Question about LG Washing Machines
Mine is WF- T506 top loader Has a stale water smell when I keep lid closed
SOURCE: mouldy mildew smell
I had the same problem and I fixed it fairly easily in about 45 minutes:
The root-cause is the incredibly stupid design of the plastic ring that snaps over the plastic wash tub. It is filled with many nooks and crannies that rarely contact the wash water, thus getting scummed up and moldy. See a picture of the gross mess here: http://www.falselaborblog.com/2008/08/moldy-maytag.html
The fix involves opening the top (easy) and removing the ring (fairly easy) and can be done yourself if you are the least bit handy.
Unplug the unit.
***If you are mold-sensitive, wear gloves and breathing apparatus or have someone do this for you.***
Tape the lid shut so it doesn't flop open when you raise the lid.
Use a putty knife to push into the front seam about 1 1/2 inch from each corner. This unlocks the top and it will open just like the hood on a car. Carefully secure this in the open position and don't let it fall on your head or your hands.
You will see plastic fasteners holding the top ring around the outer plastic wash tub. These will unsnap (you may need a flat-head screwdriver for some of them).
Carefully lift this out and try not to puke when you look at the underside (see photo http://www.falselaborblog.com/2008/08/moldy-maytag.html). Take it to a laundry tub or bathtub and thoroughly clean it by scrubbing with hot water, detergent and bleach.
Before replacing the ring, use a thin brush to clean between the upper part of the wash tub and drum---the scum and mold will be in here also.
Replace the ring in the reverse of the above steps.
Prevention: There is none. You will have to do this every 4 to 6 months to prevent mold from infesting all of your clothing, etc.
I'm experimenting with limiting wash load size to "large" and never using "super", reserving the "super" setting for running periodic (hot water + Clorox) to see if it reaches the idiotic upper ring and keeps it clean. I am not hopeful that this will eliminate the need for these overhauls.
P.S.: The person that designed this washer should have all of his/her underwear and bed linens washed in an uncleaned Maytag Atlantis for life.
Posted on Oct 01, 2008
jsrock516
  • 5911 Answers
SOURCE: samsung washing machine smell
Keeping the lid shut is one of the worst things you can do for a washer. Obviously, the company you spoke to does not know what they are talking about. It is strongly recommended that you leave the lid OPEN when not in use in order to ventilate the wash tub and allow it to dry. There is always a small amount of residual water in the drain pump and lines, however, that will not evaporate. With the lid shut this residual water can sour and cause odors.
Consumers that do not normally use a HOT water cycle, do not use bleach, or run the washer infrequently can also experience odor problems with mildew and odor. It is recommended that you run at least one HOT cycle per week, or run a cycle with bleach when washing whites to keep bacteria and odors to a minimum. I hope this advice helps you. Let me know if you require further assistance.
Posted on Oct 26, 2008
duby1990
  • 367 Answers
SOURCE: Why does the washer smell like stale water when I lift the lid
Buy whirlpool affresh washer tablets. They kill the smell in front load washers. But they work great for top loaders too!!! They are only about 10 bucks and all you have to do is read the instructions on the package and run your washer through its cycle. Then your smell should go away.
Posted on Nov 18, 2008
wheelshot
  • 102 Answers
SOURCE: front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Posted on Apr 03, 2009
SOURCE: stale water smell
washer is under warrenty so called a repair man
Posted on May 19, 2009
Lg wf-t506 has de error.
i think your machine door switch is damedge........replace it
Jun 09, 2013 | LG Washing Machines
Smell of stale water from Avanti compact washer
It may not be draining very well.
I have a front load washer and run a cycle of a few cups of bleach through mine every couple months.
I also add vinegar to most washes but that's due to my teenage son's athletic wear.
Both those things do the trick.
You shoudl probably check the mechanics as well but the above is a stop gap.
Sep 14, 2012 | Avanti W789SA Top Load Washer
I have a fuzzy logic 8.2kg top loader WF-8071TTP. We had a power failure while the machine was in a washing cycle. Now I start the machine fills with water and when the wash cycle must start it give a DE...
'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor becoming apparent with the extra movement of washing requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 13, 2011 | LG Washing Machines
I have a WF-T556 top loader with a de error. Should there be a magnet on the lid of the machine??
There sure should be....why, because mine stopped working as well. Found magnet inside machine after getting rid of water on spin cycle (thankfully it still allows the water drain to occur). Put magnet back on and hey presto, all good.....if only I had taped it on as 5-6 washes later and it has fallen off and I can't find it - hopefully a standard magnet will be enough to fix from shops - I am sure LG or proper repair place sells them for a fortune :(
Jul 04, 2010 | LG WFT1071TP Top Load Washer
Stale water smell
May 18, 2009 | Roper RAS8244LQ Washer
Whirlpool Top Loader LSB6000PQ0 fills up with water but that's it
you probably closed the lid to hard and broke the switch that tells the machine that it is closed. So the machine thinks the lid is open and for saftey reasons will not operate. I had the same problem. You can buy a new switch for about $10 or you can simply cuts the wires for the switch and wire them together. If you do this be warned that the machine will never know if the lid is open or closed. The machine will assume that the lid is always closed. But it will work also.
Jan 28, 2009 | Whirlpool LSB6000PQ Top Load Washer
Nov 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Samsung washing machine smell
Oct 25, 2008 | Washing Machines
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Dec 05, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
22 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
