Question about Apple iMac G5 MA064LL/A Desktop
Dvd player I can't get a dvd to play. I have a g5 with a Sony DVD Super dw-10a. When I try to play a dvd all I get is "not permitted". This is the first time I've ever used an imac although I have a good bit of pc experience. Can you Help me?
    Problem Solver:
  • 13 Answers
All you need to do is stop using it for about two days or more and then try again
Posted on May 13, 2008
Why my DVDs room player cannot read while it is playing?
buy a CD/DVD lense cleaner...and clean the device...the cleaner looks as CD disk...and it has the cleaner attacehd in that....insert that and run it for some time....
now try play a CD/DVD
Feb 17, 2011 | Sony DW-D22AB : DVD+/-RW 16X Dual Layer...
Does not play DVD video or read CD RW or DVD RW. But does play audio CD.
Try on VLC player or GOM Player.
I hope that this has been very helpful for you
Nov 16, 2009 | Sony (DW-D22A/B2) DVD±RW Dual Layer...
Our dvd player no longer plays dvds. The super audio cd and multi chanel light is on and will not turn off. Every time we put a dvd in it will not play.
  1. try resetting by unplugging power of device
  2. look at the manual and see if there are any options related to audio type and multi channel modes. Try toggling to different settings if you see any related options.
Aug 26, 2009 | Sony DVP-NC80V DVD Player
Certain DVD disc can able to openSONY DVD RW DRU-810A, But I am unable to open with SONY DVD RW DW G521A. Kindly advise me to further course of action.
yes, most of the dvd recorders are like that. you must read the user guide to find the correct dvd brand to use. i have a toshiba (i can only use maxell, (best) tdk ,dynex (good) and memorex (Ok)) fuji sony pansonic will not record nor play.
http://www.supermediastore.com/dvdmedia.html blank dvds for sale
May 06, 2009 | Televison & Video
August 2005, I purchased this powermac g5. There has been a steady deterioration in the DVD player. Presently, no rented DVDs play. SONY DVD RW DW-Q28A: Firmware Revision: KAS7 Interconnect: ATAPI Burn...
OK. The movie industry strikes again! Your RENTED DVDs are the key.Hollywood made some adjustments to prevent the copying of the movies. So they put software to detect the kind of drives in which the movies are inserted. DVD/RW are capable of copying a movie, so they are disqualified as playing devices. Have it be a normal DVD player you won't be facing any troubles.
Apr 20, 2009 | Apple Power Mac G5 Desktop
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
I recorded my movies on the dw 100 but now i can't grt them to play on my dvd player
The DW-100 records discs based on the format they were originally recorded.
If your camera is recording HiDef videos than the discs this unit creates will be viewable on a Blu-ray disc player.
If your camera is recording in Standard Definition (ie. NOT HD) then I believe that the discs will work in regular or upconverting DVD players.
My Canon camcorder does not record in Standard Def so can't quite vouch for that last comment though.
Jan 06, 2009 | Canon DW 100 DVD-RW Burner
Canon DW-100
Thanks, I think it works that way. gl
Dec 08, 2008 | Canon DW 100 DVD-RW Burner
Wont play dvd movies
have you installed the appropriate codecs ? if not do a search for them from google and install them should cure the problem
cheers
Jan 23, 2008 | Sony DW-U14A 4x DVD-/+R(RW) (ELU14A)...
Sony DW-Q30A Problem
the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
May 30, 2007 | Sony (DWQ30AB2) DVD RW Dual Layer Burner
Apple iMac G5 MA064LL/A Desktop Logo
101 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
