Question about LG LMV1680ST Microwave Oven
I have an ifb microwave-ifb25sc2 it is showing a cook option and nothing is getting heated
  • LG Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jfkkj
Posted on Sep 30, 2010
Use ifb microwave
You need to power down to 70% this will allow the inside
to heat as well.
Oct 11, 2013 | Microwave Ovens
Wolf convection microwave
see the next steps , use the VOM and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Jun 17, 2013 | Microwave Ovens
Sharp R-1510 1000 watts microwave, not heating
Sounds like the inverter (power supply for cooking) or the magnatron which does the work----neither are cheap parts.
Oct 16, 2012 | Sharp R-1510 Microwave Oven
Microwave will not cook or heat anything. Cooked a bag of popcorn just fine, tried to cook a second one and nothing happened. I thought the bag of popcorn was bad but it won't even heat water.
sounds like the magnetron has went out...this is the device that actualy converts the electricity into a heating source ... it is a common problem and can be costly,,it is not very hard to change just requires pulling the microwave if it is a cabinet mount and taking the exterior cover off and getting to the magnetron...the problem is the cost of the magnetron is normally somewhere in the range of a $100.00 and your time alot of people choose to get another one due to not being that much more expense and the work involved to repair yours.... good luck hope this helps...
please vote.....
Jan 03, 2011 | Frigidaire GLMV168K Microwave Oven
My ifb microwave oven is getting hot outside while
Normally when u cook food in microwave the fod is cooked by microwaves, which means the heat is generated with in food. The temperature inside is never too hot and all the heat produced is absorbed with in the food.
On the other hand when the grill is switched on, a separate heatting element gets switched on. You can see this red hot element on the top side of inside of microwave. the heat from this element gets transferred to food through air circulation. But partof heat also gets transferred to the walls of microwave oven. This is the reason the wall feel hot during use of grill.
As i see ther is no problem with the microwave itself. Jut kep delicate thngs a bit away from the microwave.
Oct 17, 2009 | LG Microwave Ovens
Hinari microwave doesn't cook
hello mam
i am having the solution for this problem check the lock terminals for loose connection and if its working and check the magnetron which produses the heat inside the microwave.
Sep 25, 2009 | Microwave Ovens
One word for cooking bulb
Are you talking about the magnetron which heats the unit? Do you have no heat in the unit. If so, your best option is to just get a new unit as the cost of the magnetron is not worth replacing.
Benjamin
Jun 01, 2009 | GE Advantium SCA1001SS Convection /...
No heat micro keeps cycling through all programsdemo in cook/bx
My GE doesn't have a Demo mode but say we have a power failure. It won't let me use it until I set the clock.
Try that and see if it helps
May 26, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave runs but does not heat--is is repairable???
I replied to your other post as well: It could be any multitude of issues from a faulty magnetron,a bad high voltage diode, a door switch issue or a faulty circuit board. A magnetron for your model is ~ the $60 area. A Circuit board is ~ the $100.00 mark. If your a wiz at electronics I would say give it a go and try to repair it yourself. Otherwise I would say that a new microwave oven would be your best bet. A technician may charge you up to $250 for the work they will do, bringing you to around the same cost of a new microwave with a warranty. Hope this helps. P.S. If you are interested in buying the parts and fixing it yourself, may I recommend this site: http://www.repairclinic.com They are top notch and really helpful.
Jul 26, 2007 | Whirlpool MH1150XMQ Microwave Oven
LG LMV1680ST Microwave Oven Logo
160 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Ross Metcalfe
Ross Metcalfe
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
