Question about Daewoo Televison & Video
I have a Daewoo dlt37c3ftb, I have braught a wall mount for the tv but I am unable to remove the stand. On my other tv it just slides off. Please can you tell me how to take off the foot stand. kind regards M Instone
tvtek
  • 1284 Answers
SOURCE: Stand
You should see at least 4 large phillips head or box headed screws tha hold the stand in place.
Posted on Mar 10, 2007
SOURCE: how to remove the stand from samsung LCD TV
Place the tv on its screen flat on a soft surface,
you need to remove all the screws, not just the stand one marked.
Lift the back panel and then you will be able to slide down the stand, when you have removed the back cover you will also see where how your wall mount will fit to the chassis.
Place all the screws back on the back lid.
Posted on Feb 09, 2008
SOURCE: Can not remove the stand to mount it on the wall
If the Aquos 46 is anything like the Aquos 42, the monitor is attached to the base with machine screws (bolts). They are located in the lower back portion of the monitor, probably need an Allen wrench to loosen and remove. Once that is done, the base can be removed from the monitor. Best way is to lay the monitor face down on a tabletop padded with foam, a quilt or blanket, etc to protect the screen as you work. Remove the stand from the monitor, not the monitor from the stand; it is easier and safer that way.
Posted on Jan 24, 2009
  • 8457 Answers
SOURCE: How to remove the table top stand for wall mounting?
Take all the screws out of the base,might require an Alan wrench.Take mellet make a couple taps.Should pull the base right out.
Posted on Feb 07, 2010
SOURCE: removal of flat screen pedestal so I can wall mount tv
There a 4 set screws on the back of the TV. There is actually an arrow pointing down to show you what direction the pedestal. Remove thesze screws and the pedestal comes right off.
Posted on Dec 27, 2010
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
HAVE A SHARP 52" LCD #LC52D65U AND I CAN'T FIGURE OUT HOW TO REMOVE THE STAND SO I CAN MOUNT IT ON MY WALL. PLEASE HELP ME
On the back of your TV, there are 4 long hex bolts. It should have triangles pointing towards the holes. Take the 4 long hex bolts out and the stand itself should slide out with no problems.
May 21, 2009 | Sharp AQUOS 52" Flat-Panel LCD HDTV
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
I want to wall mount my 26LB30QD but the stand needs to come off, there is nothing in the instuctions on how to remove the stand, please advise.
With the tv laying flat on to the screen, remove the two screws in the recessed holes. Then remove the two screws above towards the input panel, one under AUDIO-L/AUDIO-R and the one under HDMI-1. The stand should easily slide out.
Mar 06, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Jul 11, 2008 | Televison & Video
Cannot Remove Stand From TV
There should be two screws on the back of the television toward the bottom. If you remove those you should be able to slide out the stand for wall mounting. But please be careful. If you damage the television attempting this then you can lose your warranty. The manufacturer recommends professional installation only for mounting your television to the wall. Good luck. :)
Jun 20, 2008 | RCA Televison & Video
Removal of stand to wall mount tv.
Slide clips are used on a lot of these sets, and they require a small, flat blade to release the catch on both sides to allow removal...accordianman
Mar 09, 2008 | Televison & Video
How to remove the stand from samsung LCD TV
Feb 07, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Televison & Video Logo
57 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
