Question about Konica Minolta Bizhub-200 Minolta Printer
Hi! My Minolta C200 does not give me an option to print duplex (back to back) files. It states that I need memory of 512mb but my computer has sufficient memory. How can I rectify this?
It means you copier needs 512mb the likely cause is that the accessories have not been installed under the printer properties go to properties
Posted on Sep 15, 2010
  • 6 more comments
  • carpediemweb Feb 10, 2011
    in the option of your printer, in the tab 'settings' memory file must be put on 512 MB, then the duplex accesory in this tab will be available. then u will be able to print in duplex mode.
  • Pitt4U Apr 01, 2011
    Where is this option in WIndows 7?
    I am having the same issue but on a windows 7 machine. Those options are not available to choose from. The memory file option is not available under settings...
    Here is the full solution on a Windows 7 machine with Office 2007
    Duplex Printing on a Konica C200 on Windows 7 Word 2007
    1. Click Start/Windows Icon
    2. Click Devices and Printers
    3. Right Click on the Konica C200 printer Icon then click Printer properties
    4. Within Printer properties Click on the Configure tab.
    5. On the Configure tab within the Device options section highlight Duplex Unit and Select En able under Settings. Click Apply.
    6. Then on the Configure tab under the Device Options section Highlight File Memory. Under Settings click 512MB. Click Apply. Then OK.
    7. To print the document open the document Click the Office Icon and click Print
    8. Then click Properties.
    9. On the Layout tab under Print Type select 2 Sided then OK.
    10. On the print window Click OK to print
  • carpediemweb Apr 02, 2011
    These option are in PRINTER properties, not in PROPERTIES. for Windows 7, you had to right click on the printers and then select "Printer Properties" in the menu that appears. if you have seelcted properties, you had only the properties of the "print server' which is the function that enable the printing on any printers' ... seehttp://http://dodisdodat.com/dodisdodat_...
    http://dodisdodat.com/dodisdodat_img/Win...
    http://dodisdodat.com/dodisdodat_img/Win... (next msg to see the foloows..)
    (end of the address) 40/Windows7Sharing012.jpg
Abort code
contact service use go to www.konicaminolta.com
Oct 06, 2012 | Genuine Konica Minolta Konica Minolta...
Please i want to know if konica minolta magicolor 1690mf is wireless printer? and how do i set the two sided print.
The Konica Magicolor 1690MF Printer/Copier/Scanner is connected with an Ethernet Cable or USB Cable. It is not equipped to operate as a wirleless printer. It has a 10Base-T/100Base-TX Ethernet interface port and a USB Revision 2.0 High-Speed compliant port.
To do two-sided printing you must have the duplex (double-sided) option installed. This also requires either Tray 2 or the Attachment to be installed underneath your machine. Tray 2 is the optional lower feeder unit which increases capcity of your machine to 500 pages. The Attachment comes with the Duplex Unit.
Only Letter and A4 plain paper (16-20 lb bond) can be autoduplexed. With the duplex accessory installed you can do duplex or double-sided printing automatically.
From within Printer Preferences select Two-side Printing > Automatic. Shoud have choices of Off, Manual or Automatic. Within the Layout Tab for your work you may also be able to specify duplex (double-sided).
Should you have continued difficulty, please reply and advi e if the duplex option is installed and with which software and operating sysytem you are using.
Thank you for using FixYa!
Sep 19, 2011 | Konica Minolta magicolor 1690MF All-In-One...
Konica minolta c200 in network i want to scan in ubuntu 10.10
1 Download irfanview software from google and install it on your computer. 2 Now open the installed software. 3 click on file tab which is the first tab on the left. 4 Now bring cursor down and click on the 3rd last option which is select twain source. 5 Now you will see konica minolta c200 scanner in option menu. 6 select it and press ok 7 now again click on file tab and then click on acquire batch scanning option 8 place the document which you want to scan in pohtocopier machine and press ok from software. 9 scanning will commence and save in your computer c drive. usb cable or network cable must be connected with your system and machine. All the best
Mar 11, 2011 | Minolta bizhub 200 All-In-One Printer
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
Nov 17, 2010 | Konica Minolta Magicolor 5450 Printer
I am trying to print a 2 sided booklet and it says my duplex is not installed. How can I install it?
Does your printer have an optional "duplexer" ?
It's an extra-cost hardware option to "flip" the paper over, and feed it back into the printer, to allow printing on the "back" of the sheet.
Buy the duplexing hardware, and connect it to your printer.
May 28, 2010 | Konica Minolta bizhub C351 All-In-One...
I'm wanting to print two sided copies from my computer to the Konica Minolta c350 and can't find a setting that allows me to do so.
It's possible that you don't have all of the drivers installed.
In some cases, there is a simple driver and then a more complex one (such as an EFI Fiery) that will open up the rest of the printing/finishing options for you.
If you've delved into the printer "properties" and "advanced" buttons with no luck (be sure to look for the word DUPLEX), then I'd look into an updated driver.
Oct 13, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Cannot print in duplex
Go to Option, in driver and be sure that the Duplex Option is installed.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Jun 01, 2009 | Konica Minolta bizhub 250 All-In-One Laser...
Printing failed when running big files from computer to copier
hi
try to change the speed of your copier lancard to 10mbps full duplex
Dec 22, 2008 | Konica Minolta DiALTA CF910 Copier
Trouble with duplex printing
I think your problem is that the 5550 supports manual duplex printing. Print every other page then feed them through again. Never tried it though. Dave Reed
May 23, 2008 | HP LaserJet 5550 Printer
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
891 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
