Question about Samsung LASER Printer
Printer offine, its shared via a network how do i get it back with out uninstalling an re installing
  • accounts243 Sep 07, 2010
    Thanks for your reply, unfortunately my computer does not have that option, im on windows 7 it has the following options : if I right click from the icon I get, open, see whats printing, set as default, printing preferences, printer properties, create shortcut, troubleshoot, remove device and properties. i've been into every option and nowhere does it have an online option. I've also ran the troubleshoot which states no problems found !!! any help really would be appreciated I thought I knew my way round the basics but this has me stumped. thanks to rangaoat for the help
    thanks rangaoat, ive not got an online option, im using windows 7, I set it up yesterday and all working fine, but today it just wont work at all. the other computer on the network can print ok
    i've tried the troubleshoot option and it says windows cant find a problem. Im stumped !!
  • 360 Answers
Hello click start button on main computer and select printers and faxes icon then select your printer model and right click and select use printer online command.
Posted on Sep 07, 2010
Printer sharing
Sounds like You have it installed via network share so it's no in real term installed on your computer ,to delete it rift click in the printer icon and press delete
Oct 11, 2013 | Kyocera FS Office Equipment & Supplies
Trying to connect 4 MACs to all in one Kodak 5250 printer and will not connect via wireless. I had to set up so that the other pc's have to print from one location via hardwire. I tried installing...
If you have one PC connected to the printer via USB you can share the printer to your Mac computers easily:
If the printer is connected to a Macintosh computer via USB:
1) Open System Preferences
2) Click on Print and Fax
3) Highlight the Printer and Check the box Marked "Share This Printer On The Network"
If the printer is connected to a windows computer via USB:
1) Download "Bonjour Print Services for Windows" from Apple's website
http://support.apple.com/kb/dl999
2) Install it on the PC connected to the Printer.
3) After Installing the Above, Run the Bonjour Printer Configuration Utility and select the Printer you want to share and it will share it over the network to all your apple devices.
Mar 02, 2011 | Kodak ESP5250 All-In-One InkJet Printer
I need instuctions to hook up and network .diagram for network 5610 with 3 computers and router?
This printer does not support Network installation (Ethernet / Wireless). If you want to use this printer in network, then you have to share this printer.
Please reply for any questions
Regards
Riztech
Dec 05, 2010 | HP Officejet 5610 All-In-One InkJet...
I have an HP 2015N, and I want to share it on a PC network, so that an Apple Mac laptop can see it accross the network. I have set up printer sharing but the laptop still cant see the printer, any ideas?...
Have you connected it to PC via USB cable, or networtk wia r45/UTP? Because it's "n" I suggest conecting it via network adapter to switch and install it on others PCs like network printer.
Dec 03, 2009 | HP LaserJet P2015dn Printer
Can we share 3124 to another users in 1 network ?
Yes. One can by enabling others the access to your printers by first turning on sharing in windows, then installing the printer driver on one pc and ticking the box in the driver on that pc to allow sharing ie right click on printers icon, properties, sharing, and enable sharing tick.
Then going to other computers and installing the printer via installing netwok printer.
You cant do any of this without admin rights
Nov 04, 2009 | Xerox Phaser 3124 Printer
Print sharing
No matter how you slice it, if you want to share the printer, you will be creating a network. If I remember this printer correctly, it has an Ethernet port to connect to a network or USB to connect ot a computer. If your router supports wired connections, you can connect it there and just inistall drivers on each device and selec tthe network option. If not, you will probably want to connect it via USB to your desktop machine and enable print sharing on that machine. Te enable printer sharing, open up the Network and Sharing Center. In the Sharing and Discovery section, turn on the option for Printer Sharing. You will still need to install the XP driver on the netbook and select the network option, but give it the proper network location (ie.\\mycomputer\this printer).
May 29, 2009 | HP Photosmart C6180 All-In-One InkJet...
When I try to remove logmein from my program the computer says, "the program you are trying to use is on a network resource that is unavailable. Enter an alternate path to a folder containing the...
Can you browse to the installation source via windows explorer?
right click Start and select explore. Network resources are usually a share.
Example:
\\networkcomputer\folder\share
If you can browse to the share then copy it to your local machine and attempt the uninstall. You may have to point the uninstaller at the local file.
May 13, 2009 | Computers & Internet
I have a Brother HL2070N printer. I have 2 computers and want to share the printer. I connected the printer via the USB port to Computer 1 and it prints fine. I set the printer to SHARED. Computer 1 has...
hi there,
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
For detailed instructions on sharing printers at home, please refer to the "Get Your House In Order" article in the "See Also:" section below.
For detailed instructions on sharing printers in a small business, please refer to the "Select & Share The Right Printer For Your Small Business"
Apr 14, 2009 | Brother Office Equipment & Supplies
Wireless printing
I assume you have a wireless network set up with a wireless router, since you said you have a wireless laptop.
You need to share the printer on the desktop. You also need to set up both computers to be on the same network (for example, WORKGROUP or MSHOME, or a name of your choosing).Once shared and on the same network, you can go to the laptop and add a printer--just tell it that it is a network printer.
A caution--to work without further hassle, both computers need to be running the same version of Windows. If not, you'll need the driver disk for the system on your laptop.
Jan 16, 2009 | Computers & Internet
Printer sharing. how to do it?
In Win XP & presuming you have a network set up:
Navigate via :
Start - Control Panel - Printers and Other Hardware - View Installed Printers & Faxes.
Click on the printer icon you want to share.
In the panel on the left (Printer tasks) click on "Share this Printer"
It worked for me!
Dec 04, 2007 | Epson Aculaser C1100 Printer
Samsung LASER Printer Logo
44 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
