Indicate the defaults taken place in india since 1991 w.r.t to babking sector and primary and secondary market i am not geting the exact figure of 1991 and the answer
In 2,000,000 how about hour?
Posted on Sep 07, 2010
How do I check the ignition coil
Ignition Coil Primary Circuit Test
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is zero point five and zero point seven ohms. If primary resistance is not within this range check out test results below.
Ignition Coil Secondary Circuit Test
With the ignition coil removed from the motorcycle and the ohmmeter set to the RX1K scale place the ohmmeter leads on the secondary coil windings B (middle terminal) to
R (rear secondary terminal/socket), B to F (front secondary terminal/socket) and check for secondary coil winding resistance which normal resistance range will be 5.5-7.5K ohms. If secondary resistance is not within this range check out test results below.
Test Results
A low resistance value indicates a short in the coil winding which requires coil replacement.
A high resistance value might indicate that there is some corrosion/oxidation of the coil terminals requiring the coil terminals to be cleaned and the resistance test then repeated and if after the test is repeated the resistance is still high after the terminals were cleaned the coil must be replaced.
If there is an infinite ohms or no continuity) resistance value the coil is open and must be replaced.
Jul 30, 2014 | 2003 Harley Davidson FLHTC Electra Glide...
Bike has no spark
Check your pick-up sensor located inside the timing cover, behind the adjustor plate. If the filament is not intact you will have no spark.
A defective coil, cam position sensor, or stator will also cause a no spark condition.
Remove the coil. THEN set your ohmmeter scale to RX1 and place ohmmeter leads on the primary coil windings A (front of coil) to B (middle of coil), B to C (front of coil) and check for primary coil winding resistance which normal resistance range is 0.5-0.7 ohms. If primary resistance is not within this range check out test results below.
Test Results
May 09, 2014 | 2002 Harley Davidson XL Sportster 883
How to check for spark, harley springer
Test Results
May 03, 2014 | 2003 Harley Davidson FLSTS Heritage...
1998 FLHT wont fire up
Are there any codes. Does it backfire?
To start you need spark at the plugs, fuel in the induction module or tubes and compression in the combustion chamber. Have you checked any or all of these???
As a starting point install NEW plugs and also:
Test Results
May 03, 2014 | Harley Davidson FLHTCUI Electra Glide...
Throttle cable install
What year????
For some models and years, but do not know if it fits yours as I do not know what year you have:
Test Results
May 03, 2014 | Harley Davidson FXDWG Dyna Wide Glide...
I shut of my 2000 Fat Boy and 20 mins later tried to start it but no fire. Turns over but no spark?
Test Results
If you have spark, it sounds like either the sensor in the timing cavity of the engine is bad or the electronic ignition unit is bad.
Apr 30, 2014 | 2000 Harley Davidson FLSTF Fat boy
I have an 05 softail duece with manual choke, engine will turn over fine but I have no fire at the plugs, installed new plugs, still no fire
Test Results
Apr 28, 2014 | 2005 Harley Davidson FXSTD - FXSTDI...
No fire to spark plugs
Of course their will not be if both plugs are out of the cylinder and there is not compression.
Test Results
If you have spark, it sounds like either the sensor in the timing cavity of the engine is bad or the electronicignitionunit is bad.
Apr 16, 2014 | 2003 Harley Davidson FXDWG Dyna Wide Glide
Good evening wish you. I use the MK3008GAL HDD in Acer Aspire One 110Aw netbook (original was 8GB SSD). The system appears to be Secondary Master. Why? Can be set as Primary Master? Infrequently heard...
Most motherboards have two "channels", namely PRIMARY and SECONDARY.
Each channel can support two devices, namely MASTER and SLAVE.
So, the "data" cable from your disk-drive is connected to the SECONDARY channel,
and is the MASTER (or maybe "only") device on that channel.
Connecting it to the PRIMARY channel will *NOT* increase the performance of your computer; don't waste your time trying to change it.
Yes, Toshiba disk-drives do "click". However, given that you *DO* have "bad" sectors, you need to replace the disk-drive before it *COMPLETELY* dies, causing the loss of all your files!
Make a BACKUP of all your files, today!
Dec 18, 2010 | Toshiba MK3008GAL Hard Drive
P1370 and p1350 trouble codes
P1370 Ignition Control (IC) Module 4x Reference too many pulses
P1350 Ignition Control System
Ok, these codes are signaling a malfunction within the Ignition control module. it is sending way to many signals to the coil. i recommend testing the coil for damage and irregular resistance. i will explain how to do this below. i would replace the module as well. The control moduel is Located Under hood, center, rear engine area, above valve cover, mounted in base of ignition coil pack
Ignition Coil Test Procedures__
Ignition Coil Resistance
* with the key off and the battery lead to the ignition coil disconnected, use an Ohmmeter to measure the primary and secondary winding resistance of the ignition coil. when checking the resistance across the windings, pay particular attention to the meter reading. if the reading is out of specifications, even if it is only slightly out, the coil or coil assembly should be replaced.
* To check the primary windings, calibrate an ohmmeter on the X1 scale and connect the meter leads to the primary coil terminals to test the winding.
* An infinite ohmmeter reading indicates an open winding. The winding is shorted if the meter reading is below the specified resistance. Most primary windings have a resistance of 0.5 to 2 ohms, but the exact manufacturer's specifications must be compared to the meter readings.
* To check the secondary winding, calibrate the meter on the X1,000 scale and connect it from the coil's secondary terminal to one of the primary terminals.
# A meter reading below the specified resistance indicates a shorted secondary winding. An infinite meter reading proves that the winding is open.
# In some coils, the secondary winding is connected from the secondary terminal to the coil frame. When the secondary winding is tested in these coils, the ohmmeter must be connected from the secondary coil terminal to the coil frame or to the ground wire terminal extending from the coil frame. Many secondary windings have 8,000 to 20,000 ohms resistance, but the meter readings must be compared to the manufacturer's specifications. The ohmmeter tests do not indicate such defects as defective insulation around the coil windings, which causes high-voltage leaks.
May 17, 2009 | 1997 Cadillac DeVille
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
