I have a 702GE gatway that was working fine, i took everything out in an attempt to put it in a new case, the case was the wrong size so i desided to put all the hardware back into its original case but now the computer turnes on, beeps 3 times and shuts off...how can i get it back up and working the way it was 20min ago..please help
jackboy
  • 2985 Answers
SOURCE: I am have Samsung Digimax S600
Well all the time these item [didgi cams and small electronics of all sort do seem to have a high fail rate. But as I said less than a year - take it back
Posted on May 25, 2007
SOURCE: JVC HD-52G786 shuts off
Do you have your TV plugged directly into the wall? You cannot plug into a power strip, it needs its own direct power source. Also, I have heard that there can be electrical problems inside. I have this same model, I love it, picture and sound. I just replaced the bulb for the first time last night. It was a little premature to replace it now but I know what caused it. I bought a new bulb and it works like a gem. If you ever need to change the bulb do it yourself. It takes maybe 2 minutes. The bulb looks like the Flux Copassitor and all you do is remove the door in the back on the side. Unscrew the the 2 screws that hold the bulb in and just pull out. When you put the new one in make sure you do NOT touch the glass on the new lamp. Just slid it in and screw the 2 screws back in and make sure the door is closed and tight. My uncle had a service guy do his and he got raked for 5-$600, The bulb costs about $200. Should last about 5-6 years at a rate of 5-6 hours of TV on time. Hope this helped. If not, sorry, but at least you know how to change the bulb. Good Luck!!!
Posted on Apr 08, 2008
SOURCE: ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Posted on Nov 20, 2008
byteguy
  • 2229 Answers
SOURCE: Four beeps wont turn on, Dell 4700
The four beeps usually indicate a memory problem and it won't pass it's Power On Self Test. Try reseating the memory sticks, or, if you have two of them, take one out and try to start the machine and then swap them.
If this doesn't solve the problem, you most likely have a bad motherboard.
Posted on Feb 01, 2009
ashish13
  • 75 Answers
SOURCE: want turn on getting number 1 and 3 flashing
Your Power Supply has gone bad mate... known problem. You need to swap out the old power supply with a new one or maybe a working one (if you have another system)... the procedure is fairly clearly documented on the Dell Site n no Tags needed for that... :-)
Posted on Feb 11, 2009
Problem with my bobbin case I'm sewing suddenly there clunking, my machine jams, bobbin case flipped 180. took apart, re-adjusted, put everything back and it worked fine, but it keeps happening. Help
Sounds like there are some parts that are worn or broken on your machine. A bobbin, when correctly inserted and latched, should not spin 180 degrees on its own.
Have you tried a brand new needle? Just wondering if it is bent and hitting below the needle plate.
Jul 28, 2016 | Sewing Machines
I placed the motherboard into a new case. I think the new case had a defective power switch. it would not start. I put back in the original case and the computer attempts to start and stops and keeps...
> attempts to start and keeps repeating
Please be more specific.
Do you get the initial "splash" screen, and then some white-text-over-black-background,
giving RAM size, processor ID, and such?
Do you see the "press DEL to enter BIOS SETUP" message?
What else do you see?
Is a disk-drive attached to the motherboard?
Does the motherboard try to boot from that disk-drive?
Nov 15, 2010 | Computers & Internet
MH1160 Whirlpool Microwave Stopped Heating
Are you getting 110VAC on the primary leads of the high voltage transformer when you press "Start" to begin cooking?
If not, yhen it may simply be a bad cook relay (I do board repair) or a bad bottom or inside top door switch. See http://www.microwavecontrol.com/doorsw.htm
E-mail me via my site for more free help.
William E. Miller, AS-EET
pupista@gmail.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 21, 2017 | Whirlpool MH1160XSS Stainless Steel 950...
Got "wrong cartridge" error while attempting to print. Removed & reset all ink cartridges, still same error. Removed inks & print head, immediately lost power. Unplugged, waited, put everything...
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
QY6-0049-000
Nov 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Will not print from computer.
What printer brand/model is it? Make sure the printer is set to Online on the printers and faxes.
Jul 24, 2008 | HP PSC 1610 All-In-One InkJet Printer
Printer issue...:(
Hi MaCaTa2,
It can be frustrating when things aren't going smoothly.
Sounds like you're wasting a lot of dye film and cards too!
What program are you printing the badges from?
You have a very 'paper' size with this type of printer.
If you select 'Magicard Printer Series' as the printer, you will then see a special paper size called 'CR80 Edge To Edge'. This is basically the size of a credit card. (2 1/8 x 3 3/8" (54 x 85.6mm). Check your font sizes are not too big. Any text printed on the back of the card is on page 2 of 2 (on the Tango model, a Rio would feed a second card).
Experiment with an application like MS Word, where you can clearly see the 'pages'.
Create a new word document, straight away go to 'File, Print', select 'Magicard Printer Series' from the printers list, then 'Close' (not 'Print'). Next, go to 'File', 'Page Setup', for the paper size choose 'CR80 Edge to Edge', set all the margins to '0' (this is a 'full bleed' printer.
You will now see a credit card size page to work on. If you fill this page (or insert a page break), you continue onto page 2 (the card back - only available on Tango).
I hope this helps.
Regards,
MC.
Jul 01, 2008 | Magicard Tango 2 Printer
Won't print markdown lines on tickets
Did you buy a new computer with Vista?
Jun 24, 2008 | Zebra LP 2844 Thermal Printer
Wont turn on
All PSU's have a RED switch on the back make sure it is set to 115V. Connecting the case back to the mobo is described in the manual. If you do not have the manual you can connect with Gatway through online chat at: http://support.gateway.com/support/contact/chat.shtml
Dec 04, 2007 | Gateway 500GR PC Desktop
Debris in Gearing
check google for service-manual icq 475653626
Nov 30, 2007 | Samsung ML-2510 Laser Printer
Computers & Internet Logo
David Payne
David Payne
