Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
I was looking at the screen and suddenly the screen went blank and the small green light went out. I have checked the fuse in the mains cable and checked the cable on another screen. Is there a thermal cutout or internal fuse that may have blown?
  • 11,361 Answers
Most of the thime it is the SMP IC that went out.
Try some reading here: (for $29, I would buy a new PS)
http://www.midnightmods.com/2008/07/dell-1800fp-repair.html
http://www.badcaps.net/forum/showthread.php?t=7006
http://www.lcdrepair.us/1800fp-power.html
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Sep 07, 2010
TV screen went blank, can it be repaired?
If audio is OK, the problem is with its back-light. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 03, 2016 | LG 47LG50 47 in. LCD HDTV
VX37L Screen Suddenly Went Blank, Now No Image, Sound Only on Cable Input, VIZIO Logo Lights Up
turn on the set, grab a bright flash light and dim the lights in the room. Shine the flash light on the screen, if you see a faint picture on the screen, you are dealing with a backlight problem. There are several things that can cause this. One, a bad backlight inverter, two, faulty 24vdc power supply, three, bad main board, or a bad faulty backlamp.
May 10, 2013 | Vizio VX37L Television
Green lights on screen blank no picture no sound nothing
Apr 23, 2017 | Hitachi 42HDT51 42 in. Plasma SLC1551AW
THE TV WILL NOT POWER UP
It depends on a lot of other things, but you could try these steps . . .(assuming its a TFT flat screen)
Has the mains fuse blown ? try a different mains cable.
If it works from a power supply/mains transformer (a small box attached to the mains supply cable), check that box - they usually have a small green light on them to show they are getting power. These are easily replaced if that part is faulty.
Has the power cable come detached from the rear of the TV ?
Does a power light appear on the actual TV front (usually blue or green), and then go red (or off) after a few seconds. In that case the screen has a more hard to fix problem inside :(
Apr 04, 2010 | Sylvania LD370SS8 37 in. LCD Television
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
My zen suddenly went blank!
Your device lockup isn't uncommon, and in most cases is easy to fix. You need a small paperclip or straight pin to reset the device. When you reset, be sure to hold it in and wait for the blue light to turn off. Once you power the unit back on, it will rebuild and should operate as normal.
Dec 25, 2008 | Creative Labs Zen Digital Media Player
TOMTOM GO 710
Could be a loose contact at the connection between the wire and at the gps unit.
Think the green light must be on at the charger port and also on the gps unit.
This green light can be found near the power button on the gps unit.
Nov 22, 2007 | Tomtom GO 700 GPS Receiver
No Picture, cannot power off without unplugging, flashing green light
The part is Replace an X-tal (Viper) on SSB item 1H00, order code: 242254301397. The small small signal board is the one with the video jack on it. It mat be easyer to replace the SSB but yes it will cost more.
Oct 09, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Blank Screen
Hi Gemma - have a look at this forum - it may be similar to what you are experiencing. http://forum.eserviceinfo.com/viewtopic.php?t=5411&postdays=0&postorder=asc&start=0 Things don't look good for NEC owners I must say! Good luck Saty.
Dec 28, 2006 | NEC PlasmaSync 42MP3 42 in. Television
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
111 people viewed this question
Alun Cox
