Question about Maytag Ovens
Door will not unlock after cleaning. Showing F1 on control panel
  • 1,555 Answers
This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Sep 07, 2010
Unlock oven door on model #FGGS3065PF
If the oven display is showing LOC, then the lockout feature was enabled. Press and hold the key pad with the padlock symbol for 3+ seconds. This is just below the Timer On/Off key pad and to the right of the Light key pad. You should see the word DOOR and the padlock icon flash until the door is unlocked and the control panel is released.
If the word DOOR and the padlock icon are lit, then the oven is in the self-clean mode. The lock should release after you cancel the self-cleaning cycle by pressing off and the oven cools down (at least one hour). Unfortunately, sometimes the heat of the self-clean cycle will damage the oven. Either the oven temperature sensor will not give the release signal or the door lock will not disengage. In that case, the oven needs to have the correct part serviced.
The documentation for the Frigidaire FGGS3065PF is available on the product page at Home Depot: https://www.homedepot.com/p/Frigidaire-Gallery-30-in-4-5-cu-ft-Slide-In-Gas-Range-with-Self-Cleaning-Convection-Oven-in-Stainless-FGGS3065PF/204759413 . See page 15 for the Oven Lockout feature. See page 28 for the self-cleaning information.
I hope this helps.
Feb 13, 2018 | Ovens
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
Replace switch if defective
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Kemc377. Why is it showing error code?
F1 DOOR SWITCH
F2 KEYPAD
F3 TEMPERATURE SENSOR
F4 MEAT PROBE SHORTED
F8 SELF CLEAN LATCH PROBLEM
All other errors, replace the main oven control
Aug 23, 2015 | KitchenAid Ovens
Oven door locked - display shows F5:E7
Hello there and thank you for choosing fixya
These codes normally show up during the cleaning cycle this is due to the extreem heat used during the self clean operation
Now to fix this is not too hard providing the sensor for the temperature has not been damaged due to the heat
Unplug the oven and leave it sit for 1 hour and do not touch there is a internal reset feature on these ovens that take 1 hour to reset once the hour is up plug in the oven and you may hear a audiable click sound or a buzz sound if so great then all you have to do is to press the cancel or off button then after 5 min attempt to unlock the door
if it does unlock and one of these error codes are still showing this means the the controle panel has suffered some damage and needs to be replace
I have seen brand new ovens have the controle panel fail after the first self clean operation because the parts inside of it fail due to the extreem heat ok?
Hope this helps
Best regards Michael
Apr 20, 2011 | Ovens
Jenn air oven door locked after getting an F1 message after the self cleaning was done..help i cant unlock it
F1 touch pad / ERC test This simple test will help determine
(Clock).
Dec 10, 2010 | Jenn-Air JJW8530C Expressions Collection...
After cleaning the oven the fan runs and we get an F1 code, the door will not unlock.
(Clock).
Dec 08, 2010 | Jenn-Air JMW8330DA Electric Double Oven
F1...
hello,
what this code mean is an error code indicating that there is a lost of connection on the door or on the control panel meaning that the door is not properly close
thank you and thanks for using fixya.
Jul 09, 2010 | Maytag Ovens
After self-cleaning, door won't unlock
This is a common problem when people use that feature, it often "Blows" the Thermistor, which is indeed what F1 means it must be replaced, sometimes a restart, off/and ON again at the unit and cycle the breaker.
Mar 13, 2010 | Ovens
F1 WILL NOT UNLOCK AFTER CLEANING
this is a main control board fault code and you need to replace the main control board
Feb 22, 2010 | Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
F9 Program with door circuit Check wiring
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
F9 Door Latch Error Check latch
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
F9 Door Latch Error Check latch and latch circuit
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 18, 2009 | Ovens
Ovens Logo
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
