Question about Olympus Cameras
I have olympus epl 1 camera, when i dump my photograph from camera to computer after then my camera show writing protect so i can't oppreate my camera. please help me
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 07, 2010
Olympus T-100, write protect shows on the screen & won't operate ??
Look at your memory card. SD/SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Sep 09, 2012 | Cameras
My Olympus T-100 camera is showing writing protect card full and wont let me erase
can mean that the memory card is locked. take out the memory card and check for a lock slide at the sides of the card that you can adjust to a lock and unlock position, then test the card again.
Sep 07, 2010 | Olympus FE-190 Digital Camera
Write protect
When you disconnected the camera, did you use the "safely remove hardware" icon at the bottom of your computer screen?
Oct 28, 2009 | Olympus FE-210 Digital Camera
Write protect error olympus c 150 (cant get rid of read only)
Hi!
You might wanna check on your memory card. It could be that it is currently on write-protected mode. What you want to do is to check it now and then look for something like a push button. If its on the top position, push it downwards. Vice versa.
Aug 29, 2009 | Olympus Camedia C-150 Digital Camera
Write protected-Olympus EVOLT E-510 Digital Camera.
Hi there
The write protect is on the memory card, take the card out and unlock it, it will be at the side of the card like this 59a6de4.jpg .
Good luck and thanks for using Fixya!!
May 15, 2009 | Olympus EVOLT E-510 Body Only Digital...
Write protection
Hi, The PDF of your manual is HERE. Page 28 refers how to remove protection on stored photo's.
Page 30 lists how to connect to your PC with USB cable.
You should use the software disc with the camera (or available from Olympus) to navigate to delete this option.
It should be on a menu as an option.
If you still have problems, Send olympus customer support an Email with your problem. - Their link is here -
http://www.olympus.co.uk/customersupport.htm
Jul 02, 2008 | Olympus Camedia C-150 Digital Camera
"Write Protect" on Olympus FE-115
Check the manual to discover how write protect is achieved with your particular camera/card Some card rely on a silver foil stick[Smart Media] other have a switch. Compact flash rely on a control on the camera. So you will have to have a good browse through the manual - do not forget that there is a Full manual in PDF on the software disk.
Aug 20, 2007 | Olympus FE-115 Digital Camera
Cameras Logo
65 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
