Question about Intel D102GGC2 Motherboard
I want to upgrade D102GGC2 RAM to 2GB what speed in Mhz i must use
  • raju017athan Sep 20, 2010
    On D102GGC2 two rams of different speed can match such as
    one 800 and 667 or 800 and 533 or two 533 Mhz 1Gb Rams,
    But two 667 or 800 Mhz Ram cannot be supported on these motherboard
Hello ,my video driver is not working in window 7.......d102ggc is my board .what can i do.....sir plz tell me
Posted on Nov 22, 2010
  • 3 Answers
I want to know the same. Till now i saw in various forums that 1gb x 2 modules 800mhz will work. It will start running in 533MHz speed (which is the supported speed for DDR2 ram on this mb).
Let me know if you have already done this..
Posted on Sep 19, 2010
2 Suggested Answers
SOURCE: Machine randomly restarts after upgrading RAM
brother...
d102ggc2 only support max 2 gb ddr2 which mean (2x1gb) with 533mhz each,
if you replace ur curr ram module with two seperate transcend 1 gb ddr2 533mhz only then the problem will be solved...
take care
Posted on Jul 02, 2009
I have intel pendium d d102ggc2 motherboard. am using 512 mb ram ddr2 667mhz. Now i want to upgrade it and use 2 gb ram. please suggest.
Mother board d102ggc2
• Support for DDR2 533 MHz and DDR2 400 MHz DIMMs
• Support for up to 2 GB of system memory
Dec 27, 2012 | Intel D102GGC2 Motherboard
I am using D102GGC2 Desktop board with Intel Pentium D Processor 2.8GHz and using 512MB DDR2 PC-533 RAM. Nw I want to upgrade to 2GB and decided to purchase 2 * 1GB DDR2 PC-667 RAM. Will it be compati
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Third-Party+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+D102GGC2
You can only add 1gb per slot Because the mb does not supports a bigger module.
This ram type does come as 1 gb module.
The 667 mhz and 800 mhz is the Mhz speed for the ram module.
Your mainboard supports this but it will only run the current front side bus speed as the mainboard supports.
This means that the new ram will only run 533/400 mhz as the mb supports.
Hope this was helpfull
Nov 23, 2012 | Intel D102GGC2 Motherboard
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
I have 1gp 533 mhz speed ram now i want to upgrade it to 2gp 666 mhz speed ram can i do it
Yes, you can
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-026579.htm
Apr 28, 2011 | Intel D102GGC2 Motherboard
I bought new 2gb ddr2 with 800 mhz and its not working on my motherboard d102ggc2 can u plz help me with the solution
i guess you did not check the compatibility of the RAMs to your MB limitations....
the only solution is to return the RAMs and get the RAMs that is supported by your MB.....
the MB (D102GGC2) can hold only a max of 533 mhz and max of 1GB each in each slot of RAM....
so if you are trying to install one 2GB card of 800 mhz IT WIILL NOT WORK....
get TWO RAM cards of 1GB each (total 2GB) of RAM.... each of 400 mhz....
hope this helps...
Reg
Suresh
to check what your MB supports, look for the details below...
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-029352.htm
Intel® Desktop Board D102GGC2 Technical product specification circuit388.gif Product Specification
This product specification applies only to standard D102GGC2 boards with BIOS identifier GC11020M.86A. Changes to this specification will be published in the D102GGC2 Desktop Board Specification Update before being incorporated into a revision of this document.
pdf.gif D102GGC2 Technical Product Specification [PDF]
File Name: D102GGC2_TechProdSpec.pdf
Date: April 2006
This document is an update to the specifications contained in the D102GGC2 Technical Product Specification. It is intended for hardware system manufacturers and software developers of applications, operating systems, or tools. It contains specification changes, errata, specification clarifications, and documentation changes.
pdf.gif D102GGC2 Desktop Board Specification Update [PDF]
File Name: D102GGC2_SpecUpdate03.pdf
Date: November 2006
Apr 27, 2011 | Intel D102GGC2 Motherboard
Hello Sir, I had 512 MB 533 MHz DDR2 RAM(Dynet). Now I have bought 1 GB 667 MHz DDR2 RAM(Dynet). My system has 2 slots. In one slot, I have 512 MB RAM and in another slot, I installed 1 GB RAM that I have...
The Intel D102GGC2 uses a Dual Channel Memory Architecture meaning that both slots need to be running at the same speeds. I would suggest getting another 667 MHz RAM card and installing it along side your current one, just as I reminder this motherboard only supports 2GB RAM Max so don't get one that is above 1GB.
Mar 28, 2011 | Intel D102GGC2 Motherboard
Please tell me which type of support for D102GGC2 for 2gb ram i want extension ?
Your motherboard have the following specifications:
Two 240-pin DDR2 SDRAM Dual Inline Memory Module (DIMM) sockets
So either get 1 2GB RAM DDR2 with 533 or 400 MHz. It is maximum for your motherboard or have 2 1 GB accordingly.
Nov 22, 2010 | Intel D102GGC2 Motherboard
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Can intel d102 motherboard have 667 fsb ram
I am not able to find a 533 MHz 1GB DDR2 RAM.. Has anyone used a 667MHz 1GB DDR2 on this board D102GGC2 ?
Dec 25, 2009 | Intel D102GGC2 Motherboard
Ok thats the problem.
1 module with 2gb is not possible on this board:
http://www.memoryxxl.net/mainboard::4345_36366/Intel-D102GGC2.html
Intel D102GGC2 Motherboard Mainboard Speicher Technische Beschreibung Intel D102GGC2:
Bus Architecture: - Hersteller Standard Ausrüstung: Non-ECC only, Unbuffered only, Chipset: ATI Radeon XPRESS 200 - vom Geräte Hersteller empfohlener maximaler Arbeitsspeicher: 2048MB - Speicher Upgrade: 2 (2 banks of 1) -Speicher Beschreibung: Jeder Slot kann mit DDR2 PC2-4200, DDR2 PC2-5300, DDR2 PC2-6400 und maximal 1GB Speicher aufgerüstet werden. Eine bessere Performance erziehlt man bei paarweiser Modul Installation. (USB Support: 2.x Compliant, Graphics Support: PCI Express x16) - Speicher Bus Architecture:
You have to use 2 modules with max. 1 gb per module
Dec 30, 2008 | Intel D102GGC2 Motherboard
Intel D102GGC2 Motherboard Logo
365 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
