I have an RCA television
The RCA television we have we can not get it to find any channels when doing a search for them when cable is hooked up directly to the cable input in the back...what do i do?
    Novelist:
    Scholar:
  • 100 Answers
Salutations mandi84,
It sounds like you may need to adjust what type of cable signal your TV accepts. Depending on how old the unit is there maybe a small switch near the cable input, or a option in your setup.
If its a switch your should have three options including STD, which is the standard setting which has adopted by cable providers.
In your menu you would be looking for an option for signal, or even a choice between Air, or Cable.
I hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 13, 2008
I just hooked up a Scott Television as a replacement for an RCA. I use Dish Network. Problem: TV screen is blank except for the words "Please scan channels." What should I do to "scan...
Go into your menu on your tv and select channel search. Make sure your cable and cords are firmly attached them start the channel search.
May 09, 2009 | Televison & Video
Cable connector broke off of the television.
You can by an RFmodulator and a set of composite cables to get the cable signal into the tv provided you have audio and video inputs. You will then need to tune tv to the proper input to view.
Hope this helps you.
Sep 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Lost the cable signal
ok you hook up dvd to what input... you hooked up sat on what =input.. do you have old vcr around.. try hooking cable to vcr and in a sense use its tuner to tune with . this will tell you if your tv has a bad tuner... just hook the vcr to the same input the sat or dvd player is on
May 09, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
May 01, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Programming digital channels
The problem is not with your TV. You need a digital box to unscramble the channels.
Oct 28, 2007 | RCA HD52W56 52" Rear Projection HDTV
Pip
Take the cable wire that hooks to the IN connector on your cable box and hook it to the IN connector on a 2-way cable splitter.Get 2 more short cable wires and hook one end to the OUT connector on the splitter and the other end to the IN connector on the cable box.Take the other short wire and hook it to the other OUT connector on the splitter then hook the other end of this wire to your tv (you must have two sets of RF connectors on your tv for this to work)Or you can tap the A/V connector off your cable box hooked to a video input on your tv.
Aug 19, 2007 | RCA P52930BL 52" Rear Projection...
RCA MM61110 Television
I had the same problem sometimes when my Gold Plus would reset itself and include all the channels but only those Over-The-Air channels. The only way I could change the programming was to completely shut down the power. Not just turning the tv off but completely unplugging it from the wall outlet. When you turn your tv back on you'll be able to choose from Antenna/Cable option. As for Guide,if you don't want to use it, don't set it up, it won't effect anything else on the television.
Aug 08, 2007 | RCA MM61110 61" Rear Projection Television
Remote not working
Hi Suzanne. What you need to do first is get or have the original RCA remote available. next, go into the menu and do whats called a channel search, but you will need an antenna or cable line attached to the RF input of the TV set, Do whats called an auto search. Let the set complete its cycle. If it found no channels, then there is no input sourch or you have a bad tuner or its assoicitated componets. it should be in the owners manual on how to do this. If you do not have an owners manual, get one here http://www.thomsonnetwork.com/EN/Public/InstructionBook/IBSearchResults?querytext=P5292*&brands=RCA%2cGE%2cPROSCAN%2cRECOTON%2cSPIKEMASTER%2cAR%2cJENSEN%2cAMBICO%2cADVENT%2cUNBRANDED&doctypes=IB&categories=ACCESSORIES%2cAUDIO%2cCOMMUNICATION%2cDTVS%2cDVD%2cMULTIMEDIA%2cCOLOR_TV%2cVIDEO&firstdocnum=1 If you need a new remote or original replacement please go to http://remotes.com Good Luck please do not forget to rate this thread.
Oct 22, 2006 | RCA P52921 52" Rear Projection Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
