Question about Acer AL2216W LCD Monitor
Monitor turns on flickers twice then stays at a black screen
    Problem Solver:
  • 16 Answers
Test that your memory chips are fully inseted in their sockets as this can some times prevent displays from working.
Posted on Sep 07, 2010
Flickering light and screen
The power supply may be failing.
Mar 19, 2014 | KDS Computers & Internet
Flickering screen
The flickering problem you have is caused by a failing power supply. There are parts called capacitors that are failing and causing the power supply board to put out pulsing voltages until it can stabilize. We have a repair guide posted on our web site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ If you can soldethen you should be able to do the repair yourself. If you don't want to do the repair we offer a repair service for this unit. You can get details for that service here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, If so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Jul 15, 2010 | Samsung SyncMaster 205BW LCD Monitor
Describe your Dell E173FP 17" LCD Monitor Problem The monitor seems to be turning itself repeatedly on and off. No picture is ever seen, the screen stays black with a slight flicker.
Sounds like the monitor is cycling power.
Try plugging the monitor into a different power socket. Try not to use the same power bar as your computer
Mar 24, 2010 | Dell E173FP 17" LCD Monitor
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Monitor flickers then goes to black/blank screen.
have you tested it for gone conponments
Aug 14, 2009 | Computers & Internet
Black screen/flickering
try using an external monitor, if the problem doesn't happen on the external monitor then definitely the problem is with the LCD screen. Possible replacement required for the LCD panel.
Jul 13, 2009 | Compaq Presario CQ50-215NR Notebook
HELP ME FIX MY MONITOR PLEASE
same thing is happening to me except when i turn on my computer, you can see the screen and its flickering then a few seconds later it turns all black.. :( !!
Dec 04, 2008 | Computers & Internet
My hp pavilion dv6000 laptop does not turn on, the blue buttons light up, but the screen stays off
Try it without the rechargable battery connected sometimes the battery shorts and causes problems.
Do you have FN[function] keys at the left side. touch FN key with something else and see if screen comes back.Sometimes you can turn off the screen to send it to the back connected monitor.Connect (extra if you have) an external monitor to the back (vga) connector.If that shows, then you have to ""flutzz" with the FN(function) & F1-F12 keys
Nov 28, 2008 | Computers & Internet
Blank screen
its cheap buy a good one!!!!!!
Dec 22, 2007 | Computers & Internet
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Acer AL2216W LCD Monitor Logo
74 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
