Question about Cameras
I am shooting with a 10mm - 22mm lens - however that should not matter. Frequently my camera cannot find a focal point and therefore i cannot active the shutter release. I am forced to switch to either Manual focus or A (Automatic. I generally have the camera set to either AV or P for standard shooting. I have an EOS Reblel (6.4 pxls) that i've used with the same (10 -22) lens and i have never run into this focusing issue. Also, I am framing pretty standard subjects like doorways etc....NOT a bird on the horizon! I am very frustrated as this was supposed to be a super camera and it's causing me real stress - when I have a framed image to change my settings at the point of exposure is extraordinarily disruptive. Any help is welcome. janet@roro.org
  • Cameras Master
  • 19,396 Answers
Hi Janet.
If the problem is with auto focus, then it is a factory defect due to the smaller flap. Here an article I wrote regarding this problem: the auto focus feature.
If problem is instead with manual focus, then issue may concern settings, firmware, lens, lens contacts, micro USM motors.
The auto focus issue is a common problem affecting different Canon Rebel models.Read the article above and follow instructions. The problem can only be fixed replacing the sub flapper pin.
Posted on Sep 07, 2010
The best telephoto lens for this camera?
Canon G10 - Ken Rockwell
www.kenrockwell.com/canon/g10.htm
Oct 20, 2008 - The Canon G10 is the best compact digital camera I've ever used, ...The G10 is a regular Canon Powershot point-and-shoot, in a tough ..... On the G10 theISO dial moves under the mode dial to make room for ... Neither the G10 or G9 have true zoom lenses; they only change focal length in discreet steps.
Canon PowerShot G10 Review ' Digital Camera Resource ...
www.dcresource.com/reviews/canon/powershot_g10-review/
Nov 24, 2008 - Is the PowerShot G10 the ultimate compact camera? ... Telephoto lens, TC-DC58D, From $109, Boosts focal range by a factor of 1.4X, ..... For bestresults, you'll want to attach one of the Canon Speedlites I mentioned back in ...
Jan 01, 2016 | Canon PowerShot G10 Digital Camera
Hi. Is it possible to shoot photos using the digital zoom in manual mode?? canon 600d
No, EOS systems only use lens at a fix focal point like 50mm, or lens that have zooms built in, ie; 24mm to 105mm. You can zoom images in a image editor like Photoshop.
Feb 12, 2014 | Canon EOS 600D Rebel T3i Digital Camera
I have a tamron 28-200mm lens that have a aperture ring at the back .. so is it possible to lock the aperture at f3.8 and shoot at 200mm focal ?? (this lens was f3.8- f5.6) by the way i was using a n
If you're using a Nikon camera, you want to lock the aperture ring at its smallest setting (largest f/number). You can control the aperture from the camera body, the same way as on a lens without an aperture ring.
This has nothing to do with the focal length. You can shoot at any focal length from 28mm to 200mm.
Feb 10, 2014 | Cameras
If you had a compact camera it would say 10x zoom what is the equivilent in a 70mm -300mm tamron
A 35-80 mm lens is 2.3X zoom. Divide 80 by 35 and you'll get the result.
It is usually better to know what the focal length of a lens in "35 mm equivalent" is and judge by that, rather than relying on the "X" power of the lens. For instance, most point and shoot cameras start at about 35 mm and have either a 3X or 4X zoom. This would make it a 35-105 or a 35-140. I've seen some that start at 28 mm, though. A 3X starting at 28 mm is 28-84 and a 4X is 28-112. Neither one is a particularly strong telephoto lens and the 4X is just about the same as the 3X that starts out at 35 mm.
It's also important to realize that tradition dictates that lens focal lengths are usually expressed in terms of "35 mm equivalent," where "35 mm" refers to a 35 mm film camera. This is because of the relation between the sensor size and the actual focal length of the lens and the resultant angle of view of the lens.
I have one point & shoot that is actually a 5.8-24 mm zoom. This is a 4X zoom. The 35 mm equivalent is 28-116 mm. The sensor is 7.2x5.3 mm. (1/1.8") (And I wish I knew someone who could explain how the heck they came up with sensor size terminology!)
I have another point & shoot that is actually a 5.7-17.1 mm zoom. This is a 3X zoom. The 35 mm equivalent is 34-102 mm. "How could a shorter focal length give a longer 35 mm equivalent?" you might ask. It's because the sensor is only about 5x4 mm. (1/2.5")
I have a few Nikon DSLR's and - thankfully - they all have the same size sensor. They all have a "lens factor" of 1.5. This means that you just multiply the actual focal length of the lens to get the 35 mm equivalent and then you can make comparisons accurately from camera-to-camera. Most Canon's, for instance, have a lens factor of 1.6. On a Nikon DSLR, a 28 mm lens is the "35 mm equivalent" of a 42 mm lens. On most Canon DSLR's, the same 28 mm lens is the equivalent of a 45 mm lens.
These example are just to show you how freaking confusing it can all become if you try to make sense of the "X" power of a zoom lens.
Bottom line...
Check the 35 mm equivalent specifications for the lens. This way, you will be leveling the field and comparing apples to apples. More or less.
Jul 10, 2012 | Tamron 75-300mm f/4.0-5.6 LD Lens for...
Overexposed shots when between 10-14mm. I understand from another user that this is common near 10mm. Will there still be a problem if shot taken at night? Used with Canon Rebel T1i
I owned this lens and didn't have that problem, but I always ALWAYS used the lens hood, and 99% of the time had a slim 77mm circular polarizer on there as well since my use for it was mainly landscapes and mainly during daylight hours. Does your camera have lens profiles for automatically correcting known lens issues? As a Band-Aid solution you could dial your exposure compensation down to -1.00 or so when shooting 10-14mm. It's a pain, but better than blown highlights...
You might also try different metering modes. I tend to use partial metering and choose a spot with "average" light in my shot, then lock the exposure, autofocus, then shoot. Sometimes evaluative metering might read too many darks in such a wide framing and overcompensate - just a theory.
Feb 12, 2011 | Canon EF-S 10-22MM F/3.5-4.5 USM Lens
How do you take a pic with the Nikon d60 where the background is blurred?
You're trying for what's called a narrow depth of field. DoF is controlled by three factors: distance from camera to subject, lens focal length, and lens aperture. The closer the camera is to the subject, the narrower the DoF. The longer the lens focal length, the narrower the DoF. The larger the lens aperture, the narrower the DoF.
Get as close to the subject as practical, and use as long a focal length as practical. I realize these two aims conflict with each other. For portraits, you want a focal length in the 50-90mm range and move in to fill the frame.
You want to shoot with as wide an aperture as you can. Unfortunately most lenses are not at their sharpest wide open. Also, the 18-55mm lens doesn't open up all that wide, f/3.5 at 18mm and f/5.6 at 55mm. To get the widest aperture, you can shoot in the P or A modes. If you don't want to leave the point&shoot modes, try using the Portrait mode.
Since you're not paying for film, I suggest you experiment with the different settings and shooting setups, moving closer and farther from the subject, using different focal lengths, and using different apertures, and see what results you get.
Nov 22, 2010 | Nikon D60 Digital Camera with 18-55mm lens
Item: Canon EF-S 17-85mm 1:4-5.6 IS USM Camera: Canon 20D Problem: At a focal length of below 35mm with the aperture set smaller than f4.0 in any programme mode an Err 99 appears in the view finder,and...
Check this article which will lead you through diagnosing the problem and a possible fix.
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Sep 20, 2010 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
?? I am having the same problem. The eyepiece I am using is 22mm?
Put the 22mm eyepiece into the focuser. The focuser end is pointed UP, the big mirror is on the bottom. Take the lens cap off, and go outside during the daytime and practice focusing on a distant object.
Sep 16, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
I going to be shooting an high school beauty pagaet,, what lens suggest i use.. any other points on what shutter setting i should use..
I would recommend a fast medium focal lengh prime for dimly lit scenes, such as a 50mm f/1.8 or 85mm f/1.8. The 50/1.8 is really cheap, still very sharp! The 85/1.8 is a fantastic lens for portraits.
For daylight scenes I would recommend a zoom lens, with a range from ~17mm to ~55mm.
In order to avoid motion blur by camera shake, always try to keep your shutter time to 1/focal lengh or shorter. That is, if you shoot with a 50mm lens, you should use a shutter time of 1/50s, or shorter.
Jan 16, 2009 | Cameras
Whats the best economical lens to use for indoor photograph with
If you are new to photography in general and especially SLR photography I would suggest holding off on buying any lenses besides the 18-55mm.
The reason I suggest not buying extra lenses just yet is coz you need to get to know your camera and if you are new to SLR photography then you need to get your fundamentals right. Sure the 400D will let you shoot in full auto mode but you will really not learn much doing that and certainly not be making the most of your camera in that process and that will extend to your new lenses too.
Get used the the control, the 18-55 is a great little cheap lens with the pop up flash it will work great for most family pics. The 55-200mm is a new "cheap" lens, its been marketed as letting you go beyond 55mm thats why it starts at 55mm goes to 200mm.
Hope this helps you...
Jan 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
