Fridge is freezing up/icing up - Office Equipment & Supplies
I have an admiral gc2224gekb side by side. The ice machine isn't producing ice and also the fridge is freezing up
First, check to see if the airflow is blocked at the back of the fridge compartment as this also may cause the lower items to freeze. Fridge freezing is usually the malfunction of the damper swing door or the circuit controlling it. A failure of the temperature sensor in the fridge could be the cause. We just had ours replaced this year [on extended warranty]
Sep 22, 2016 | Admiral Refrigerators
Ice maker is not producing ice and items in fridge are freezing.
How old is the fridge? Is this the first trouble experienced with this fridge? What is the outside temperature of the air around the fridge? Is the fridge kept in a garage? Please report back.
Jul 21, 2015 | Refrigerators
Fridge freezing up
It may be a faulty thermostat,namely the control you are using to turn it down.Also there may be ice in the drain line from the fridge compartment to the evaparator tray at the bottom.Try unplugging it overnight .That would allow any ice buildup to thaw.Once it goes into defrost mode again the resulting water should flow into a tray at the bottom of the fridge near the compressor.
Nov 11, 2014 | Refrigerators
My daughter's mini fridge has a freezer compartment. Her issue is, if she turns it up high enough so the freezer freezes, the fridge compartment also freezes everything; if she turns it down so that the...
This is a drawback of most mini-fridges. Start by defrosting everything. Then fill ice cube trays with water and keep lowering the setting until the water freezes. Just go a little lower, no more. Fridge should not freeze food. If the fridge stays closed all the time food will freeze. Also if the freezer element gets ice buildup it must be defrosted. Not automatic like home fridge. Most kids today weren't born when the last fridges that had to be defrosted were in service.
Sep 01, 2009 | Refrigerators
Ice maker makes ice then water dripps and freezes
water valve not working properly needs to be replaced ... located on bottom back nof fridg
Aug 11, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Freezer and icemaker freezes, jams.
I have run into this before and found it very helpful to re-level the refrigerator. By leaning the fridge back toward the wall about an inch helped keep the water and ice in the tray. Remember to remove items that block air flow in the freezer. Remove the ice bin and clean it then start over with the fridge leaning back a little. Hope this helps.
May 01, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Water does not flow through the dispenser
sounds like the sensors are playing up causing the bottom of the fridge to freeze, this will also cause the water reservior to freeze thus no water to the ice tray and water dispensor. do a full defrost then see if you gain back all the functions proving the sensor fault.
Apr 05, 2009 | Frigidaire FRS26R4A Side by Side...
Refrigerator not that cold and freezer not freezing well
between the door and freezer is very hot, and the refrigerator is not that cold and the freezing is freezing but not that well, ice cream is soft but meat freeze and ice is not melting. Also behind the fridge at the bottom is very hot.
Jun 05, 2008 | Kenmore 64802 Top Freezer Refrigerator
Fridge of Fridge/Freezer keeps freezing contents.
all the food going to ice temperture at 2
Oct 24, 2007 | Refrigerators
14 people viewed this question
jasbo
jasbo
