Question about Saeco Talea Touch 14-Cup Coffee Maker
I have just bought the Saeco Talea touch and water is coming from the back of the machine at the base.
    Problem Solver:
  • 16 Answers
Take it back to where you bought it under guarantee
Posted on Sep 07, 2010
What to do when prime water curcuit comes on
When prime water circuit comes on turn on the steam/water valve may need to select hot water the machine will run water until primed
Nov 16, 2014 | Saeco Talea Touch 14-Cup Coffee Maker
My saeco talea touch wont steam out of the wand, it makes the noise like it is steaming but the steam is coming out of the bean hopper and the grind tray area
Your delivery pipe has been disturbed at some point and has dislodged or blown out the O-ring seal, or maybe careless assembly of said pipe seal, if under warranty, take it back.
Oct 19, 2014 | Saeco Hot Buy Talea Touch Plus Automatic...
Saeco talea giro flashing red exclamation point
take out the coffee waste bin, on the side facing into the machine, there's a little metal bit, it's a kind of sensor.
Clean it if it's dirty with a screwdriver or some wire wool.
Have you cleaned the brew group lately?
Sep 06, 2014 | Saeco Talea Giro Espresso Machine
I had a leak in the water tank of my Saeco Talea Touch coffee machine. I oredered a new water tank and received it. How to I detach the olde water tank from the outer cover of the machine and attach the...
Turn the tank assembly upside down,there are two tabs you need to unclip to allow the cover to slide off.
One tab is near the water outlet and the other is towards the outer edge of the tank.
Jan 26, 2013 | Saeco Talea Giro Espresso Machine
My Saeco Talea Touch machine stopped working this morning after a first cup of coffee. The error code on the screen said Restart to solve the problem (with a wrench key). I restarted the machine but the...
Had the wrench icon problem on a used Talea Touch that I bought.
Don't know how it started with the previous owner.
Solution - cleaned compressed coffee grounds from the grinder discharge. You need to manually spin the motor to clean all grounds from the rotation discharge gate.Also needed to probe and press the electrical connections to the motor. The brush spring and capacitors are press connected.
This solved the problem.
I've owned abnd repaired many Saeco machines. They are poorly designed and over priced.
None the less the majority of their problems can be fixed by simply cleaning the components.
Enjoy
MDR
Sep 08, 2011 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Touch. The Touch screen display is barely visable. Even after adjusting contrast. Sometimes disconnecting power cable for while gets it back to normal but not for long.
Hi...
The problem is the screen itself. You can get it fixed under warranty if the machine is new. Hope the service center will arrange it for you.
Good luck.
Oct 26, 2010 | Saeco Talea Touch 14-Cup Coffee Maker
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Doesn't start up properly...
Actually I decided to day to deliver to a service point for Saeco in Warsaw ,Poalnd.
Anyway ,thank's..
Best regards
Johnny
May 14, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Talea Touch - Drip Tray not raising/lowering smoothly
It can be the sensor or the engine that have to be replaced:-(
Best regards
/Mirran
Sep 08, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
Saeco Talea Touch 14-Cup Coffee Maker Logo
255 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
