Question about Nokia 7610 Supernova Cell Phone
How to stop "Allow network access" in nokia2700
CAN I USE NOKIA2700 C IN CDMA
No, You cant.
Nokia 2700c only support GSM network.
Nov 26, 2011 | Nokia Classic 2700 Cell Phone
How to activate the gprs of nokia2700?
Activating GPRS is a network specific procedure. Contact your mobile operator and request them to activate gprs on your number and also ask them to send the configuration settings applicable for your handset.
Oct 27, 2011 | Nokia Classic 2700 Cell Phone
How to stop 'allow network access' pop up window in nokia 7610 supernova. Its very annoying that it always comes in between when i am surfing the net.
you download the java software first before you can run: on the phone to find your JAVA applications. Then select the section to stop the application software, press the left soft key operation, go to see the applications access the. Application access - communication - network access, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - communication - data interchange, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - data access - read user data, select Always allow the software without authorization certificate for each inquiry to the election.
application software access - data access - increased selection and editing of data is always permitted, the software did not authorize the certificate to select Always ask.
need to read the phone system, network or application software to download the JAD is authorized with the certificate.
this way can avoid the use of mobile phones, java software, always prompt " allow network access " this problem, this method is suitable for the Nokia S40 operating system models.
Aug 14, 2010 | Nokia 7610 Supernova Cell Phone
I want to change my nokia 2700 classics gprs settings any 1 can help me??
hi, go to settings on your phone click on connectivity add new gprs profile but you need to know the APN access point name of the network and the working ip address for it to work
Jun 13, 2010 | Nokia Classic 2700 Cell Phone
The Wireless setting does not allow me to turn it on
there is a wireless switch on the front of the notebook..try to switch it ON...
May 24, 2010 | Lenovo ThinkPad R60 with Wireless Wide...
Allow guest to logi into my network
You want to allow guests to access the Internet.
is it a wireless network ?
If there is any security on the wireless network then you will need to check the wireless settings of the router.
you will need to access the router set up page.
Click here for more info about wireless
Nov 27, 2009 | Belkin Computers & Internet
Open Port Sonicwall
1. If the port is to be opened for internal people to access the port outside the network, add a firewall allow policy in Firewall -> Access Rules -> LAN->WAN
2. If the port is to be opened for external people to access the port in the network, add a firewall allow policy in Firewall -> Access Rules -> WAN->LAN
Jul 13, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
Excellent Wireless Network Connection, cannot access internet
The unsecure public network nay be using mac address filtering. In this case, the network will show as being unsecured, and will even allow you to connect in some cases, but then will not allow you to surf once connected.
May 28, 2009 | D-Link Air DWL 650 802.11b Wireless...
BEFSX41 and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Nokia 7610 Supernova Cell Phone Logo
90 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
