Printers
Problem for Printers
Generic problem for all Printers
HP PRINTER JAMMED, UNABLE TO
By m1212 on May 13, 2008
HP PRINTER JAMMED, UNABLE TO LOCATE PAPER JAM AND THE ON AND OFF BUTTON KEEP FLASHING AND NO OTHER LIGHTS ON SELECTION PANEL. PLEASE ADVISE!
Best Solution
posted on May 13, 2008
Very Helpful)
gadgetboy21
Rank: Master
Rating: 91%, 16 votes
the problem that you are having m1212 might be because there is a that piece of paper that is jamed in the printer. if you can strip the printer then remove the main top cover to acess the centre rollers then use a new full sheet of paper and push it threw the main centre rollers to clear out small pieces of paper. if you not sure on what to do get some 1 who knows printers as this maybe abit tricky.
Was this helpful?
Yes
No
Solution #2
posted on Dec 14, 2008
Not Rated)
NJChemist
Rank: Apprentice
Rating: 0%, 0 votes
I had a similar problem with my HP C6180 printer, and HP tech support was useless. I had no paper stuck and did all the steps from HP.com. My carriage jam also came with a grinding sound (it was not able to move all the way to the right). I looked inside and and on the lower right side there was a white pad that was raised (I think this cleans the print heads). After unplugging the printer, I used a screw driver to pushed this pad down and to the back of the printer. It moved back and a black sponge like pad moved up from under the front of the printer. I then closed the lid, and used the HP software to clean and realign the print heads. Everything is working fine now. No guarantees this will work for you, but it saved me from having to get a new printer.
Was this helpful?
Yes
No
Popular Solutions for Printers
Questions and Unsolved Problems for Printers
Answer
Is a DELL 1700 LASER PRINTER a decent printer, and how much should I be willing to pay, is this a... (More)
Answer
I've read that inkjets are best for home photos. But I really want a color laser printer ( fax not... (More)
Answer
Lexmark x4530 does not scan. Cannot retrieve application list. Is there any way to fix this?
Answer
i have the new microsoft 7 and cannot print with the HP PSC 2355 printer? not possible yet?
Answer
blue paper keeps printing
Describe your Printers problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Printer Experts
Top Printer Repairmen
in , AK
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
