I search the codes to command the SKY HD decoder pace DS831NS with the URC 1212 TOTAL CONTROL
Pls, any 1 wit sky + HD universal remote code. Inbox me joeabidakun@yahoo.co.uk. Pls am waitin
Posted on Sep 12, 2013
4 Suggested Answers
SOURCE: Total control urc-2082 universal remote control
Here are all i have
0579,0060,0261,0035,0744,0577,0214,0066,0110,0216,0446,0366,0593,
0397,0023,0795,0032,0223
Posted on Mar 09, 2009
  • 403 Answers
SOURCE: I have a Total control remote 8.1 and i can't find
If you have a Brookstone remote control this will work for you. This sequence will also work with most universal remotes. If it doesn't let me know and I will try to find the codes for you. Just remember to send the Brand and model (very important when finding this info for you).
Here you go. This will work with most all universal remote controls. If you don't have the code do the following:
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device. Although this method can be more time-consuming, it eliminates the need to look up codes and enter them manually.
1. Turn off the device with which you want to use the remote control, keep in mind when not trying to use this sequence with any other remote than a Brookstone you might have to have the unit on when doing this, then it will turn off when you have the right code. I would try the first option first.
2. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) until POWER INDICATOR illuminates. It should take a couple of seconds for the light to remain solid. The remote control is in programming mode.
3. Press and release power button. The POWER INDICATOR flashes once and stays on indicating the unit is in Power Scan mode.
4. Press CHANNEL up or CHANNEL down repeatedly until the device turns on.
5. When the device turns on, press OK to store the code.
Note:
• To exit without storing the code, press BACK.
• The unit will search for the next code or the previous code if you press
CHANNEL up or CHANNEL down after the device turns on. (go slow you need to press OK when the TV turns on) if you mess up turn TV off and start over.
6. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Fill free to ask me questions about anything..........................
Hope this helps, let me know if I can help you with anything else. It would be very kind of you if this does work for you to please rate me or leave a short note. I would really appreciate it. Thank you for your time.
JimmyC
Posted on Nov 01, 2009
SOURCE: total control codes urc 11-2082
codes daewooTV are: 0657 0397 1932 0522 0060 0579 0032 0239 0241 0684 0240 0474 0062 1160 1925 1951 1931
Posted on Aug 16, 2010
Total Control Universal Remote. URC 4140. What is the 4 digit code to operate the above TV
Search Results
    [PDF]Total Control URC-4140 - Universal Remote Control Codes
    www.remotecodelist.com/remotes/URC_4140_B00_and_B01.pdf
    UNIVERSAL. Remote control. URC - 4140 ... Your TOTAL CONTROL can operate four devices: a Television, ... The TV, VCR/DVD, SAT and AUX keys select the device.... 4. Enter your four-digit code using the number keys. The red light will blink twice.... To set up your other devices, follow the same instructions above, only.
    Codes and links for a number of universal remote controls, including Sony, RCA, ... GE Remote Codes, General instructions for GE Universal 3 and 4 digit remote controls. ... This manual may work for a number of Philips-Magnavox remotes. ... Total Control URC-4140, PDF Instruction Manual (remote also known as Crest .
Jan 13, 2016 | Sanyo 42 in. LCD TV
I need total control urc 2940 remote codes for a Baird FULL HD TV
0182,0188. Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Sep 27, 2015 | Universal Televison & Video
I need a code for grundig 7 in 1 remote to operate sky plus (not hd) box. it is a Pace manufactured sky plus box.
0027,0048,0091,0063 are the codes to check with Sky Plus. If you wish to get more, check these sites. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 24, 2013 | Grundig 7 In 1 Universal Remote Control -...
How do i ebter a code for a samsung tv??
I can help you with your URC-3021 Universal Remote Control issues.
The codes for Samsung TV's are: 0060, 0702, 0030, 0178, & 0812.
For complete instructions on entering the URC-3021 remote codes, please refer to my posted Fixya Tip One For All URC-3021 Code Entry.
I hope that helps.
_______________________________________________
Reassign URC-3021 Device Key
Urc-3021 Code List Download
One For All URC-3021 Code Search
Jun 25, 2010 | One For All URC-3021 Remote Control
I need the codes for the one for all remote urc-3220 please reply asap.
I can help you with your URC-3220 Universal Remote Control issues.
The codes for JVC TV's is:0053.
For complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
May 07, 2010 | JVC HD-52G787 52" Projection Television
Manual for URC-11-2840R00
how do you set up a Total control 4 way remote silver
Mar 19, 2010 | Universal Remote Control GE174Universal...
Total control codes urc 11-2082
code for autormatic seach total control urc 11-2082 b00
Apr 20, 2009 | Televison & Video
I need the code fro a new sky box hd
To find the codes for the sky boxes you will need to look at the user guide/manual that came with the remote control. Go to Sky's website for the remote codes. select version 8 for all new Sky + HD remotes
Mar 01, 2009 | One For All URC-3445 Remote Control
Televison & Video Logo
545 people viewed this question
Top Televison & Video Experts
Electro Med Services...
