Question about Kitchen Ranges
Hi i have a beko wm7127w every time i put a wash on it locks the door but dose not fill with water and shortly after says end
SOURCE: beko dishwasher fills with water, does not wash but will drain the water away
impellor buggered. Needs replacing
Posted on Apr 12, 2008
SOURCE: Door Lock LED flashing
The solution from testy helped me but I decided to change it.
I cut the plastic latch away from the end of the interlock,just the little bar that holds the door closed.This means that the lock position doesn't affect the door.
I then used the little piece of plastic to act as 2 packing pieces to hold the lock half closed. This works fine.
Don't push the lock fully closed or it doesn't work
Posted on Nov 29, 2008
  • 1082 Answers
SOURCE: Hi cold water is very
I assume this is a clothing washer, not a Kitchen Range.
It is likely one of two possible problems. Either there is some debris (rust, minerals etc) partially blocking the inlet valve, or the inlet valve is malfunctioning and not opening correctly.
Where the cold water hose attaches to the machine is the inlet valve. This will have a small wire basket filter in it. You should turn off the cold water at the wall side of the hose. (Turn off both to be safe. Disconnect the cold hose from machine. Expect to see some residual water from hose, and possibly a seepage continuing as the shut off faucets are not usually great. You'll probably need some channel lock pliers to loosen the connection. Just unscrews.
When you remove the hose from the valve, see if any blockage at the wire filter. If it looks fairly clear, then the valve itself is probably faulty and needs replacement. If lot of crud in there, pick and clean it out as best you can. Do not try to remove or open up the wire filter or you will have trouble inlet valve. Replace hose making sure to include the rubber washer, and tighen with the pliers.
Good luck.
Often the hot and cold valves are one unit. and replaced together.
Posted on Dec 21, 2010
  • 12 Answers
SOURCE: My Beko washing machine switches
sounds like circuit board is faulty
Posted on Jan 20, 2011
  • 6277 Answers
SOURCE: Hi, I have a Beko wm6123w
There is a separate motor for all of the draining parts of the cycles.
I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 25, 2011
Testimonial: "Thank you John...wasn't expecting anybody to come back to me or as quickly! I will try now."
My nanussi washing machine won't fill with water, when i put in onto a cycle it sounds like water is filling then it clicks off 1min later. Drier seems to working fine.
HI lisa
Have you moved your machine recently ? It sounds like it could be the drain outlet hose that is too low and the water is syphoning away If your machine dose not fill within a preset time it will stop. Is there any error codes or flashing lights.If water is going into the machine and the tub is not filling check that the end of the drain outlet hose is no lower than the centre of the door.
May 25, 2016 | Washing Machines
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Jan 28, 2014 | Beko Washing Machines
Beko washing machine WME8227B. Switch on power, set programme ,press start button, hear the door lock (noticed that the padlock symbol isn't on as nomal) no water flows , checked manual eg child lock, time...
Probably a fault with the lock or latch; should be no problem for an engineer to fix. Just try giving the door a firm push to close it, to see if the padlock light comes on.
Jan 10, 2018 | Beko Washing Machines
Washing machine wont spin (beko 1512 s)
Hi if your beko 1512 s washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Mar 19, 2009 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Sep 05, 2008 | Indesit W 123 Front Load Washer
Beko 2431 dishwasher not working
I have the same problem
dishwasher seems to try to wash but not get anywhere.
have tried tipping dishwasher to empty excess water out, filters and arms cleaned.
dishwasher just takes in water, hums for a bit and then the cycle ends after about 20 mins but obviously dishes are not clean
Jun 05, 2008 | Beko 24 in. D3421F Free-standing...
Wont wash
The water level sensing switch could be stuck or not functioning and therefore not cutting off the water when it reaches the correct level and starting the wash cycle.
Sep 24, 2007 | Beko 24 in. D3421F Free-standing...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
