Question about Car Audio & Video
Ace caravan battery
Could someone please help me? I have just bought a 1983/4 ace globetrotter caravan, everythings great on it (including the 240v hook up) but I have one major problem, I cant find the battery, I have looked every place possible but no battery and no terminals either, the van is fitted with a zig unit but theres just no sign of any battery or even any place for it, in the owners guide it states to open the battery door with key provided, what door? there is no doors outside the van at all, PLEASE CAN SOMEONE HELP
JohnWebber
Battery, if fitted is under the front LHS seat on mine
Dave.
Posted on Jul 22, 2008
Bought a used 1983 southwinds motorhome but no batteries. does someone have a wiring diagram for the batteries
no diagrams but the reason for duel 6 volt batteries is for proper distribution of power you can put duel 12 volt in it and it will seem to run fine but over time fueses will get weak and start to pop as well as relays. i hope this information helps. J&D services
Sep 22, 2012 | 1983 Chevrolet Suburban
2002 Honda VT 750 CD Shadow A.C.E. Deluxe how to change the shifter shaft seal
Hi, Crumbobc for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Oil Leak at Shifter shaft on 1983 GL1100 Std
How To Dirt Bike Shifter Seal Replacement
Honda 1998 VT750C Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda VT750C Owner Manual
Aug 18, 2012 | 2002 Honda VT 750 CD Shadow A.C.E. Deluxe
Stalling 22r 1983 toyota truck 22r fires up, runs great then cuts out. fuel bowl goes empty and i've replaced everything, pump, filters and cleaned tank
Check the steel fuel line under the intake manifold
had one that was almost completely clogged shut with ****
took a month of hunting but found this to be the problem
May 16, 2012 | 1983 Toyota Pickup
I bought a used item #f509040 brad/staple gun (Air Ace) It came loaded with staples. How do I load nails??
The nails fit one side same place as the staples its usually on right side but may not matter. I hope this helps please rate if the answer helps in any way. Good Luck and have a great weekend.
Apr 03, 2010 | Ace Hardware Ace Staple Gun
Service engine light
a i got a 1996 with the 3.8 dodge caravan and the codes red 12 and 55 my car wont start at all got gas in it
Jul 03, 2009 | Dodge Caravan Cars & Trucks
Wiring Diagram
May 20, 2009 | 1983 Chevrolet S-10
My license plate light wont work. i have bought a
To replace the fuse without the diagram, just look closley at the fuses and look for the one that appears melt. The little wire filament will appear melted.
Mar 04, 2009 | 1997 Dodge Caravan
1997 dodge caravan 3.3L Won't Start.
clean both cables including ground. does it dim any of the lights or do they go out when you turn key to start? make sure all connections are clean and tight and that includes hot cable on starter, and the small wire on starter. if your sure everything is clean and tight. You can try this if you know how, you can chk. starter with a screw driver by crossing the big post to small post on starter but you got to be real careful as not to weld the screw driver to the posts as your are by passing the key and comeing strate from battery, if it turns starter there, then most likely not starter, if you got acess to an external starter switch it would be safer. if that all chks. out then most likely its the starter switch under dash on steering colume. starter is not a big thing to chg. just make sure you unhook battery before you take it off.
Feb 03, 2009 | 1990 Dodge Caravan
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
