Question about Canon ImageRunner 3025 Black and White Copier
Press shut down key of main machine and restart and error message is 000805-0000
  • 1,219 Answers
these means that you have fan trouble, probably fan in the rightsideway door.
You need to dismantle upper section of the door to get to the fans, reconnect them and try again.Also if you can remove one fan and by him go to electronics hardweare store and try to buy new.
Second thing:
remove back cover and reconnect all connectors on main pcbs and try then.
If these doesnt help you can write me on emma.servis@gmail for service manual of ir 3025.
hope that helps!
Posted on Sep 07, 2010
Smart failure.. bootmgr is missing..I have recovery discs but dvd player is not working
Yes, you can make USB boot drive. However main problem is the Smart... error. It is your hard drive. You need to fix that first! Try reseating the drive. Next go into BIOS by pressing F key during boot. Might be F2? Make sure BIOS recognizes the hard drive.
Once you get the drive going again, you can start the install / repair again. USB drive tool.
http://www.microsoftstore.com/store/msstore/html/pbPage.Help_Win7_usbdvd_dwnTool
Oct 11, 2012 | Computers & Internet
Canon IRC2620 Error Code E000001-0004
This is standard error code for Canon and the fuser unit. The error can be reset by being ready to go into service mode quickly. First press the additional function button, then the 2 & 8 keys at the same time and then the additional function key again. The display should change to the service mode screen, indicating " COPIER " and other accessories. Press " COPIER " then accross the top you should see a menu and select "FUNCTION" then select " CLEAR", then " ERR ", then " OK." This will clear the error from the copiers memory. Turn off the main power switch, wait a few seconds, then turn the copier back on. If you continue to have this error you will have to replace the fixing assembly and if it is similiar to the IRC3220 then you ahve only two screws to remove and the whole unit comes out. You will be saving a service call and I do believe the fuser is over $500. I usually don' tknow the prices of items until I have to do a quote for a customer. Good Luck.
Sep 04, 2012 | Canon imageRUNNER C3200 Copier
KDL52EX700 shuts down and restarts
If it is showing a blue scree of death (BSOD) and shuts down before you can read the error message try this:
Turn the computer off, then turn it on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Scroll down below Safe Mode and you will see an option to Disable Automatic Restart. Select it and reboot your machine. Next time it boots up you will be able to read the error message. You'll probably need a system disc or repair disc to fix the blue screen error message.
Mar 26, 2012 | Computers & Internet
UNABLE TO INIT
Hello all - here is the code solution - happy printing!
Machine unable to int - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
1) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
2) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
3) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
5) Press the 9 key twice to return to the standby state
Jan 06, 2011 | Brother DCP 115C All-In-One InkJet Printer
SharpMX-M620N copier problem is service F2print on the display board what is that problem
F2 error code means your toner control sensor is open. i would check your toner cartridges and make sure they are all seated in the machine. Once you check all of them, turn off the machine, then turn back on. If it is still not cleared, try pressing the #, *, C,* keys in rapid succession, which will take you to the simulation mode.
once you are in the simulation mode, press 14 (for the main code) and press the start key. It will ask you to verify, say yes, then when it is finished, press the CA or "clear all" key which will restart your copy machine and hopefully get rid of the error message.
If the machine still has the error code, call a service technician to come and take a look at it.
Thanks!
Ryan
Oct 29, 2010 | Sharp Office Equipment & Supplies
Cannot read disk
"A disk read error occured press Ctrl+Alt+del to restart " FOLLOW THE BELOW INSTRUCTIONS TO RUN DELL DIAGNOSTIC ON INTERNAL HDD Open the Dell Diagnostics on either your hard drive (F12) or from the Resource (Drivers and Utilities) CD. Running from the hard drive is the preferred method of using the diagnostics. If problems occur when running from the hard drive or there is no Utility Partition, the diagnostics can be run from Resource (Drivers and Utility) CD. From your hard drive: Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. When the boot device list appears, highlight ?Boot to Utility Partition? on desktop systems or ?Diagnostics? on portable systems and press . Note: On portable systems, PSA will be executed first. When PSA completes, press any key to load the Dell Diagnostics.? Go to step 2. NOTE: If you receive a message stating that no Diagnostics utility partition has been found, follow the instructions on the screen to run the Dell Diagnostics from your Resource (Drivers and Utilities) CD. From the Drivers and Utilities CD ResourceCD: Insert the Drivers and Utilities CD into the CD drive. Shut down and restart the computer. When the DELL® logo appears, press immediately. If you wait too long and the Microsoft® Windows® logo appears, continue to wait until you see the Windows desktop. Then shut down your computer and try again. NOTE: This feature changes the boot sequence for one time only. On the next start-up, the computer boots according to the devices specified in the system setup program. When the boot device list appears, highlight IDE CD-ROM and press . Select Boot from CD-ROM option from the CD boot menu. Select Run the 32 Bit Dell Diagnostics numbered list. If multiple versions are listed, select the version appropriate for your platform. Go to Step 2. After the Dell Diagnostics loads, the Main Menu appears. Click the button of the option you want. If a problem is encountered during a test, a message will display the error code and a description of the problem. Write down the error code and problem description and follow the instructions on the screen. If you can not resolve the error condition, contact Dell. If you run a test from the Custom Test or Symptom Tree option, click the tabs above the right window for more information: When the tests are completed, if you are running the Dell Diagnostics from the Drivers and Utilities CD, remove the Drivers and Utilities CD. Close the screen to return to the Main Menu screen. To exit the Dell Diagnostics and restart the computer, close the Main Menu screen. Regards Sunil Dsouza
Dec 04, 2009 | Dell Dimension 2400 PC Desktop
RICOH FT5832 ERROR CODE E-5 47
With the machine on, press clear modes(yellow button), 107, and then hold down clear/stop (red button). Enter 5810 then # key then 1 #. Turn off the main power then power back on. This code is a fuser lamp on condition. It should clear. If not reseat the fuser unit (gets hot), clear using above procedure and try again.
Apr 08, 2009 | Ricoh FT5832 Copier
Getting message 8611 failing to start
The 8611 error is telling you that the trackpoint or keyboard for the Thinkpad has stopped working
You can sometimes get the 8611 error:
  • If an emergency power down is made by switching the system off during or while an application is open, then immediately switching the system on creates a 8611 error.
  • Repeatedly turning power off and back on without properly shutting down or allowing the system to shut itself down.
The Solution:
  • Wait at least 6 seconds or longer after shutting down the system or before restarting to correct the 8611 error
If the above doesn't work you will have to disable the Track Point:
I did the following procedure from information I found on the Internet, and it worked, only you will need to use a mouse with the laptop from that point on, you are basically turning off the trackpoint which is causing the error.
There is no guarantee this will work because it may also be the keyboard itself, so do at your own risk.
First go into the system config utility which you get forced into after the 8611 error is reported
Then go back to the main menu and enter the config.
When there press the control key and the d key at the same time..
Find and ensure you are on the -base 128 cmos- page.
Look for ofset 20h, (maybe a different number ##h) and in the1st column and 3rd row and change the number to 01. On my Thinkpad the ofset was not 20h but 12h., so my ofset number wasn't the same but it is still 1st column, 3rd row.
When finished changing the number to 01 press the F2 key and then the F3 key.
Then exit out and restart the computer.
The computer should reboot with the trackpoint disabled. And you will need to use a mouse with the Thinkpad.
Mar 12, 2009 | IBM ThinkPad 600E 2645 Notebook
SC542
sc 542 is when the machine cant warm up to temperature for whatever reason usually entering service mode via clear 107 clear stop and rebooting clears the code if that dosnt work then the next step is call a service engineer
Feb 19, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Canon ImageRunner 3025 Black and White Copier Logo
133 people viewed this question
old marine
old marine
