Question about Bosch Exxcel KGV35421 Bottom Freezer Refrigerator
Bosch frost free fridge freezer
I have a Bosch frost free freeer which will not maintain it's temp. The alarm keeps coming on and the temp keeps droping when you put it onto super it will only go as far as 19.then drops again when you take it off I have aquired a new circuit board not sure if it is what has gone but is worth a try but am unable to find where the old one is located so that I can change it. I would welcome any help on this matter
  • Anonymous Apr 24, 2009
    I have the same problem on a KJU3201gb/01 fridge freezer. Fridge temp stable at 4 degrees, but freezer temp hovers around 2 degress unless switched to super. As soon as super setting switched off reverts back to 2 degrees. Is this a circuit board problem?
    Genius:
  • 1,036 Answers
The circuit board is fitted behind the display right at the top.
Unplug.
Open fridge, undo the two screws under the display moulding.
Using a thin bladed scraper and a flat screwdiver, prise the panel off at the top join. The top is the only bit with plastc clips, but it will help to apply pressure with the screwdriver at one end as well.
Pull it forward by about 2", and remove the connectors to the on switch.
There may be a drip strip to remove before taking the board out.
Use a thin screwdriver to remove the retaining clip over the board.
Use a small flat screwdriver to lever the board out using he holes at each end.
Observe anti-static precautions as it contains Cmos chips.
Reverse procedure to replace.
Posted on Dec 31, 2008
My whirlpool frost free fridge freezer's alarm keeps going off, ice-cream doesn't freeze?
Check condenser is clean, fans working, thermostat set correctly, try to check internal temp with digital thermometer
May 17, 2012 | Refrigerators
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
Bosch Fridge Freezer KGU3200GB/01 alarm beeping temp rising
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 26, 2010 | Freezers
Frost free fridge freezer the fridge isnt staying cold we have tried turning the temp up and down but it makes hardly any difference.
you need to find out what going on in the freezer,is the fan running?is there frost on the back wall?let me kn ow and we can go from there,mike
Sep 12, 2008 | Bosch Refrigerators
Bosch KGU44120 frost free fridge freezer (6 years old) generates ice on floor of freezer compartment within a couple of hours. Maintains -20C temperature no problem.
drain is blocked in freezer. take back panel off inside the freezer and you will probably find that the bottom is covered with ice. melt off with a hairdryer and hot water till water flows freely down the drain. needs a bit of patience
Jul 04, 2008 | Bosch Refrigerators
Freezer not working
same problem but electronic temperture on in fridge but keeps flashing
Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
Bosch KGU32160 fridge freezer
The compressor behind the fridge should cycle on and off as the machine maintains temperature, but the evaporator fan inside the freezer will keep running, except when the fridge goes into defrost. If the noise is coming from the fan inside the freezer, there could be some ice on the frame of the fan and the blades are touching the ice. If the noise is coming from behind the fridge it could be the condensor fan motor. This fan is situated behind the fridge in front of or next to the compressor. It keeps the condensor cool by blowing air onto it. Check this fan. The blades could be touching the pipework or something.
Oct 31, 2007 | Bosch KGU32124 Bottom Freezer Refrigerator
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Bosch Exxcel KGV35421 Bottom Freezer Refrigerator Logo
1,471 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
