Question about Sanyo DS31520 31" TV
Sanyo DS35590 I was told by a tv repairman that the fuse may be bad in my tv because there is no power. However, I know nothing about tv's and I do not know what a fuse would look like. Can someone tell me what to look for so I can replace it myself?
  • Anonymous Aug 15, 2008
    This morning when we turned on our TV there was a solid line in the
    middle of our TV screen where you could see the picture. But the
    picture could only be seen in that thin line across the middle
    of the screen. You can also hear the TV just fine.
It would be a little glass tube with a filament in it. To locate it you will have to take the back cover of your television off, follow the power cord up to where it connects. The fuse will be located very close to the power connection, look carefully.
Posted on May 13, 2008
The power light will come on for about 18 seconds then goes off and then comes back on and goes off etc.
It sounds like your power supply is cycling. Check power supply output and replace. I've been told by a TV repairman that the power supply (and motherboard) in smaller sets is the same as yours.
Oct 29, 2013 | Sanyo 42 in. LCD TV
Sanyo 35 tvmodel # DS35590 horizontal output gets hot
Maybe the flyback are in bad conditions or the ceramic capacitor near the output check him bott
Jul 24, 2010 | Sanyo Televison & Video
Toshiba 65H82 that is showing red and green like an old 3-D movie. Was told it is probably a convergence circuit by tv repairman over the phone. Where can I get one & is this common?
Try adjusting the convergence from the second page of the menu. If this doesn't work then you may have to fix it.
If you are handy and know how to solder it isn't very difficult.
The circuit in question is an integrated circuit. It is a large IC mounted to a heat sink on the left hand board when viewed from the back.
Newark electronics has very good prices for the Sanyo STK's. I wouldn't recommend buying the cheapest one you can find because it will be a copy and go bad again. If you have STK392-110 or 120 or 150 then the STK392-180 can be used. It has a higher rating and only costs $10 at newark.com.
You should replace both STK's and check the resistors near the heat sink and the fuses on the power board. Also check all of the solder joints.
Newark electronics has very good prices for the Sanyo STK's. I wouldn't recommend buying the cheapest one you can find because it will be a copy and go bad again. The STK392-180 can be used. It has a higher rating and only costs $10 at newark.com.
Jan 19, 2010 | Toshiba 65H82 65" Rear Projection...
Sanyo tv ds35590 main board
that big wire is for the degauzing coil, connect it by plugging it to the main board near the power supply section.there are 2 terminal which is near to the thermistor.
Oct 20, 2008 | Televison & Video
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Jan 17, 2008 | Televison & Video
Sanyo DS35590 35" CRT Television
are you replacing the compasator PHE 820 M it is blue rectangle next to the fuse
Jan 14, 2008 | Sharp 27C-240 27" TV
Dead tv
your tv needs a repair man near you, the problem is its malfunctioning power supply. I believe some electronic parts must be replaced.
Nov 25, 2007 | Televison & Video
Need some help here
that is one of your problem when any component burn in side a set it means that the tv have a short.getting excessive current.if you are not a tech have a repairman check your set and repair it the power supply or the horizontal out put circuit has a short.good luck.
Mar 29, 2007 | Sanyo DS31520 31" TV
Motorboat sound
problem in the power supply a filter cap is bad check the repairman to locate the bad cap good luck.
Dec 09, 2006 | Sanyo DS27820 27" TV
No nothing
I am sure it can be repair,Checking the fuse was good idea but it seems the problem might be farther ahead,if you have no indication of power(no lights,no clicks)the problem might be in the power supply,there is a 5 volts supply that has to be running because is the power to the microprocessor(brain)and when you push the power button on the remote or the set the brain knows it and send the commands to everyone else to turn on,if you have the 5 volts and the brain is working the problem might be in the horizontal circuit ,possibly a bad horizontal output transistor(shorted)if he is bad it might have taken a fuse or a safety resitor.Some fuses dont look like the average fuse,they look more like resistors.If you are familiar with tv service We can give you all the help you need to find the problem ,if you are not too familiar with servicing electronics you might want to call servicer.Let Us know if you need more information.
Oct 27, 2006 | Sanyo DS31520 31" TV
Sanyo DS31520 31" TV Logo
218 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
