Question about Microwave Ovens
Bush BAF55143W how do i defrost it, manual does not say. Does water come out of it into room?
Instructions for bush bt05 mini oven
Try Googling (bush)(bt05)(manual) without parens.
Dec 10, 2017 | Microwave Ovens
How do i defrost in a prestige 3de microwave
If you don't know how to program defrost or if the unit does not have variable power settings, you can put a cup of water in next to the package you want to defrost and run the microwave for 30 seconds at a time. I don't advise defrosting meat in a microwave but I guess sometimes you have to.
Jan 30, 2015 | In Microwave Ovens
What could cause loud popping sounds?
The sounds you are hearing is the defrosted water, from auto defrosting, running onto the hot compressor. This evaporates the defrosted water. This is quite normal.
Mar 23, 2014 | Samsung RF260BEAEWW
I want to defrost my GE chest freezer but i do not know where the drain is
Since you did not include a model number this is my best guesses:
http://manuals.appliancesonline.com.au/kcm2100wc/kcm2100wc.pdf (Page 1 w/pic)
and
http://www.appliancesdirect.com/InstallationPdf/49-60442.pdf (page 7 no pictures)
For Complete Defrosting
Turn the temperature control to the
OFF position and unplug the freezer.
Remove all food and place it in
corrugated boxes, insulated bags,
picnic coolers, etc. Use towels and
newspapers for insulation as needed.
With the door/lid open, use pans of
hot water to speed loosening of frost.
Remove large pieces before they melt.
Chest models have a defrost water drain
at the front.
NOTE: Water may drip from the back flange of
the lid cover during defrosting. This is normal.
Ice builds up in the lid insulation when the lid is
open for adding or removing food, and melts
during the defrosting operation.
Sponge excess water from the bottom
of the freezer as it collects to prevent
overflowing.
After defrosting, clean the inside of the
freezer (see Care and Cleaning).
Replace the drain plug inside the
cabinet and the cap on the defrost
drain. Fold over and dry the gasket
on the hinge side of the lid.
Plug in the freezer. Return the
temperature control to its previous
position and return food to the freezer.
Hopefully with this information you can find the drain. If not go to www.ge.com and click on service and support to download your manual. (Model number required)
or contact them here:
800 GE CARES
(800.432.2737).
Thanks for choosing FIXYA,
Kelly
Jul 24, 2011 | General Electric Microwave Ovens
Fridge and freezer is stuck on defrost, what do I do?
Un plug it for a bit and then restart it....or a well placed whaap with your hand right by the timer may do it...
but sometimes it will not go and you will need to either manually turn it or get it replaced...
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 11, 2011 | GE Microwave Ovens
How do you defrost a samsung rs21dgrs
samsung fridge freezer problem
samsung dity help on youtube ">
Dec 29, 2010 | Microwave Ovens
Build-up of soft ice all over in the freezer
Do a manual defrost of the unit. Unplug it.. empty the freezer and place a fan b l o w i n g into the freezer for about 2 hours.
After the manual defrost return the unit to normal service.
If the soft build up of ice shows up again take a very hard look at the door seals. Look for tears.. gaps or any place the gasket is no longer attached to door face
This unit should defrost about every 10 hours. If it does not automatically defrost,,,, doing a manual defrost will only keep the unit going if you repeat the manual defrosting drill every 2 - 3 days.
If it just never goes into the automatic defrost cycle at all, the control board could have failed. PN: W10116216
Item 5 this link:
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KFCS22EVMS3/0593/0161000/W1003150/00003?blt=06&prst=&shdMod=
A failed defrost heating element can also cause this. Item 10 this link:
http://www.searspartsdirect.com/partsdirect/part-number/Kitchenaid-Parts/Refrigerator-Parts/12729129/0046/106/Model-KFCS22EVMS3/0593/0161000?keySuffixId=NA&productTypeId=x&searchModelNumber=KFCS22EVMS3&subCompDesc=Unit%20parts&brandDesc=KITCHENAID&modelDesc=REFRIGERATOR&pathTaken=partSearch&blt=11
Nov 18, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
When defrost kicks on in the freezer it stays on to long and defrost the food.
The defrost timer/control board is not working right... replace it...
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 25, 2010 | Microwave Ovens
Microwave Ovens Logo
44 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
