Hitachi TV is working in normal condition except the colour has suddenly turned more Pinkish Red like at the background which is irritating eye while viewing channels programmes. Otherwise all functions of TV are working normal except the darked red colour. Please apprise the problem and any solution to reduce the colour though manually done as per booklet enclosed with the set. Thank you in advance. Regards Gobind Chhoda
  • Televison & ... Master
  • 1,896 Answers
If you have an old crt television with a normal tube then your degaussing ptc thermistor could be defekt
If an younger LCD television some components that possibly react on a inspection with a canister coldspray on some components get a service manual and search for the right basic power on the several service points from the power supply first. https://www.youtube.com/watch?v=84tyJ6A1frg
Posted on Jul 10, 2017
5 Suggested Answers
  • 192 Answers
SOURCE: colour problem
I have default settings I normally use for most sets before I begin any kind of alingment. Contrast: 90% Brightness: 45% Color: 45% Tint: 50% If the brightness is to high or the contrast to low the color is off. Check your connections, there probably OK, but, it never hurts. If the settings don't help call a local authorized servicer in your area. Hope this helps.
Posted on Jun 24, 2007
falter
  • 245 Answers
SOURCE: Hitachi 32'' lcd tv picture runs slow sometime and goes dark
go in touch wit HITACHI costumer help and service and tell them ur problem u have.....how old is ur TV?
hope u get a answer from hitachi....and good luck
Posted on Mar 12, 2009
SOURCE: Westinghouse 32in HDTV-Ready
I called westinghouse with a similar problem(my picture shows up but all the white turns blue or somtimes pink).
they say the problem is similar to that of the xbox 360's red ring of death problem. Now what needs to be done is the unit needs to be unplugged completely for about 30 minutes. this allows the unit to completely cool down. and when the unit restarts and heats up the troubled connections will reflow and all will be fixed.
I tried this and it worked well for my TV. but it is only a temp fix and will need to be done again if the problem occurs.
Posted on Apr 16, 2009
welcomejee
  • 10594 Answers
SOURCE: Pinkish red horizontal lines loop in the
What is the exact model of your Sony TV?
Posted on Jun 03, 2009
How do I fix my colour picture that has a red/pinkish hue in the background
Hi, Go into menue and try to adjust the color to your liking. If it doesn't help much you may have to change the projector light.
If you need help look at google (youtube) Good luck.
Jun 03, 2015 | Televison & Video
The screen is doubled and pinkish blue kind of like 3-d screen
this is aconverson problum.
first tv-set menu open and select converson option select and see to screen CENTRL cross line in 2 or 3 colour [RED /GREEN /BLUE] hten set on your REMOT cantrol arow key or [ ch+ ch- v+ v-] up down to arow key an set all colour line is meching with centrel and see cross line is complitly waite an d seethe pictur is normal ...
if not converson seting facility in the menu system pls. set your tv-set with tech . he is set menualy sum time's
Oct 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Hdtv has a red screen
Looks like you got some convergency issues there, I would consult a local repair place like www.teexp.com put in your zip code and see if they service your area and TV.
They can also give you a estimate on how much it will cost to get it repaired.
Jun 12, 2009 | Hitachi 57S715 57" Rear Projection HDTV
Pink colour everywhere
Assuming all power supplies are OK, you most likely have a bad CRT grid, and that respective (red) tube must be replaced. I'm sorry that it went that way, as this repair is not cheap....accordianman
Sep 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red screens cause flickering
if normal tv is fine then ,likely the signal from the box is too hot.
if using composite switch to cable ch 3 or vice versa,
or use hdmi cable or change the box .
Apr 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
Hitachi 43FDX01B (convergence) problem
hi i have same prob iv bin told its a convergence chip an thay r £150 ! thay go bout evry 6 years an its comon .. any way there coming 2 fix mine 2day so ill let u know if it sorts it out my mail is mjoutlaw@hotmail.co.uk thanx
Jan 30, 2008 | Hitachi 51F500 51" Rear Projection...
Monitor colours get pinkish red
The lamps have not failed as you believe Steve. If they fail, then a protection circuit inside will shut them off all together.
Acers have a habit of capacitors failing. This in turn sends dodgy power to the inverter circuit and through to the lamps.
This is not a design flaw, it's just age. Capacitors can die early of course, but it's not common for them to go before the warranty period is up at least. Normally 3-5 years is what you can expect from them.
If you understand electronics then the job will be easy, if not have your local TV tech give it the once over before real damage is done.
Nov 07, 2007 | Acer AL1714 17" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
