Question about Ricoh Aficio 1018D Copier
I have a problem with my ricoh aficio 1018d copier. It is printing very faint. let me how to go about it
  • Ricoh Master
  • 525 Answers
After every 60 000 copies the drum must change, if the drum changed inspect laser module and clean if dirt
Posted on Jan 22, 2011
Ricoh Aficio 1018D copies are light
buy a Photo conductor unit and then initialize it after you put new unit in.
Aug 14, 2014 | Ricoh Aficio 1018D Copier
How do i clean the dirty white plate in a ricoh aficio 1018d copier
Remove the exposure glass. The white plate is on the underside of the left scale. Clean with water or alcohol.
May 31, 2014 | Ricoh Aficio 1018D Copier
Ricoh aficio 1018d toner not detected
oooh i think u need to replace devoloper gears there are five gears must be replacees. u need a tech. to do that
Feb 18, 2014 | Ricoh Aficio 1018D Copier
I have a problem with my ricoh aficio 1018d 'when it finish print one paper it guve me error that stil paper in section (b) when i turn off it work good
This problem is related to two things one is your exit sensor defective or your tray settings is not correct first you have to correct the tray settigs even thow problem exist you have to change the exit sensor or BICU
thanks
Dec 16, 2010 | Ricoh Aficio 1018D Copier
Copy is faint
wipe the screen of your machine. open the screen and wipe the inside too. that can help
Aug 07, 2010 | Ricoh Aficio 1018D Copier
I have ricoh aficio 1018d can it fax or print and i cannot find connection points on machine
Sir,
You can fax or print with the aficio 1018d provided that you have the fax and printer options. these connection points are located at the back of the machine.
Mar 06, 2010 | Ricoh Aficio 1018D Copier
Can MAC OSX 10.5.x use Ricoh Aficio 1018D? Do you now alternativ drivers for ricoh aficio 1018D. HP LaserJet 5-Gutenprint v5.1.3 is o.k. for A4 but not for A3
this is an older model copier, however try going to www.savin.com and click downloads then drivers. there will be a tab for drivers, this is 10.5 though not snow leopard. Ricoh/Savin/gestetner and Lanier are all the same copier, but savin site has more mac info than Ricoh site. Usually I have better luck using already installed Mac drivers than Gutenprint, if you type in the ip it should give you a list of preinstalled Mac drivers. I believe the Ricoh 1018 corresponds to a Savin 2518 if that helps. Also use print daemon, not ipp. hope this helps somewhat as Macs are difficult with options and such on most printers. also must use PS3 for best results.
Jan 09, 2010 | Ricoh Aficio 1018D Copier
Ricoh Aficio 1018D turn off Z problem
Something is jammed somewhere, turning the power off is not the reason that the jam indicator won't go out...you're missing something. Check all areas of the copier -just because the "Z" is lit doesn't mean that the remaining jam isn't somewhere else
Apr 05, 2009 | Ricoh Aficio 1018D All-In-One Laser...
Cant reset Z error at Printer Ricoh Aficio 1018D
Im assuming that you are referring to the Z as the jam light. In that case the operation panel will tell you what part of the machine is jammed by displaying a diagram and a letter that corresponds to a chart that you will see when you open the front door. make sure to open all the doors then close them to reset jam code (there is a hidden door on the right lower side called the A door) Good luck
Ricoh 1018d not print with lan conection
Hi Usama,
I had the same proplem as you when i installed pcl6 driver on my ricoh 1085
I solved but by uninstalling pcl6 driver and installing pcl5e
for your 1018d try this driver for windows XP D O W N L O A D H E R E
BTW.
about using 1085 as a scanner ,
I don't know what is "scanner interface drive board" ?
more help please.
Oct 23, 2008 | Ricoh Aficio 1085 Laser Printer
127 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
