Unusable Signal for PS2
I have a RCA Stereo Monitor Colortrak Plus with the red yellow white inputs in the back. I tried hooking my PS2 in and since there is no TV/Video button I checked all the basic channels like 2,3,4,5--didnt work, then I bought a universal remote and hit the TV/Video button but all that popped up was a black screen saying "unusable signal". What's the problem and what to do???
  • Anonymous May 20, 2008
    I go to play dvd player and press dvd and says vid 1 and in screen unusable signal
  • Anonymous Mar 30, 2014
    How to hook up an RCA gem star plus to direct tv getting an unusable signal
    Problem Solver:
  • 15 Answers
If you want to use a PS2 with an RCA stereo monitor Colortrak plus television, folllow these steps:
1.Buy a universal remote compatible with RCA televisions if you don't have the original.
2.If your remote needs programming, program it with the manual provided.
3.Goto Menu
4.Goto Alarm
5.Goto Alarm Channel
6.Set Alarm Channel to 00
7.Exit Menu
8.Goto channel 00 on the television by using the remote.
9.You should be in AV mode, and able to play your PS2.
P.S. I don't know if you need to set Alarm Channel to 00, but that's how i did it.
Posted on May 26, 2008
Rca unusable signal
Your TV could be on the wrong input source. if your using red/white/yellow cables look for an inpout button or source or even TV/Video. your tV has many inputs on it and you can only acess them 1 at a time, this allows you to toggle through the input sources and when you get to the right on you'll have picture and sound
Sep 29, 2013 | RCA Televison & Video
How can i play ps2 on lcd without having a black and white screen ? how can i connect the cables ?.....when i look at the back of my lcd i find three ports (red white yellow) when i use them the screen is...
1) The set of input (Yellow= Composite video, Red= Right channel audio, White= Left channel audio). This set of input is for composite video.
2) The set of input (Red= Red video signal, Green= Green video signal + sync, Blue= Blue signal, Red= Right channel audio, White = Left channel audio (the Red and White will be grouped close together). This set of input is used for Component video for HD signal.
You should try using composite video source (Yellow RCA jack) from DVD player and feed to the monitor and see if it works OK with all color showing that way we acn find out if it is the video source problem or the monitor video signal processing problem. Try the PS2 on the TV if it works OK also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 20, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
Is i possible to connect a rca cable to the converter box from a dvd player and watch on the tv?
DVD players can have several outputs:
* coaxiable cable
* composite video (RED/WHITE for stereo audio, and YELLOW for video)
* component video (RED/BLUE/GREEN to video components, plus RED/WHITE for stereo audio)
* HDMI
TVs can have several inputs:
* coaxiable cable
* HDMI
Just use the correct tables to "match" the output to the input.
Feb 21, 2011 | RCA (DTA800B1) Video Converter
Trying to connect ps2 to samsung syncmaster have connected the red and whie cables but all i get is a fuzzy black and white picture - do i need a different cable??
Is the cable you are using a set of Yellow, Red & White cables? If so do you have them plugged into the ports on the "side" of the Monitor? or are you trying to use the ports on the back?
It should be hooked up to the ports on the side.
Jan 05, 2011 | Samsung SyncMaster 940MG 19" LCD Monitor
How do I hook up my Wii to my 32" Emerson lcd hd tv? I have my dishnetwork satellite hooked into the dvd player and it's hooked up to the TV. On my remote I don't see a "game" button like my older Emerson...
I found a better way and it works fine. I have a new 32 inch Emerson, with only one composit hood up ( which won't work with the wii) 2 HDMI's ( again does not hook up to the wii, the monitor hook up for PC, red and white ( yellow plus is not there it's for a stereo they told me), and the usb hook up ( which is more for pictures I was told by the company).The answer was to hook my RCA plus to the red and white under the composite, then hook the yellow into the green plug of the composite, and behold- my will now works fine.
May 04, 2010 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
How do I hook up my Wii Console to my new Emerson
Dec 22, 2009 | Nintendo Wii Console
I have connected my PS2 to my TV using the Red, White, and Yellow cables but when I hit the source button the screen just says "no signal". I know that the PS2 is working because I have recently used it...
It is possible that the RCA cable is no good. The yellow = video, the red and white = audio. The input on the TV may be bad, try switching from one input on the TV to another if you have one available. Even if you don't have a free one, remove a DVD player or something else that may be hooked up and try to hook up the Playstation to that input using those RCA wires. This way you can eliminate the port and the wire being bad at the same time. If all else fails and the PS2 works on other TVs, the only option left would be a problem with the TV you are trying to hook it up to. I have that problem on one TV I own, one of the RCA inputs (input 4) is no good. I hope this helps.
Oct 26, 2009 | Samsung LN22A330 22 in. LCD TV
TV does not recognize PS2 input
On the TV you should have a video, input or mode button. If you press that button while the PS2 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Mar 21, 2008 | Emerson EWF2004 20" TV
Trying to get ps2 to play on new tv..
USE a VCR between the PS2 and the Sylvania TV.  Hook the PS2 A/V cable RCA connectors( Red, Yellow, White) to one of the the Video input RCA connectors( Yellow, Red, White) on the VCR. Hook the VCR Cable output to your Sylvania Cable input. Set the Sylvania Tv to channel 3 or 4.  Set the VCR channel to Line 1 or Line 2.  This should work. I hope it helps you.
Oct 12, 2007 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
1,966 people viewed this question
Top Televison & Video Experts
Electro Med Services...
