Question about Apple iPod MA446LL/A MP3 Player
Help please hey rest it but everytime i turn it on it says reset your ipod
  • Apple Master
  • 13,433 Answers
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Tip:
  • If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
  • If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If that doesn't solve it try a restore
Restore
  • Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your itunes Library.
How to restore your iPod:
For Windows:
  • 1. Make sure you've reinstalled the latest version of itunes.
  • 2. Open itunes, and then connect your iPod to your computer.
  • 3. After a few moments, it will appear in the source list in itunes.
  • 4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main itunes windows.
  • 5. Click the Restore button. You will be prompted with one or more restore options that may prompt itunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  • 6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, itunes will instruct you to leave iPod connected to your computer to complete restore.
  • 7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  • 8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the itunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on May 16, 2008
How to reset my ipod
If you want to reset your ipod back to factory setting then this if what you do:
1. plug your ipod into the computer and open itunes.
2. click on your ipod and click back-up to backup your data on ur ipod.
3. If you have any photos that you want make sure you have a backup of them or transfer them.
4.After that you can just press the rest button in itunes.
-Or-
if you dont care about what on the ipod then you can go to settings, then general, then rest and chose which rest you would like.
Hope this response helps you!
If any problem happen please feel free to tell me
Jul 19, 2014 | Apple iPod touch
How to reset ipod touch
-Or-
Jul 17, 2014 | Apple iPod touch
My ipod says disabled and try again in 21,345,432 minutes..please help
This explains how to do a hard rest on the IPOD, if you haven't tried it already
To perform an iPod Touch hard reset, start by turning the iPod Touch on. Press and hold down the sleep/wake button until you see the Apple logo on the screen. Next, you need to turn the iPod Touch completely off. Press and hold down the sleep/wake button until you see the red slider. Slide the slider to turn off the iPod Touch. This should fix any potential problems you are having with your iPod Touch.
If you are unable to turn off iPod Touch, you can try doing a manual reset. To do so, hold down the sleep/wake button and home button at the same time. Continue to hold them for at least 10-15 seconds. Wait for the Apple logo to appear.
Jul 19, 2011 | Apple iPod touch
Hi my ipod touch screen is wghite when i turn it on please help me
White Screen of Death
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
This is a FREE answer, Please Rate Me
Sep 26, 2010 | Apple iPod touch
Need to reset password on ipod nano
Connect iPod to the primary computer you use it with (the first one iPod synced with), and open iTunes. When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock iPod using this method, you can restore your iPod to factory settings. Please note that this will erase all data on your iPod. Afterwards, you can add your music and data back to iPod.
Dec 05, 2008 | Apple iPod touch
My ipod wont respond
Hey, simply reset your ipod
To reset your iPod:
Tip:
Sep 04, 2008 | Apple iPod nano 3rd Generation
80gb ipod classic won't turn on!
sounds like you have an error on your hard drive. Either fomat your hard drive in FAT32 or replace it for a new one.
Aug 20, 2008 | Apple iPod classic MP3 Player
Ipod wont show up on itunes
hey, select your model from this webpage and do all the steps it suggests.
If after all that the ipod still doesnt work properly contact apple or your dealer for more help.
http://www.apple.com/support/ipod/five_rs/
Mar 17, 2008 | Apple iPod MA446LL/A MP3 Player
Hey, watch this tutorial and try the things it suggest.
Id highly recommend, restarting, and returning the device into the original state.
All this is covered in the video here:
http://www.apple.com/support/ipod/tutorials/troubleshooting.html
If that doesnt help contact the appel support.
Mar 09, 2008 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
48 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
