Question about Dell Inspiron 1545 Notebook
My dell inspiron 1545 failed to boot keep telling me hard drive not detected, pls what can i do
    Genius:
  • 2,785 Answers
You have to open the case of the laptop and replug the cables of hard disk. if you are not familier with the hardware then you have to take your lap top for servicing
Posted on Sep 07, 2010
    Problem Solver:
  • 10 Answers
First go into your bios setup by pressing either F1, F2, Del or F10. Then check there if the hard drive is listed in the first tab. If not then your hard drive is faulty, but if it does show there then It means your hard drive is working. It might just be bad sectors on the partition of the hard drive. Take the hard drive out and connect it to a desktop pc if it picks up on the desktops windows then just backup your data and re-install windows.
Dell inspiron 1545 laptop wont boot. Error unable to locate hard disk drive
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jan 21, 2012 | Dell Inspiron 15 1545 Notebook
Dell inspiron 1545 Laptop computer is getting BSOD on boot, when first ran diagnostics got error: Hard Drive - DST Test Results - Fail Error Code 2000-0142 Msg Hard Drive 0 - self test unsuccessful status...
The error indicates that there's a hard drive issue. If it just happened after the hard disk is reinstalled, remove it and reinstall it. It could be a problem caused by loose connection or improper connections. If the same problem repeats, install the hard drive on another system (to verify whether it works on another machine or not and to confirm it still works). If it doesn't work on another computer/system then your only option to run the system is replacing the hard disk. If it works on another computer or if it's detected on another system, then there could be problem with the hard disk, eg. Corrupt Partition, Windows Corrupt etc....
First of all, try booting into Safe Mode. You have to press F8 during the startup to go into Advanced Boot Options. Once you are in the Windows Advanced Boot Options, select Safe Mode using the up and down arrow keys on your keyboard. If it still doesn't work, it's the hard disk issue. Try with another Hard Disk.
But if in case you can boot into safe mode, check the Hard Disk for errors. In other words, run Windows Checkdisk utility. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Oct 10, 2011 | Dell Inspiron 1545 Notebook
I have a dell laptop 1545 inspiron. iam unable to boot my laptop it comes up with err 2000-0146. it happend bcz i was scanning antimalware application and in the middle of scanning i warm booted the...
Hello, You dont need another hard disk, because that error is from the software you are making use of at that time. It was deleting your system files without you knowing that. Just look for a windows cd and reinstall your windows and you will enjoy your system again.
Apr 05, 2011 | Dell Inspiron 1545 Notebook
I put a new hard drive into my inspiron 1545 and it says their is no hard drive
in Bios you see this hdd? try to pres F12 while boot and do a diagnostic with dell utility, then post here again
Jan 23, 2011 | Dell Inspiron 1545 Notebook
Ran Dell diagnostics and SATA Disk Confidence test failed, Error Code 0F00 1332,Disk Block 30819848(etc)IRQ did not set in time. Dell Inspion 1545 laptop with SATA disk s/n 5VC2W51X
consider to replace your hard drive, your hard drive detected crash on your bios so you have to replace it. your hard drive can be use to external hard drive buy some external hard drive case 2,5"
you can re partition your hard drive and maybe if you are lucky the harddrive can be use again on your laptop
Jan 16, 2011 | Dell Inspiron 1150 Notebook
I have a Dell Inspiron 1545 laptop that won't boot. When i perform a BIOS diagnostic on it it comes up with error code 2000-0146. "Hard Drive 0 - self test log contains previous error(s)". I...
The problem is either the Hard drive has failed and needs replacement or the hard drive is operational but it lost the OS. (Operating System). If the OS is gone, you need to re-install it again..
Feb 09, 2018 | Dell Inspiron 1545 Notebook
Sudden Blue screen display on my Dell Inspiron 1545 with MS XP OS-Then I ran diagnostics and got this result- "DST short Test-Failed-Error code-2000-0151 Error message: Hard Drive 1-incorrect staus...
Hard Drive 1-incorrect staus 3E. Please help fix this problem. Thanks
Nov 03, 2010 | Computers & Internet
Dell Inspiron 1545 will not boot up.
Try removing battery and booting on AC power only from adaptor
Then take out ram modules and reseat these, try to boot
Disconnect hard drive, DVD rom drive and try to boot.
If you get a beep sound, this shows that at least there is power to the system. Note down the number of beeps and post the result.
Feb 10, 2010 | Dell Inspiron 1545 Notebook
I cannot get my dell inspirion 1545 laptop to boot up
If the laptop turns on, but you get an error during boot it could be a broken operating system. Try to re-install. If that fails, you have a broken hard drive. You can get a new one on ebay or laptop hard drive store. somebody has to open the Laptop and replace the part. The part is available on ebay. Here's a guide on how to disassemble a Laptop. Maybe a tech savy friend can do it for you. If you want to pay to have somebody do it for you there are third party Laptop Repair Services.
Feb 09, 2010 | Dell Inspiron 1545 Notebook
Dell Inspiron 1545 Notebook Logo
144 people viewed this question
Alun Cox
