Question about Microsoft Computers & Internet
I've been using Microsoft Outllook 2000 for receiving and sending e-mails happily with Windows XP SP3 for a long time but in the last few days Outlook has been unexpectedly closing almost immediately after opening without any error messages. To try and cure the problem, I have used Windows System Restore but have been unable to restore to an earlier date/time. Any help or advice you can offer would be gratefully appreciated. Many thanks in advance.
  • wbroad Sep 08, 2010
    Thanks for the prompt response. Since I originally contacted you I have checked a few thing for myself (see below):-
    I don't think the data file (mailbox.pst) is corrupt.
    I have scanned the file with scanpst.exe and no errors were found.
    I have also temporarily moved the data file from its default location which forced Outlook to create a brand new data file but this did not cure the problem.
    Also, I added a new profile in Outlook and removed/re-added the original profile but I still have the same problem.
    After searching the internet, I found a workaround for the problem as follows:-
    1) At a command prompt run: Outlook /cleanprofile (this switch prompts for a profile to use and then apparently removes invalid profile keys and recreates default registry
    keys where applicable).
    2) I have to do this with both profiles and then Outlook opens and stays open OK. When I close Outlook the problem returns so I have to do this each time I want to open Outlook. It's not an ideal solution but it works for now.
    I don't think a Windows update has caused the problem either because I have not installed any updates for 2-3 weeks and Outlook was working fine until last weekend.
    Just before the problem started, I downloaded an I-Tunes update. Do you think this may have caused the problem? Perhaps I should un-install I-Tunes and re-install the previous version?
    I've also tried Outlook's own "Detect and Repair" utility but this made no difference.
    I suspect that something might be corrupting the Outlook profiles or incorrectly removing Registry keys when I close Outlook. Perhaps I should completely un-install Microsoft Office 2000 Professional and then re-install it from the original set of two CDs?
    Lastly, I've noticed that the data file is quite large (374 MB). Is there a limit to the size of file that Outlook can handle? Should I perhaps compact the data file or archive some of the older messages?
    Is any of the above additional information of any help?
    Let me know what you think. I'd be really grateful for your opinion.
    Thanks in advance.
  • Microsoft Master
  • 19,396 Answers
Hi.
Most Outlook problems of this kind are caused by a corrupted Outlook data file. In that case system restore and Office reinstall will not work.
Outlook/Office 2000 is also quite an outdated version, and may have troubles with Microsoft updates, that usually are set to install automatically.
As first step, locate and copy and paste onto an external hard drive, a CD or a USB memory stick the Outlook PST data files (look for personal.pst). This are located inside the hard drive. They can be found used Windows search. In the search window use advanced to enable searching hidden files and system files.
Once you have done manually a backup of your data, find a copy of Office 2007 or Office 2003 (better), and install it onto the computer. If the operation is successfull, the newer Outlook will convert and update automatically the old PST file, importing all your personal folders, contacts etc. and fixing the problem.
If the update cannot be performed, or if that does not fix the problem, then report exactly the error message that you get. The fixes are different depending on the error prompted by Office.
Posted on Sep 07, 2010
Windows media player error - "not installed properly and must be reinstalled. Do you want to intall the player from the Microsoft Website?" Media player 11 with Windows XP sp3
you will not be able to upgrade window media only goes to 10 for windows xp. if you are having problems with playback then there are video and audio code packs for windows media that are updated and free.
May 29, 2017 | Microsoft Audio Players & Recorders
I have Windows XP SP3. My main software is QuickBooks 2009. I use Internet Exp 6 & Outlook Express for e-mail. After updating Windows (.NET Framework,etc.)I started to get error messages (Microsoft...
try uninstalling the last updates that you received before the problem occured however, I would recommend you update to ie 7 then to ie8 use windows or microsoft update to perform the updates.......as for outlook it should update from windows update (Microsoft Update) as well.
Jul 15, 2010 | Microsoft Internet Explorer 8
I can send email messages via outlook express, but I cannot receive them. I get an error message. This started to happened after installing McAfee Internet Security on my Dell pc with Windows XP SP3. I...
The registry from McAfee that blocks your incoming mail could still be working... Try running a registry cleaner. Try Ccleaner @ www.ccleaner.com
Mar 17, 2010 | Microsoft Outlook Express
"general mail failure in Excel 2003 when trying to send attachme
Hope this works :
Close Excel first and check out if Outlook or Outlook Express/Windows Mail is your mail program for Office.
Start>Settings>Control Panel....Internet options (Program Tab)
In Vista : Start>Default programs
Controls to send mail might be missing missing or disabled or there are errors when you try to mail.
when u get this error message "General Mail Failure " The "E-mail" command is missing or is unavailable, see
http://support.microsoft.com/kb/918792/en-us
for excel 2003 chek the registry for errors
http://support.microsoft.com/kb/834008
hope it works ......
Feb 17, 2010 | Microsoft Excel 2003 (06503995)
Want to download and install windows xp to my pc
kindly follow the official link link from microsoft given below where u can download and install XP Sp3
http://www.microsoft.com/downloads/details.aspx?FamilyID=2fcde6ce-b5fb-4488-8c50-fe22559d164e&displaylang=en
thank you
have a nice day
if u felt i ve been of help and spent time for u.. kindly rate the service
Jul 25, 2009 | Microsoft Office Professional 2007 Full...
Software to work with Windows 2000
Hi
Try the MS driver package below. I don't have a LifeCam to test. Let me know if you are sucessful
Microsoft LifeCam NX-6000/VX-1000/VX-3000/VX-6000 Driver 1.21 Windows driver
Manufacturer: Microsoft
Version: 3.10.58
Added: March 11, 2002
Updated: March 17, 2002
Filename: MicrosoftLifeCam1_21.exe
Filesize: 543 Kb
OS: Win XP, Windows 2000 SP4, Windows 3.11, DOS, Windows NT, Windows 2000, Windows 95, Windows NT SP1, Windows 2000 SP3, Windows 98
http://download.microsoft.com/download/c/f/3/cf34583f-f873-4b8c-8b13-00d156f3af05/LifeCam1_21.exe
Mike
May 13, 2008 | Microsoft LifeCam VX-1000 Webcam
Unable to send email in outlook 2003
check the mail settings for receiving and sending in tme mail options i think sending mail setting is wrong
Apr 23, 2008 | Microsoft Windows XP Professional With...
Keep getting disconnected when geting email
Check your connections settings in outlook, if there good, make sure you have no mail your trying to send, it wont receive any mail tell it sends mail. Good luck Cat
CoDoc
Dec 11, 2007 | Microsoft CompuRegister POS-1000 POS...
Computers & Internet Logo
22 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
