Question about Sanyo Televison & Video
I have a Sanyo tv model No CE3/FD90B when in stand by light keeps flashing. also DVD player will has stopped automatically appearing on screen when switched on. If I then try to access AV/HDMI menu through TV remote it will not appear. If I unplug both appliances for a few moments all works ok until TV is switched off again then its back to square one
SOURCE: AKAI PDP4273M1 - Unit powers up then shuts down.
I just repaired one for the same trouble. The input to the main processor from the standy switch had shorted to groung. This was probably caused by static inserted when pushing the power button. The processor is not a replaceable part. The part number for the main board is E3761-058010-2. It costs between $140 and $150. I found it on-line at Shopjimmy.com.
Good Luck!
Posted on Feb 25, 2009
ginko
  • 19396 Answers
SOURCE: Polaroid LCD TV TLA-4641C
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
SOURCE: Single Blue vertical line appeared on the sanyo 42'' LCD screen
vertical ic fult or vertical section supplys missing
Posted on Jun 12, 2009
VinayT
  • 1884 Answers
SOURCE: Toshiba 50HP16 Plasma tv has
Display IC seems to have gone. It will be a replaceable module. Only you have to figure out which one it is. Such thing happen in electronics. Look for any burnt or bulged IC.
Posted on Oct 07, 2009
SOURCE: on a Daytek 46 in LCD TV, no AV Digital Cable Signal, but HDMI OK
Had the same problem.
Fixed by unplugging everything from the power source, leaving for 2 minutes then plugging back in.
Works fine now.
Posted on Oct 31, 2009
How can I fix my Sanyo Model FVM5082 TV?
You can get power supply boards and any other part you may need from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Jul 28, 2017 | Sanyo Televison & Video
How do I shut off or disable TV Guardian?
Hello
Setting TVGuardian®
Example:
To set "TV Mode Strict", "TVG CC On" and "TVG CC Ch
CC2"
1* Press [SETUP] in the stop mode.
The setup screen appears.
2* Press [ => ] to select "Parental".
3* Press [ENTER].
"Parental" screen appears.
4* Press [Down Arrow button] to select "TVG Mode".
Note:
If the parental lock is set, the highlighted box does not
move. You must enter the password to release the
parental lock first.
5* Press [ENTER].
The submenu ("Off", "Moderate" and "Strict") appears.
6* Press [p] to select TVG mode to OFF at this window, if it is selected strict.
OK.
Jul 13, 2011 | Sanyo DWM395 DVD Player
My sanyo tv stand by light keeps flashing and it wont turn on can you tell me whats up with it
i have 32inch sanyo tv i have blue light on front whitch comes on when on stand by it wount come of standby eney idears on how mutch it will cost to get fixed x
Nov 13, 2010 | Sanyo PDP-42H2W 42 in. HD-Ready Plasma...
Jun 12, 2009 | Sanyo Televison & Video
I have a sanyo dvd player dwm-395. how do i unlock it w/o remot
For the DVM-390 model, I believe this solution should work on the DVM-395 model - Push and hold down the Open/Close button until "UN-LOC" appears on the FL display (or "Disc Tray Unlocked" appears on the TV screen).
Dec 24, 2008 | Sanyo DWM-390 DVD Player
Subtitles on Sanyo DVD Player Model DMW-380
For the DVM-390 model, the above problem can be due to the TV Guardian (TVG) mode. I would go to the intial setting options and under Language turn the TVG mode to "Off" and see if that allows the subtitle languages to appear on screen.
May 23, 2008 | Sanyo DWM-390 DVD Player
DVD Tray is locked
Jan 18, 2008 | Sanyo DWM-390 DVD Player
Nothing on unit front display but Red Record light (solid)
how do you hook a dvd player up to a Sanyo sdtv model ht27547 tv ?
Jan 18, 2008 | Televison & Video
Sanyo TV
I too just bought an RCA remote for the same television. The button to access other video screens is the A/B button on mine (next to the last channel button).
Jan 08, 2008 | Televison & Video
Televison & Video Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
