Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
I have a pro heat turbo cleaner and the water does not come out when the trigger is depressed
  • Bissell Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
Posted on Sep 07, 2010
How to take out the water holder to fill it with water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
heatman101 ..,/,
May 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Water is leaking out of the upholstery cleaner
Might the button be stuck a bit? We had this problem and rinsed the brushes out and cleaned the connector area with a damp paper towel. Had to push the button in and out several times to be sure it wasn't sticking. Also, when the hose is docked found it tended to hit the docking station and would spray everywhere! Had to turn around the hose w/ the button so it would stop spraying everywhere. Hope this helps.
Apr 22, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
A friend loaned me her Bissell Proheat Turbo carpet cleaner and I don't know how to use it - any help?
I like these cleaners.
First vacuum your carpet very thoroughly.
Depress the lever to tilt back the handle.
Grab the tank from the base. Remove the lid.
Fill the bladder with hot tap water. Replace the lid, and place tank back into the base. Put the handle back upright until it locks into place.
Take the soap container on the side and fill it with the Bissel soap solution. Place your dial on floor cleaner, and select either soap or heavy traffic.
Turn on the machine and the heater. Take your machine to the far end of the room and depress the handle put the machine in the corner depress the trigger and you will see a little spinning thing on the machine starting to spin - this means that the solution is blending and the spray is wetting the carpet. Pull the machine slowly back towards you about three feet and then let go of the trigger and pull the machine a couple more inches. When you stop the trigger will release. Push the machine forward and repeat the pull pass this time without depressing the trigger. For the next pass - overlap each and every pass (I do each pass at the half way point). Do this along the back wall. When you depress the trigger and that spinning dial does not spin - you are either out of water or out of soap. Go over the entire room with this technique.
Now this next step is VERY important. You have to do the whole room process AGAIN - this time with NO SOAP. I have used these machines for years and trust me - if you don't go over it again - your carpet will be a magnet for dirt. This time empty out your soap cup and rinse it out and refill it with WHITE VINEGAR. Again fill your tank with hot water. Re-do the entire room as if you are shampooing the carpet.
Let the carpet dry overnight - the next morning I would recommend applying scotchguard carpet protector (you can get the cans at H.D. or Lowes. Yes the Bissell solution has scotchguard, BUT when I apply the scotchguard again - the carpet stays so much cleaner so much longer.
Do it right the first time and don't cut corners and you will have the cleanest carpet on the block. It's a long process to do it right, but the end result is worth it.
OR if you want to save money and use something more environmentally friendly - fill with white vinegar. This will work just as good and leave your carpet less sticky from the soap and your carpet will stay cleaner longer.
Mar 19, 2010 | Bissell 1699 ProHeat Clear View Upright...
Bissel pro heat cleaner won't expell water -- seems no suction
The reason that it won't expel water is because your pump belt is stretched and worn. You need to replace that belt, it is pretty easy. Here is the belt you need:
Bissell ProHeat Pump Belt
Jan 30, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Lost instruction book for my bissell pro heat turbo deep clean
BISSELL User’s Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User’s Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Nov 15, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell pro heat carpet cleaner, the water spray wont come out to clean the carpet.
Bissel proheat turbo 2x ipx4.
I don't have the instruction the this machine if you could help me with where to put the water and cleaning solution and how much, also how to use it.
Thankyou,
Please email me at carolynsst@yahoo.co.uk
Mar 01, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Carpet steamer continually sprays water/cleaner. Can't stop it!
This is a solution for the Bissell Pro Heat, although it may apply to other Bissell steam cleaners as well. This is for the problem of the cleaning solution continually spraying without stop.
I found a quick and simple solution to this problem.
This problem occurs because the valve that allows the solution to flow gets "sticky" and will not close. The valve is engaged by the trigger mechanism in the handle. Squeezing the trigger pushes downward on the valve's plunger, but the spring in the valve that is meant to push the plunger back up to the closed position is not capable of doing so.
Here's the solution:
This valve is white and resides about half way down the vertical handle portion of the cleaner. To get to it, unscrew the 2 black screws that hold the top part of the handle to the bottom part. These are the same screws that you used for assembling the cleaner when you first bought it. Pull the top portion of the handle up and it should slide out.
Now, looking down into the handle body of the remaining portion of the handle, you'll see the top of the white valve. If you push down on the top of the valve (like the trigger mechanism in the top part of the handle you just removed does) it may go down some, but it probably won't go back up by itself like it should.
I found that lubricating this plunger with dish soap was the trick. If you can't get enough access to the valve to do this, you can remove the seven phillips head screws in the lower portion of the handle and pry it apart. I did this. I even took the valve out and put soap around the plunger and into the valve itself. I worked it up and down until it had a quick and positive open/close action.
Reassemble and you should be good to go. You'll notice that the trigger now has a more positive feel to it. I hope this helps.
Dec 14, 2008 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
304 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
