Question about ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 Issue with No Display yet Green Power LED Blinks ....and possible solution
Whenever I would switch resolutions, it would cause my display to go out and not come back on. Meanwhile the green power led would be blinking at me. Now it's gotten to the point where I would boot my computer, and I would see the POST screen, but the moment it switches to the Windows XP Logo, I would lose the screen entirely due to the resolution change.
I first checked my cables and tested them out on other monitors, and they worked perfectly. Then plugged the Viewsonic VX922 monitor into several other computers in my household and had the same exact problem.
I decided to do some research online and found out that this issue is incredibly widespread with this particular model. So, I decided to call up Viewsonic Technicial Support and told them about my problem with this model and how widespread the problem actually was. They suggested that it could be related to the "backlight inverter" and that through it's course of operation (which was roughly about 11 months after I purchased it) could have "burned out" or "got defective".
So apparently the blinking green light means that the "backlight inverter" is defective and should be replaced. This is probably useful information for those who bought this monitor but don't have the luxury of a manufacturers warranty anymore. You probably can go on ebay or someplace that sells this part and replace it yourself, if your warranty is up.
  • Anonymous Apr 26, 2009
  • 3 Answers
Thanks alot mate!
Posted on Jun 09, 2008
Viewsonic VX922 19" - green
Since you hadd confirmed that the monitor is faulty with a swap then it seems that the input signal processor is faulty.
Only a signal test will confirm the fault in the stage , so check from the power supply section to see if the set has tripped off due to a protection- if so check the output drivers.
Jul 27, 2011 | ViewSonic VX922 19" Monitor Flat Panel
Display out of range monitor not working
try to hook up your old monitor to use temp. go to display options and reintall drivers for the vx922. power down and switch monitors. windows should recognize the vx as monitor 2, click it and will cchange to a 1
Oct 09, 2010 | ViewSonic VX922 19" Monitor Flat Panel
I have a Viewsonic VX922 My led power goes on and off and the screen flickers then finally screen is black.
Defective power board can cause of on and off the led power, the boated electrolytic capacitor of secondary power supply and inverter area, shorted semiconductor of inverter area. The electronics repairman can fix this.
Sep 20, 2010 | ViewSonic VX922 19" Monitor Flat Panel
I have a vx922, green light blinks but there is no picture.
Blinking about once a second? Switchmode power supply fault in the monitor.
May 19, 2009 | ViewSonic VX922 19" Monitor Flat Panel
The blinking green light on VX922
If there is a flashing led on front of the monitor, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1 The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours, sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr suddenly are a blown capacitor on power board, the inverter board powering up backlight lamp has blown, or a fault on main lcd controller board.
check also the video cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Check connectors, try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact Viewsonic to find out a Viewsonic service point.
See:ViewSonic - Support & Service
If you want to repair at your own expenses, just locate any good qualified repairer.
Feb 26, 2009 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 - black screen of death and the blinking (mocking!) green led
Really if this happens then you may want to contact viewsonic to see if it still in warrant. Reminder that most of their monitors have a 3 year warrany from the date of purchase. So make sure that you have your proof of sales/receipt/POP/invoice or what ever you want to call it ready. This model is old so they will ask for it if its a first time repair.
Oct 28, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic problem
Get the RMA, I had no problems whatsoever with thecustomer service folks. They answered email within 1 business day, shipped off the monitor last week...
Jun 22, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic VX922 19" Green Light Blinks when booted, no picture
I have the same problem with my VX922 as do MANY others. The problem seems to be caused by leaking/bulging capacitors on the circuit board. The only solution is to replace the faulty capacitors either on your own (which is fairly easy if you're good with a soldering iron) or send it to Viewsonic and have them fix it.
May 21, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Viewsonic Monitor problem, blinking LED light, no picture.
you don't have a software (driver, refresh rate, etc.) problem. When you first power up the monitor, do you get any display at all (ex, "analog input" or "No input signal")? Of course not - that's because you have a hardware problem with the monitor. Go here and watch the youtube video on how to take apart your monitor and find and replace the "domed" capacitors that have blown:
Fortunately I only had 1 ($1.76 at Radio Shack). I replaced it in less than 30 minutes and my monitor showed "no input signal" upon powerup as expected because I wasn't connected to my pc which is full of all kinds of drivers and refresh settings, etc.
Aug 16, 2007 | ViewSonic VX922 19" Monitor Flat Panel
17" veiwsonic power blinking green
The flashing green power button is a well known electronic problem with this (and other) Viewsonic LCD monitors. There is a YouTube video (do a search) showing how to disassemble the VX924 and find out whether the problem is related to blown capacitors. When I took my VX922 apart I discovered 6 bad capacitors out of a total of 7 on the power supply circuit board.Only recommended for those handy with a soldering iron.
Jul 28, 2007 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX922 19" Monitor Flat Panel Logo
540 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
