Question about Toaster Ovens
I need a manual for my technika oven model TU950TME8. so i know what the different settings are for for cooking
How do I cook in this oven??
Great question, there are thousands of Toaster Ovens out there and they are not the same. Without knowing what you have your question cannot be answered. Please add make and model and somebody should help you.
Dec 01, 2014 | Toaster Ovens
Need knob for a To289. Want the Function on can't find out where to get it
I just bought mine today. customer service# 1.800.798.7398
1031KG timer knob, 1032KG function knob, 1033KG temp knob.
$1 each plus reasonable shipping. This is the second set I have purchased since I bought my Euro Pro 6 years ago. They are owned by the Shark Co now which might be why it's hard to find this information.
Jan 06, 2011 | Euro-Pro EuroPro 6Slice Toaster Oven with...
Received a B&D Convection,Toaster,Rotissere oven but did not get a operator's manual and am not familiar with the convection operation. Can I get a manual? I believe this oven is about 2 years old but...
Try the following site: http://useandcaremanuals.com/SearchManuals.aspx?SiteID=4 . Then scroll down or use the Find feature of your browser (under Edit). You want the manual for the TRO200 and TRO300 series toaster ovens for the TRO355. If you have a different model which seems likely (since the TRO300 series aren't convection models), scroll through the list for one that matches the TRO and either the whole model number or the first digit or two. (Usually the model number is on the back of the toaster oven on a plaque with the serial number.)
I hope this helps.
Dec 17, 2010 | Black & Decker TRO355 Toast-R-Oven 1550...
Need manuel and cook book for hamilton beach toaster oven/convect
I( need a instruction manual for model # 31175 also a broiler pan
Jul 17, 2010 | Hamilton Beach 31175 Extra Large Toaster...
Manual for turbo-oven
I have this manual. I have been using this oven for almost 30 years. (I love it!) However, I'm having trouble with internet connections at the moment. As soon as I can get a good connection again, I will scan the manual and upload it here for those of you who need it.
Sep 06, 2009 | Farberware T490C 1500 Watts Toaster Oven...
Farberware Turbo Oven -- Model 360 + Manual
The only thing you have to know is that pork and chicken cook at 325. Any baked goods with leavening in it cooks at 75 degrees less than what the recipes calls for but no lower than 275.
Feb 16, 2009 | Farberware T490C 1500 Watts Toaster Oven...
I need a user manual for a Euro Pro Extra Large Toaster Oven
It shouldn't be a problem. You just use it like a regular oven and like a regular oven, you have to watch what you cook the first few times to be sure how it cooks. A regular gas or electric oven will be off by up to 50 degrees EITHER WAY (100 degree variable) from the factory. Toaster ovens are generally accurate to within about 10 degrees of the setting. Mainly the time it takes to cook something will be the only adjustment you should need.
Feb 05, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
Need to activater self-clean
Every self-cleaning oven is different. It's best to consult the owner's manual for the correct procedure for your oven. But often the steps are:
  1. Set the Start time for the time you want the cleaning to begin.
  2. Set the Stop time to a time 2-3 hours after the start time.
  3. Close and latch the oven door.
  4. Set the selector switch and/or thermostat to "Clean."
Jan 09, 2009 | Farberware FAC900R Toaster Oven with...
Turbo oven model T-4850
I have two tubo ovens. Would anyone know if they are all supposed to "ding" or "ring" when the timer goes off. My one does. Bought both used at a thrift store diff times
Mar 06, 2008 | Farberware T490C 1500 Watts Toaster Oven...
What is exactly a toaster oven?
A toaster oven is a cross between a toaster and an oven. But unlike a toast, you can cook things in it like you would on a regular oven. It might also be more comfortable than a regular oven, because it heats up faster and saves energy. I even bake cookies in it! The only problem is that it is usually much smaller than a standard oven, so you probably won't be able to bake a birthday cake or a roast in it. Other than that, it's a very useful device. have fun!
Aug 06, 2007 | Cuisinart TOB-30 Toaster Oven with...
Toaster Ovens Logo
184 people viewed this question
Top Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dave
Dave
Are you a Toaster Oven Expert? Answer questions, earn points and help others
