Question about Canon iR 2016i Black and White Copier
When i put copier on few seconds give E000 how i can troubleshooting this
  • 1,219 Answers
these error means temperature trouble in fixing section.
First, lets try to clear error:
press *
press 2
press 8
press *
With arrow + or - select CLEAR and press OK, then select ALL and press OK.
If these doesn't solve your problem, these means that you need to change the fixing heater assy.
Posted on Sep 07, 2010
System error e000
Are you getting the error on your computer or on the printer display?
Jul 27, 2013 | Canon imageCLASS MF4320D
E000-001-002 please help solution regarding this code
This a fixing assembly tempature error. First reset the copier by getting into service mode. Additional Function key, then the 2 & 8 pressed at the same time, then Additional Function key again. Press COPIER on display, then Function ( across the top ), then CLEAR, ERR, Then Ok. Power down copier then wait a few seconds then power up again. If the error continues then the fixing film will have to be replaced.
Jun 21, 2011 | Canon imageRUNNER 4570 Copier
ERROR CODE E000004-0001 IN 8070IR COPIER
This is error given by the thermistors in the fuser. Not detecting a temp change or too much temp difference between the thermistor ( front edge and Middle ). You can reset it by going into service mode. Press additional functions, then 2 and 8 at the same time, then additional functions. Press copier, then function at the top of the display, CLEAR, then ERR, then OK. Power down the copier using main power switch. Wait a few seconds then power up again. If the error continues then you will have to have the thermistors replaced if the heater is working. The heater should give an E000 code if not heating up.
Jun 09, 2011 | Canon imageRUNNER 5000 Copier
Canon iR 2022 gives a system error E000 and error E003, what could be a problem?
how to clear error code e000 please help me copier ir 2022 show me how to clear
May 19, 2011 | Office Equipment & Supplies
What cause errer 000 canon np7161.when lit, it is E000 and it goes off after a few seconds.
A error code of E000 means that the fuser unit is not turning "ON" or is not warming up correctly. You will need to fix the problem before you can reset it. You may have a blown fuser lamp or thirmister or thermal fuse or all three? Good Luck
Oct 03, 2010 | Office Equipment & Supplies
SYSTEM ERROR E000
Error Coed E000
- Check the connectors of the fixing film unit.
- Need to replace fixing film unit.
- Need to replace Hi Voltage Power Supply Board
- Need to replace DCNT Board.
May 29, 2010 | Office Equipment & Supplies
How do I solve a system error E000
You have to get into service mode and reset it under Funcation. You may have a power problem with your outlet. It could also be a problem with the fixing unit..
May 23, 2008 | Canon imageRUNNER 1023N Black and White...
Canon D880 Error -- E000
Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser.
May 22, 2008 | Canon ImageClass D880 Copier
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
Nov 28, 2007 | Canon ImageClass D880 Copier
Canon iR 2016i Black and White Copier Logo
47 people viewed this question
old marine
old marine
