output of a receiver, but some subwoofers can be connected to the speaker level outputs of the receiver or amplifier.
1. How to Connect a Subwoofer to the Subwoofer Output
The preferred method of connecting a subwoofer is through the LFE or Subwoofer output (SUB OUT) of a receiver. Almost all home theater receivers (or processors) and some stereo receivers have a subwoofer output. The LFE (Low Frequency Effects) is a special output for subwoofers and is often labeled 'SUBWOOFER' not LFE. 5.1 channel programs on DVD discs have a dedicated .1 channel output with bass-only content that is best reproduced by a subwoofer. Connect the output of the LFE or Subwoofer jack to the Line In jacks of the subwoofer using a single RCA cable (the two jacks on the left in the photo). A 'Y-Cable' may be necessary to connect the LFE output to both the left and right channels of the subwoofer.
2. How to Connect a Subwoofer to Speaker Level Outputs
Some receivers and amplifiers do not have an LFE or Subwoofer output. In this case you can use the speaker outputs of the receiver to connect the subwoofer. Using speaker wire, connect the left and right channel speaker outputs of the receiver to the left and right channel speaker level inputs on the subwoofer (the speaker inputs on the right side of the photo). Using speaker wire, connect the left and right channel speaker outputs on the back of the subwoofer to the left and right channel front speakers.
Hope it helped..
Apr 20, 2011 | Denon Audio Players & Recorders
Receiver cannot recognize subwoofer
As I implied earlier, take a clue from the physical style of connectors for both parts of the subwoofer function in the old and new receivers:
RCA connections are for Line Level signal between components only.
The input (bare wire) at the speaker is for AMPLIFIED signal.
You can't just modify one to fit the other and expect magic to happen. Be glad you didn't do it the other way around and modify an amplified (speaker level) outout into a Line Level input. You likely would have smoked that component.
Your subwoofer is a passive speaker, that is, like any other speaker it needs an amplifier. Many subs are self-powered (amp built-in) and they would mate well with the RCA sub output of the receiver.
Get yourself an Active (self-amplified) Subwoofer and run UN-MODIFIED RCA cables to it, according to its instructions, from the Sub Out of the receiver. Or get an amplifier between your receiver and the sub you have.
Feb 21, 2010 | Pioneer VSX-D607S Receiver
Subwoofer trouble
does your deck have a sub control on it sub on or sub off are your rca jacks plug in to the right one are your rca cables in good shape speaker wires hooked up properlly amp is set on low pass filter
Jul 06, 2009 | Car Audio & Video
HOW DO I PLUG UP THE SUBWOOFER TO AMPLIFIER
On the back of the amp, there should be a jack with the name "SUBWOOFER PRE OUT". It is a standard RCA jack, but it only puts out a line output, meaning only self-powered subwoofers will work with it. Usually, if the subwoofer does not have an amp, it will have 2 imputs and 2 outputs. You plug the two left and right inputs into the front speaker jack on the amp, and then plug the front speakers into the left and right amp on the subwoofer.
Jun 17, 2009 | Audio Players & Recorders
Speakers are connected to pre-amp or power-amp? pls explain connections , what connects with what , between cd player + pre amp + power amp + speakers.
Do this, CD audio out jacks to the PRE-AMP INPUT jacks, then PRE-AMP OUT jacks to AMPLIFIER INPUTS then from AMPLIFIER to speakers, This will work similiar with any sound source unit ie. Radio Tuner, Tape deck, etc. Just think of it this way, a PRE-AMP is BEFORE the AMPLIFIER, all the AMPLIFIER is going to do is AMPLIFY the sound to your speakers, HOPE THIS HELPS!
Feb 03, 2009 | Audio Players & Recorders
Speaker wire for subwoofer
Usually, a subwoofer will have its own built-in power amplifier. Thus, it will be designed to plug into a standard RCA jack (the type used for DVD players, etc). rather than having wires to connect to a speaker terminal block. Look for a jack on the back of the receiver called "Subwoofer", or simply "SW". If your subwoofer has 2 single wires, it WON'T work with your reveiver's subwoofer output, as this output only carries a line-level signal and is not amplified. You would need a separate power amplifier for this type of SW. If your SW speaker has a DVD-type plug, it should work fine with the receiver's SW output jack.
Jan 02, 2009 | JVC RX-554V Receiver
I speakers to my laptop
You need an amplifier between Laptop/PC jack to drive the high power speakers/subwoofers. Or buy the special system like Logitech's Speaker system (speakers-subwoofer) that has a built in amplifier already designed for PCs/Laptops. Radio shack has amplifiers of various inputs and power levels.
May 23, 2008 | Computers & Internet
JBL PSW-D110 Speaker Logo
417 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
